Xena alarmed disk lock. Help!
Crazyd943
PostPosted: 17:49 - 13 Sep 2011    Post subject: Xena alarmed disk lock. Help! Reply with quote
Hey guys,
Bought a Xena XZZ6L alarmed disk lock, and can't get the bloody battery in.
I've got it apart, got the battery in, but it's auto-arming. so when the battery goes in, I get 10 seconds before the warning beeps. Xena's youtube installation says it should disarm when replaced in the lock body, but mine just carries about its business of blasting 120dB into my skull.
How do I put the bloody battery in, and then disarm it?
Charlie
PostPosted: 18:20 - 13 Sep 2011    Post subject: Reply with quote
Is there anything effecting the sensor in the lock?
Codemonkey
PostPosted: 18:45 - 13 Sep 2011    Post subject: Reply with quote
There's supposed to be a little shiny circle in the slotted bit of the lock body that the IR beam gets reflected off. Check that this is clean and that the bit of the electronics housing that sits above that area is clean and unobstructed or it will constantly think its attached to a bike and go off every time you move it.
Test Passed 10/05/2011 Current bike: XJ6-N
Crazyd943
PostPosted: 19:46 - 13 Sep 2011    Post subject: Reply with quote
Yeah, I checked that. The reflector and sensors are both clean.
It's brand new out of the box. Is it likely I've got a dud?
Codemonkey
PostPosted: 07:35 - 14 Sep 2011    Post subject: Reply with quote
If you just stick the battery in and put it all back together, after it initially goes off, does it shut up eventually ?
If it does, does it then go off again if you move it (without it being on a bike) ? If so, sounds like its dodgy.
Crazyd943
PostPosted: 16:48 - 14 Sep 2011    Post subject: Reply with quote
I'm gonna give it one more shot.
Last time, after it shut up, it stayed armed. I haven't tried getting the bolt back in incase it won't shut up. I'm not gonna try undo it again like a bomb disposal expert.
Crazyd943
PostPosted: 17:11 - 14 Sep 2011    Post subject: Reply with quote
Tried it again. Shouldn't have.
It still thinks it's on my lock, but the rubber battery gasket has jammed the alarm module to the body.
So it's armed. And stuck in the body. With the battery in.
Doh!
Codemonkey
PostPosted: 19:08 - 14 Sep 2011    Post subject: Reply with quote
lol, I understand your frustration. Mine went through a phase where it would go off randomly while in my bag on my way to work at about 6:30am!
I used mine as just a lock with the electronics module removed for a few months until I could be arsed to give the thing a good clean and sort it out. Fortunately its been fine ever since.
Crazyd943
PostPosted: 18:44 - 15 Sep 2011    Post subject: Reply with quote
After taking the rubber seal out, it worked fine. So maybe it was just misaligned. But obviously it's not weatherproof without the battery seal.
Got in touch with the seller, and they're going to replace the alarm module.
S'all good. Thumbs Up
Charlie
PostPosted: 22:18 - 15 Sep 2011    Post subject: Reply with quote
Can be quite fiddly getting the rubber to fit well. Good seller to just replace it, think you should name them Thumbs Up
Crazyd943
PostPosted: 22:44 - 20 Sep 2011    Post subject: Reply with quote
Aye, it is. Very pleased with the service thus far.
And next day signed for delivery, which wasn't mentioned. I think postage was £2/3.
Anyway, just posted it today, so lets see how quick they can get it back. Wink
Assuming all goes well, motorsportelectrics on fleabay. Thumbs Up
The last post was made 14 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 71.34 Kb
