Upgrading my calipers
shereen
PostPosted: 22:38 - 15 Sep 2011    Post subject: Upgrading my calipers Reply with quote
Im thinking of uprgrading the calipers on my nc30. Does anyone know what will fit straight on - or if thats even possible?
temeluchus
PostPosted: 23:12 - 15 Sep 2011    Post subject: Re: Upgrading my calipers Reply with quote
if money is no issue, ap racing, harrison or pretech would be worth a call.
Quote Me Happy
PostPosted: 06:01 - 16 Sep 2011    Post subject: Reply with quote
Is there a problem with you existing brakes?
Try overhauling your existing callipers as well, new seals, fluid and a good clean can work wonders.
PostPosted: 08:11 - 16 Sep 2011    Post subject: Reply with quote
This.
However people have done adaptor plates for various calipers on NC30s over the years. Rick Oliver's probably the guy to speak to.
PostPosted: 08:33 - 16 Sep 2011    Post subject: Reply with quote
This. Consider braided lines along with good pads.
While they aren't the most amazing calipers, I've seen plenty of people win races with them just fine Smile.
shereen
PostPosted: 09:22 - 16 Sep 2011    Post subject: Reply with quote
I have braided lines all round and the pads cost a me a small fortune.
I didnt think of overhauling the brakes. I just dont feel overly confident when braking Confused
PostPosted: 09:24 - 16 Sep 2011    Post subject: Reply with quote
In what way don't you feel confident. More likely to be a suspension/tyre issue than a caliper issue IMO.
PostPosted: 09:29 - 16 Sep 2011    Post subject: Reply with quote
You should be able to stand an NC30 on it's nose from A road speeds without too much effort. If you can't with good hoses and pads, then yes, sounds like it needs a service Thumbs Up.
shereen
PostPosted: 09:31 - 16 Sep 2011    Post subject: Reply with quote
When im braking I feel like I have to squeeze the brakes harder than I should to stop effieciently. Not so much at higher speeds when I just need to slow down a bit, but more at mid to lower speeds when I might need to stop suddenly or slow down quickly.
P.
PostPosted: 09:32 - 16 Sep 2011    Post subject: Reply with quote
My brakes are absolutely fantastic since I put braided lines, new pads and stripped and cleaned them. I rarely have to use more than 1 finger lightly squeezing Laughing Used to be 4 fingers and digging feet into the floor Mr. Green
Give them a strip down and give them a nice clean Thumbs Up
shereen
PostPosted: 09:52 - 16 Sep 2011    Post subject: Reply with quote
Will give it a try, so when you say strip them down and clean them, I should be taking the calipers off, pads out and just literally wiping them down with some sort of cleaning fluid? Shifty
P.
PostPosted: 09:54 - 16 Sep 2011    Post subject: Reply with quote
Well, not sure how your calipers are, but mine split into 2 pieces, I pumped the pistons out, cleaned inside them with brake cleaner and a soft toothbrush. Reassembled and then bled them etc.. The difference that it made is crazy, i'll be doing it again after winter.
MarkJ
PostPosted: 09:59 - 16 Sep 2011    Post subject: Reply with quote
If you're going to do everything you'd also need to pull all the pistons out, clean any corrosion out from behind the seals, replace any seals that are knackered and replace any pistons that are pitted. Might need to replace the orings that seal both sides of the calipers if they're opposed piston calipers, too.
shereen
PostPosted: 11:08 - 16 Sep 2011    Post subject: Reply with quote
Righto, so I'l be taking it to the garage then Laughing
P.
PostPosted: 11:09 - 16 Sep 2011    Post subject: Reply with quote
You can DIY Laughing It really isnt as hard as it sounds.
You just remove them and reassemble is the right order Laughing
DrDonnyBrago
PostPosted: 11:11 - 16 Sep 2011    Post subject: Reply with quote
Will cost you a fortune!
Get the spanners out it isn't hard, practice on the rear brake first so if you do find you are unable to do it (you wont, but it is nice to have a backup plan) then you can still ride it to a garage somewhere.
shereen
PostPosted: 11:34 - 16 Sep 2011    Post subject: Reply with quote
Hmmmm better dig the Haynes manual out then Very Happy
temeluchus
PostPosted: 15:34 - 16 Sep 2011    Post subject: Reply with quote
Replacing the piston in the master cylinder is simple enough. As far as the caliper goes, its likely to be quite rotten but isnt too hard to once its all cleaned up.
PostPosted: 16:10 - 16 Sep 2011    Post subject: Reply with quote
I might be crazy but what about just bleeding them.
Why has no one mentioned that yet? Rolling Eyes
If you have decent pads and braided lines try that, it will cost you £3 in brake fluid and take you an hour if you are borderline retarded.
As for cleaning them up this is also a piece of piss, although a little more expensive if you haven't got the bits.
You will need to buy brake cleaner £5
Toothbrushes 11p for 2 in Tesco
Silicone grease £????
Copperslip £????
Take the pads out, pump the pistons out, use the brake cleaner and tooth brush to clean them, then put the grease on and put them back together using copper slip on the back of the pads and on any pins/threads.
Brake seals are usually more expensive than the pads and don't often need doing.
shereen
PostPosted: 16:18 - 16 Sep 2011    Post subject: Reply with quote
If the brakes needed bleeding wouldnt the brake lever feel spongie? I dont want to get it wrong bleeding them as I could do more harm than good and get air in the system? Being as I am truly borderline retarded Laughing
PostPosted: 16:19 - 16 Sep 2011    Post subject: Reply with quote
Yea, were it me, I'd start with a cursory clean, lube and bleed - shouldn't take much more than three quarters of an hour and may well make a big difference.
0l0dom0l0
PostPosted: 22:45 - 16 Sep 2011    Post subject: Reply with quote
I can always give you a hand Shereen Thumbs Up
You've got 4 pots anyway which are nice to work on Very Happy.
Give them a good clean etc. If they are still no better let me know asap and if I've got time I will get you to order the parts and we can spend a morning doing them.
I love working on brakes as it's very satisfying at the end Smile.
Silentwalker
PostPosted: 22:58 - 16 Sep 2011    Post subject: Reply with quote
All the advice so far is sound, although I’d replace all seals as a matter of course if I’m taking the thing to bits. Also where the seals sit might need a good scrap out?
But back to your original question, yes it is possible there might be a 6 pot that could bolt on direct or need one off machined spacers. It’s the type of knowledge an owners club might have for members?
shereen
PostPosted: 12:48 - 17 Sep 2011    Post subject: Reply with quote
Thanks! I may well take you up on that. I will have a go when I get a chance and see how I get on with cleaning them.
The fluid was changed about 2000 miles ago when it last had a service.
The last post was made 14 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 130.91 Kb
