| Ingah |
 Ingah World Chat Champion
 Posted: 22:54 - 12 Sep 2011 Post subject: |
I would be looking at how far the new spring + spacer are normally compressed when fitted in the (fully assembled) fork they came from and trying to match this distance. That'll give the spring the same amount of preload when you swap it into the other fork.
If you want to be technical, check the static sag. Fit the springs and spacers then see how much the fork compresses from fully extended when you set the bike on its wheels. You're looking for around 30mm (extreme ballpark, varies with bike, stickiness of seals and rider preference).
Blue alkathene water pipe makes excellent spring spacers. It's light, strong, cheap and can be cut to length with a junior hacksaw.
As such, trial and error is also a valid tuning tool because the spacers are effectively disposable and infinately adjustable. Start with them long and cut them back a bit at a time until it feels right.
EDIT: The easiest way I can think of to measure how much preload is applied is to undo the fork cap and measure the gap between the top of the stanchion and the underside of the fork cap that normally butts against it with the fork totally unloaded and the cap on the end of the spring. You want to compress the spring by the same amount in the other fork.
Again this is ballpark because how much preload is required will vary with the overall weight and weight balance of the two different models but it should be pretty close. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Fizzer Thou |
 Posted: 00:02 - 13 Sep 2011 Post subject: |
| Teflon-Mike |
| MarJay |
 MarJay But it's British!
 Posted: 08:31 - 13 Sep 2011 Post subject: Re: Fork springs and spacers |
| Teflon-Mike wrote: | | Ingah wrote: | So, to save me forking out the £80 a new set of Hagon springs cost, is it a bad or a good idea for me to use the longer springs and get a spacer made by a local engineering firm so that it is the right length? |
I'd use the longer springs and longer spacers; I normally shim the springs on my bikes to firm up the front anyway; would save hunting washers the right diameter!
BUT:... spend the £80 on the Hagons....... and some heavier fork oil... completely transforms the bike, did my 750. Suddenly it felt 'composed' and under braking, like it WASN'T having a major panic atack! |
Tef, your advice is usually sound... but using the longer springs with the longer spacers? The preload might well be far too high and the bike will feel awful to ride. The front end will be topped out.
If I were the OP, I'd use the longer springs with the spacers that go with those springs. I strongly suspect they could be aftermarket springs (perhaps Hagon). Recently I replaced the springs in my RD350F2 with Racetech springs. Part of the procedure for doing this was to make new spacers because the spring rate of the new springs is much greater. This means they need much less preload to have a 'good' static sag setting, and so the spacers must be shorter. In the end, I settled on 5mm preload instead of 20mm and the front end is transformed. Shame the same can't be said for the rear! This means the new spacers are 60mm instead of 85mm, which is quite a difference!
If the forks aren't preload adjustable, then you need to measure the distance from the top of the spring with the fork fully extended to the top of the fork tube. You then need to look at the fork cap and work out by how much it protrudes downward into the fork tube. Measure this value and subtract it from the first value. This number is the length the spacer needs to be with NO preload.
Being that some helpful soul has probably done this already, I'd go with the spacers that go with the longer springs. It sounds like they are better anyway. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Teflon-Mike |
| MarJay |
The last post was made 15 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
