Fork springs and spacers
Ingah
PostPosted: 18:12 - 12 Sep 2011    Post subject: Fork springs and spacers Reply with quote
I am in the fortunate situation of having two of the same make and model of bike (2 CB500's, one to ride and one as a donor bike).
I'm using the forks from the older model on my newer daily ride (unfortunately the newer forks are pitted), and when changing the fork oil (was transferring the headlights across so it made sense as a good time to check), measured the fork springs. Haynes says they are ~308mm new, 305mm is the service limit. Mine were ~298mm! So i need to replace them, clearly.
Normally i'd just nab them from the other set of forks, but the newer model's fork springs are 100mm longer as stock, so they don't just slot in. However the spacer is much shorter.
So i put them side by side (spacer and shock vs spacer and shock) to find that the total lengths are about 50-100mm different.
So, to save me forking out the £80 a new set of Hagon springs cost, is it a bad or a good idea for me to use the longer springs and get a spacer made by a local engineering firm so that it is the right length?
-- Ingah
PostPosted: 22:54 - 12 Sep 2011    Post subject: Reply with quote
I would be looking at how far the new spring + spacer are normally compressed when fitted in the (fully assembled) fork they came from and trying to match this distance. That'll give the spring the same amount of preload when you swap it into the other fork.
If you want to be technical, check the static sag. Fit the springs and spacers then see how much the fork compresses from fully extended when you set the bike on its wheels. You're looking for around 30mm (extreme ballpark, varies with bike, stickiness of seals and rider preference).
Blue alkathene water pipe makes excellent spring spacers. It's light, strong, cheap and can be cut to length with a junior hacksaw.
As such, trial and error is also a valid tuning tool because the spacers are effectively disposable and infinately adjustable. Start with them long and cut them back a bit at a time until it feels right.
EDIT: The easiest way I can think of to measure how much preload is applied is to undo the fork cap and measure the gap between the top of the stanchion and the underside of the fork cap that normally butts against it with the fork totally unloaded and the cap on the end of the spring. You want to compress the spring by the same amount in the other fork.
Again this is ballpark because how much preload is required will vary with the overall weight and weight balance of the two different models but it should be pretty close.
Fizzer Thou
PostPosted: 00:02 - 13 Sep 2011    Post subject: Reply with quote
CB500.
Do you mean a 1975 model CB500/4?
https://i295.photobucket.com/albums/mm133/npscl/bikes060.jpg
Or a 1978 CB500T?
https://i178.photobucket.com/albums/w275/toecutterat22/1974-cb500t.jpg
Or the more recent CB500s twin?
https://i285.photobucket.com/albums/ll59/miguel29646/CB500.jpg
Always have a 'Plan B'
Teflon-Mike
tl;dr
PostPosted: 00:21 - 13 Sep 2011    Post subject: Re: Fork springs and spacers Reply with quote
I'd use the longer springs and longer spacers; I normally shim the springs on my bikes to firm up the front anyway; would save hunting washers the right diameter!
BUT:... spend the £80 on the Hagons....... and some heavier fork oil... completely transforms the bike, did my 750. Suddenly it felt 'composed' and under braking, like it WASN'T having a major panic atack!
PostPosted: 08:31 - 13 Sep 2011    Post subject: Re: Fork springs and spacers Reply with quote
Tef, your advice is usually sound... but using the longer springs with the longer spacers? The preload might well be far too high and the bike will feel awful to ride. The front end will be topped out.
If I were the OP, I'd use the longer springs with the spacers that go with those springs. I strongly suspect they could be aftermarket springs (perhaps Hagon). Recently I replaced the springs in my RD350F2 with Racetech springs. Part of the procedure for doing this was to make new spacers because the spring rate of the new springs is much greater. This means they need much less preload to have a 'good' static sag setting, and so the spacers must be shorter. In the end, I settled on 5mm preload instead of 20mm and the front end is transformed. Shame the same can't be said for the rear! This means the new spacers are 60mm instead of 85mm, which is quite a difference!
If the forks aren't preload adjustable, then you need to measure the distance from the top of the spring with the fork fully extended to the top of the fork tube. You then need to look at the fork cap and work out by how much it protrudes downward into the fork tube. Measure this value and subtract it from the first value. This number is the length the spacer needs to be with NO preload.
Being that some helpful soul has probably done this already, I'd go with the spacers that go with the longer springs. It sounds like they are better anyway.
Teflon-Mike
tl;dr
PostPosted: 09:03 - 13 Sep 2011    Post subject: Re: Fork springs and spacers Reply with quote
Actually... looking at the numbers again; you'r probably right; he says longer springs are about 100mm longer with the shorter spacer....
PostPosted: 09:43 - 13 Sep 2011    Post subject: Reply with quote
Don't forget you need a third of the suspension travel to be used when sitting on the bike. This is called rider sag.
If the bike is topped out then it won't deal with depressions in the road and you'll end up bouncing around the place.
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 61.48 Kb
