125 superdream wheels
old1eye
PostPosted: 17:11 - 10 Sep 2011    Post subject: 125 superdream wheels Reply with quote
hi there,
as i rebuild my 84 wet dream i want to put spoked wheels on it as apposed to the original cast alloy ones.
wondering if any one has done this before or if any one can recommend a set of wheels that should fit?
many thanks
ben
If its loud Be proud!
Nexus Icon
PostPosted: 17:13 - 10 Sep 2011    Post subject: Reply with quote
Do some research and see if a set of CB125RS wheels will go on.
Actually, Teflon Mike could probably answer that in a heartbeat.
Greetings from Shitsville!
old1eye
PostPosted: 17:24 - 10 Sep 2011    Post subject: Reply with quote
TEFLON MIKE were art thou?? lol
kk cheers dude will have a looky at some
Teflon-Mike
tl;dr
PostPosted: 17:38 - 10 Sep 2011    Post subject: Reply with quote
no idea.
Why would you want to fit wires ANYWAY?
old1eye
PostPosted: 17:45 - 10 Sep 2011    Post subject: Reply with quote
dont like the look of the alloy ones, and spoked rims, especialy wider ones, i personely feel look the dogs danglys.
Teflon-Mike
tl;dr
PostPosted: 18:50 - 10 Sep 2011    Post subject: Reply with quote
It's a 125 Super-Dream....
Spokes, of which there are about 30 per wheel are around a quid each. Decent that would take a wider tyre, bearing in mind that 3.50 rear is about as big as you can go anyway, without the rubber fouling the swing-link.... about £70 a piece.... you'd have spent more than the bike's worth before looking for suitabel hubs to lace them to or building the things!
Buy a CG or CB-RS and stick super-dream engine in it.
old1eye
PostPosted: 19:18 - 10 Sep 2011    Post subject: Reply with quote
i already have the cb though and it was free so spending a bit of money to build something i want is fine for me. i always build my own things.
i currently have a bobber rebel on the road which has a complete one off rear end that i built myself.
i dont mind spending a few ££'s on wheels as the only other big expense is going to be the paint.
my mate has a cg and i find it very flimsy
Teflon-Mike
tl;dr
PostPosted: 13:44 - 11 Sep 2011    Post subject: Reply with quote
Trouble with the CB125 Super-Dream is that they aren't particularly obliging towards modding.
The rear suspension is great as stock,and if in good fettle; but the link arangement and frame to mount it offers little scope for creativity.
Forks too, are small and uncommon diameter and length, while head-stock a tad 'long' limiting options.
Styling wise; they were quite avant-guarde, with plastic mudguards and tail cowling with integral lamp...... while the air-boxes for the battery tray.
Slope of frame back-bone makes fitting different tanks awkward; its ALL just 'difficult' to do anything really creative with.
Its an irish directions job, "Ah, well I wuddnnee be wannin to start frum here, noo!"
CB125RS, is twin shock, and updated version of old CB125S the duel grandaddy of the CB125RS/CB125T and the CG125.
It has wire wheels as standard; and twin shocks and more condusive architecture for doing anything different.
And the small bore Honda's often share a crank-case casting mount pattern. a number of 98 - 233cc engines, singles and twins are 'almost' bolt for bolt interchangeable between frames.
Lots can be done in mix and match; but the Super-Dream is a bit of a pain in the arse!
JUST fitting wire spoke wheels to one; I know I saif cost of re-rimming, but limit of what rims you could use would be small, becouse of restriction on rubber width imposed by that shock linkage.
CG wheels and thier skinny rims would probably take tyres as wide as you can squeeze in there anyway.... Heavy though, and its already a heavy bike.
If you want to percevere with it, though, I'd suggest checking out motoard wheels; I dont know what the City Fly's wheel sizes are... but a 17" rim, might give you a bit more clerance un the horse shoe of the drop link, but dont know how wide you could go before risking fouling teh chain run......
Other hassle would be jacking it up to get back the 1/2 lost on ride height from smaller wheel, and whatever extra a low-pro tyre would add.
To quicken up a Super-Dream rear end needs to go 'up', but as yet I haven't found a way!
Stick one on the centre stand, and remove top shock pin, the wheel dont fall much before the links lock... there's not much scope to get anything with it, without major engineering! Linkage doesn't have convenient dog-bone connecting link to mess with; Cast iron horseshoe drop link, and knuckle....
Looking at it, I concluded only way to make any significant change would be to cut and shut the swing arm!
Pedd
PostPosted: 13:58 - 11 Sep 2011    Post subject: Reply with quote
didn't the cb125t have wire wheels ???
A quick look around says they did, as did other variations, few diff wheels on egay too, would be pretty straight forward to put a set on tbh.
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
Teflon-Mike
tl;dr
PostPosted: 14:32 - 11 Sep 2011    Post subject: Reply with quote
The very early CB125T 'Twin-Shock' had wires; they are rare. Model was introduced 1977, but from aprox '79, they had the first generation com-star.
MattWadz
PostPosted: 16:07 - 11 Sep 2011    Post subject: Reply with quote
I also agree that wide wire wheels look wickedd!
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
old1eye
PostPosted: 17:08 - 11 Sep 2011    Post subject: Reply with quote
well i have a fair bit of experience with modding things as i have had 15ish bikes over the last 8 yrs including a one off built kwak gt 550 trike. so im up for modding.
anything i come up with i shall share on here, i will ask a few of my enginering friends and colin at moore speed racing as he knows what i like allot Smile .
as for the forks:-
Rebel 250 Original Forks: Upper: 26 x 48.5 x 15.2 Lower: 30 x 50 x 14.4)
Forks are the same size as the following bikes....
Honda C250N (79)
Honda CB250 (Early Models)
Honda CB250RS (80-84)
Honda CBX250RS
Honda CM250T Rebel (82-84)
Honda GB250F/F2
Honda MVX250 (83-84)
Honda VT250F (83-86), VTR250 (88)
Honda CB350F/F1 (73-74), CB350G (73), CB350/ K2-K4 (69-72)
Honda SL350 /K2/K3 (69-73)
Honda CB360 (74-76), CB360GT (76), CB360T (74-77)
Honda CJ360T (76-77), CL360 (74-75)
Honda CB400A (74-75), CB400F (75-77), CB400TI/TII (78-79), CB400T (80-81)
Honda CBX400F
Honda CM400A/C/E/T (79-81)
Honda GB400
Honda CB450/K1-K7 (65-74), CB450T (82), CB450SC (82-86) Honda CL450 /K2-K6 (68-74)
Honda CM450A/C/E (82-83)
Honda CB500/K1/K2 (71-73), CB500T (75-76)
Honda CX500 C/D (78-81)
Honda FT500 Ascot (82-83)
Honda GB500F/F2
Honda GL500/I (81-82)
Honda VT500 Ascot (83-84), VT500ED, VT500C/FT (83-84)
Honda CB550K/K1 (74-78), CB550F (75-77), CB550SC (83)
Honda CBX550F (82-83)
Honda CB650 (79-82), CB650C (80-81), CB650SC (82-85), CBX650ED/SCD
Honda CX650C (83), CX650ED
Honda GL650/I (83)
Honda VT700C (84-85)
Honda CB750K (69-78), CB750A (76-78), CB750F (75-78)
Honda VFR750C (83)
Honda VT750C (83)
Honda GL1000 (75-76)
Honda GL1000L (76)
so there is a bit of choice Wink
DannoXYZ
PostPosted: 16:04 - 11 Oct 2011    Post subject: Reply with quote
Ben, I've got some wire wheels from a 1990 CB125TT (U.S. version of TDC?) I'm restoring with my wife. We were looking at getting some of the 3-spoke cast wheels to run modern tubeless street tyres. Would love to trade with you. Not sure if it would be cost-effective as we're in California.
https://i42.photobucket.com/albums/e346/DannoXYZ/Motorcycles/CB125TT6.jpg
https://i42.photobucket.com/albums/e346/DannoXYZ/Motorcycles/CB125TT2.jpg
The last post was made 14 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 87.87 Kb
