| fatjames |
 fatjames World Chat Champion
 Posted: 08:55 - 08 Sep 2011 Post subject: Problems changing gear following a crash |
Hi All,
I'd been riding for about a week, and had a slight crash. It was my fault and rode into the back of somebody doing an emergency stop. I bounced off his bumper fell on the floor and dropped my bike
I'm ok (only 3 cracked ribs) but my bike took a bit of a beating. I cracked 3 bits of plastic (which I'll probably leave broken) and bent some metal. The left hand foot rest, gear shifter, clutch lever, clutch lever housing, and wing mirror. Oh and indicator are broken.
As the gear shifter was bent down and under, it was unusable. And, as the RAC cover that evil MCE supplied me with was rubbish, I had no choice but to ride on. It was stuck in 3rd which was quite fun, especially pulling away at lights..I rode to a friends house about 10 miles away like this (home was about 25 miles)
So, using some mole grips and a bit of force I bent it back out so I could get home. I've since purchased the new bits but have noticed an issue shifting from 2nd to 3rd. (not fitted the new bits yet)
Basically, when I tap the shifter up to 3rd, nothing happens, this is followed by an over rev and few bounces off the limiter. This is happening because it hasn't changed, then I try again wiggle it a bit and it shifts.
So is this problem deeper than the shifter? Have I busted the gear box? If so...how much? How hard to fix? etc..
Thanks for any advice
FJ
Oh, It's a Honda CBR125 R W7 |
| Bezzer |
 Bezzer World Chat Champion
| fatjames |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:20 - 08 Sep 2011 Post subject: Re: Problems changing gear following a crash |
| fatjames wrote: | I've since purchased the new bits but have noticed an issue shifting from 2nd to 3rd. (not fitted the new bits yet) |
Then you're worrying prematurely. Change anything that you're going to change, get it all straight and adjusted on the outside, then see if it's still doing it. From my extensive experience (one incident ) the gear shift is quite soft and easily bent on the CBR, which is a good thing, as it's less likely to have damaged anything internally. ____________________ Biking is 1/20th as dangerous as horse riding.
| fatjames |
| Ariel Badger |
 Ariel Badger Super Spammer
| fatjames |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:46 - 09 Sep 2011 Post subject: |
Very unlikely, unless you've stretched it. Just be sure to adjust it so that there's a small amount of slack at the lever before it starts pulling on the cable. ____________________ Biking is 1/20th as dangerous as horse riding.
| fatjames |
| fatjames |
The last post was made 15 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
