| McJamweasel |
 McJamweasel BCF Junkie
 Posted: 18:08 - 03 Sep 2004 Post subject: Booger |
Failed MOT on one missing reflector and one small crack in the frame, around the dent.
The tester says it will be ok welded though and he's told me where I can get it done, should only cost a few quid. ____________________ BCF: Be yourself, just don't be an arse. |
| iCraig |
 iCraig World Chat Champion
 Posted: 18:11 - 03 Sep 2004 Post subject: |
Bit of a bugger when things fail.
Last time my GS would have failed on not having the reflector, but the tester stuck one on and passed it . |
| stryker |
 stryker Brolly Dolly
| ratcliffe |
 ratcliffe Scooby Slapper
| McJamweasel |
 Posted: 17:44 - 07 Sep 2004 Post subject: |
So, today I whipped the fairing off and had a proper look. It still didn't seem like a crack to me. Anyway, off I toddle to the alloy welder that I was recommended. He had a poke around it and decided that it wasn't a crack at all, just a crease. He said he could have a go at putting a weld on it but it wouldn't be easy and wasn't needed.
Back to the MOT tester, told him what the welder bloke had said and he proceeded to poke and scratch at it with a screwdriver. He was still adamant that it was a crack though.
I decided to take it to another tester for a second (well, third actually) opinion. I told him the story before he saw it, so I wasn't hiding anything from him. He says that he can't see a crack (and he's younger with better eyes than the first one ) and he will certainly pass it on the frame. Its all booked in for thursday, and they even gave me a reflector for the back.
Thats the first and last time I use the first place I went to. ____________________ BCF: Be yourself, just don't be an arse. |
| Ste |
 Ste Not Work Safe
 Posted: 17:48 - 07 Sep 2004 Post subject: |
Nice. Did do a fair bit of looking into it when I got it and everywhere said as long as there is no crack (which there isn't, or not unless you've been to the G school of how to do wheelies maybe ) it'd be fine. Other thing if they are being arsey about it could put those tarty carbon fibre frame covers on it to hide it.  |
| McJamweasel |
| iCraig |
 Posted: 17:51 - 07 Sep 2004 Post subject: |
I've found some MoT Testers find problems with vehicles just to try and get money out of you.
They think if they say its failed you'll say fix it for me etc, or recommend you to someone else they know and they get commision or something.
I always found Riossi to be good at doing MoT's, they failed things for a reason and not just stupid ones like bulbs or anything.
They'd pass it and then tell you and then not even charge you for the bulb! Pity Riossi are now gone .
Though the Hells Angel that owns the garage I now go to is not really arsed and passes most things . |
| Ste |
 Ste Not Work Safe
 Posted: 18:05 - 07 Sep 2004 Post subject: |
| karen_moomin |
 karen_moomin World Chat Champion
| McJamweasel |
| McJamweasel |
 Posted: 13:45 - 09 Sep 2004 Post subject: |
God damn!!!
This guy has said the steering head bearings are too rough. I give up.  ____________________ BCF: Be yourself, just don't be an arse. |
| karen_moomin |
 Posted: 14:17 - 09 Sep 2004 Post subject: |
What are you going to do then?? We need it to pass so we can go to France  |
| Robby |
 Robby Dirty Old Man
| M1ke |
 M1ke Ped Boi
 Posted: 16:28 - 09 Sep 2004 Post subject: |
You can borrow my rgv for the france trip  |
| dibbster |
 dibbster Nearly there...
| Ste |
 Ste Not Work Safe
 Posted: 22:41 - 09 Sep 2004 Post subject: |
As useful as slightly dodgy MOT's are, having a bike to be road worthy and MOT standard is a fairly useful thing to have most of the time.
Head bearings as robby said aren't too much hassle .  |
| dibbster |
| Ste |
 Ste Not Work Safe
 Posted: 00:28 - 10 Sep 2004 Post subject: |
The frame AFAIK isn't a MOT failure, I owned the bike before McJam and did a lot of looking into the whole MOT with dented frame issue and everywhere I spoke to said it wasn't an issue. Does seem slightly dodgy them saying we'll fail it because of the dent but we'll pass it if you put poly filler in it and paint it.
Head bearing are do need changing every so often, and that bike spent a bit of it's life not using both wheels which generally does wear the head bearings more. Might be worth seeking Keith's thoughts on the head bearings and either adjusting or changing them.  |
The last post was made 22 years, 53 days ago. Instead of replying here, would creating a new thread be more useful? |
