Car sounds like a diesel and exhaust running red hot.
Wave2k
G's Stalker
PostPosted: 16:25 - 13 Sep 2011    Post subject: Car sounds like a diesel and exhaust running red hot. Reply with quote
Its a Nissan Primera 2.0
After about 2-3 minutes of running the car starts to sound like its an old diesel van.
So i checked the oil, as i checked it a little drips from the stick onto the exhaust manifold cover.
It turns to smoke instantly, its absolutely red hot.
Trouble is the temp guage in the car says the temp is normal (right in the middle).
Could this perhaps be pre-ignition, what could cause this.
BTW i picked the car up the other day, it cost me £400.
Im doing an Ebay car challenge round Europe for under 500 quid cars.
It appears ive already bought a dud lol.
But any help would be greatly aappreciated
Ducati 1299 Panigale
2009 Corvette C6 z51
PostPosted: 16:34 - 13 Sep 2011    Post subject: Reply with quote
Exhaust probably should be VERY hot on anything vaguely new to get the cat hot quickly. Possibly there is a missing heat shield from around the exhaust.
For the engine to heat the exhaust up would suggest either a very lean mixture (possible) or cam timing out (possibly might explain the diesel noise, but probably run like a dog). Ignition timing might do it as well, but again I would expect it to run badly.
To be honest my main guess would be a knackered and blocked up catalytic converter.
Wave2k
G's Stalker
PostPosted: 16:37 - 13 Sep 2011    Post subject: Reply with quote
any way i can check this ?
What about the 02 sensor ?
PostPosted: 16:44 - 13 Sep 2011    Post subject: Reply with quote
O2 sensor can affect the mixture, but probably not from cold (it is probably ignored for the first few minutes). Wouldn't expect it to cause the exhaust to be unusually hot that quickly from a cold start.
Not sure of any tricks to check the cat.
karoshi
PostPosted: 16:59 - 13 Sep 2011    Post subject: Reply with quote
burnt out an exhaust valve?
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
SoND
PostPosted: 17:51 - 13 Sep 2011    Post subject: Reply with quote
When you say it's red hot, you mean it's literally glowing red with heat? Surprised
Good luck getting round Europe Very Happy
ajbsmirnoff
PostPosted: 18:30 - 13 Sep 2011    Post subject: Reply with quote
Blocked cat ?
neatbik
PostPosted: 20:36 - 13 Sep 2011    Post subject: Reply with quote
Has it got variable valve timing?
I only ask as our renault developed a faulty dephaser pulley and sounded like a diesel at idle.
No idea why it would cause it to run hot though if that is the problem..
Wave2k
G's Stalker
PostPosted: 21:08 - 13 Sep 2011    Post subject: Reply with quote
I dont believe it has VVT,
I assume you are refering to something simular like you get on the Alfas in the late 90s early 00s with the VVT rattle ?
it dead strange, it only starts to sound rough when the exhaust manifold cover is hot enough to evaporate oil instantly.
The top of the radiatior gets pretty hot too.
I thought it may be the water pump, but that would show up if the temp guage rose in the car, which it dont.
Though if the car was running VERY lean, id imaging that /could make the manifold v.hot.
Surely a rich mixture would make it run colder.
Hex
Party Boy
PostPosted: 22:24 - 13 Sep 2011    Post subject: Reply with quote
at operational temp the manifold of any car is going to burn the oil off straight away Dave.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Biker100
PostPosted: 13:19 - 14 Sep 2011    Post subject: Reply with quote
Agree with others, blocked cat possibly.
Just take a big drill bit to the cat internals n knock it through with a pry bar and hammer...
Instant decat lol
plugger147
PostPosted: 03:59 - 15 Sep 2011    Post subject: Reply with quote
Had a few issues with blocked cats and if there's no issue with power loss then I wouldn't say it was a blocked cat, the oil would burn off the manifold after its warmed up in no time.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Wave2k
G's Stalker
PostPosted: 18:05 - 15 Sep 2011    Post subject: Reply with quote
There isnt really an issue with power, its a really nice smooth car to drive.
Apart from it sounding like a bag of spanners or an 1980s Diesel.
I was perhaps thinking, after lifting the oil cap although the oil in there is fresh, at some point the oil had sat in there for ages, as there are sludgy deposits.
Could there be a blocked oil passage, perhaps restricting oil to the head ?
ALSO oil appears to be fairly overfilled, maybe by around 25%+
Could this affect crack pressure enough to do this ?
PostPosted: 18:16 - 15 Sep 2011    Post subject: Reply with quote
Over full oil would likely pop out of the breather and be burnt by the engine (a cat stops that from being really noticeable), although if full enough / revved enough it will blew seals in the engine.
One thought, is the oil the right grade? Too thick oil doesn't work well with hydraulic tappets and can cause them to pump up. Which might mean the exhaust valves staying open a touch and odd noises.
Wave2k
G's Stalker
PostPosted: 18:18 - 15 Sep 2011    Post subject: Reply with quote
Im not sure, but i think im gonna change the oil anyway just to be sure.
Tiff
PostPosted: 18:21 - 15 Sep 2011    Post subject: Reply with quote
Older Primera's had cam chains- could be the tensioner-either no oil pressure or broken up with would cause a rattling noise. Can you take a vid of it running?
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
Wave2k
G's Stalker
PostPosted: 18:30 - 15 Sep 2011    Post subject: Reply with quote
yea, that i can do.
Ill try get there out there tomorrow.
But to explain it.
Starting from cold....
Really loud at startup, then quiets down.
after gets upto operating temp, it consistantly sounds like a diesel, more noticable at idle, gets quieter as you rev, but its still there.
But it drives quite well, no adverse MPG that ive noticed as of yet either.
Wave2k
G's Stalker
PostPosted: 18:34 - 15 Sep 2011    Post subject: Reply with quote
Tiff after reading that it has a Cam chain, i read up about it.
It could be possible.
it sounds rather like this
https://www.youtube.com/watch?v=bFSA5a6UmUs
Tiff
PostPosted: 18:45 - 15 Sep 2011    Post subject: Reply with quote
Yeah, not too clear in the vid, but reckon its chain. I see you have a VTR, so same applies to the Primera with regards to camchain tensioners...!! In this pic you can see the parts- if the tensioner is gone the chain will flap about...
https://images.shoppit.co.uk/sizeimage.aspx?client=35133&image=tk54.jpg&height=300&width=300&colour=FFFFFF&offer=0
Wave2k
G's Stalker
PostPosted: 18:55 - 15 Sep 2011    Post subject: Reply with quote
Nah its not a VTR, thats just a primera i found on youtube with a simular problem.
ITs a 2.0 SE with the SR20De engine.
But yea, it could be right.
Is there any simple way i can fix this myself, or taking it to a garage and it costing less than £150.
I mean the car only cost £400, so im not splitting hairs over it, if its too expensive, ill just drive till she blows.
Tiff
PostPosted: 18:57 - 15 Sep 2011    Post subject: Reply with quote
Wave wrote:
Nah its not a VTR
I meant a Honda VTR Laughing Just did tensioners and chains on one of these a few weeks back...
Less than £150- no chance. The kit is £100+. Its quite a big job, maybe a 5 spanner job in Haynes.....
Wave2k
G's Stalker
PostPosted: 19:15 - 15 Sep 2011    Post subject: Reply with quote
arrrr she blows Smile
Now i havent heard of a CC snapping, so im hoping this is just going to be all noise no trousers.
I did however have my Cam belt snap on my Audi TT
Talking of bike cam chain rattles, the only rattle i had was on the CBR600RR, it was only 3 years old at the time.
Worst build quality out of all my bikes that one.
Tiff
PostPosted: 19:20 - 15 Sep 2011    Post subject: Reply with quote
I've seen a few Nissan's, especially little Micra's, snapping chains... 3 Cyl Corsas are prone to it too- listen to one the next time you see one on the road...
As for Honda bikes.. well I just don't get on with them, and any one I've had has been troublesome.
Cam belt snap on a TT... ouch. wasn't the crazy plastic water pump that did it was it?
Wave2k
G's Stalker
PostPosted: 19:22 - 15 Sep 2011    Post subject: Reply with quote
Nah, it actually slipped instead of snapped.
same result though, pistons......meet valves.....
The last post was made 14 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 131.55 Kb
