| shereen |
 shereen World Chat Champion
| temeluchus |
 ..... Quote Me Happy
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| G |
 G The Voice of Reason
| shereen |
| Wafer_Thin_Ham |
| G |
 Posted: 09:29 - 16 Sep 2011 Post subject: |
You should be able to stand an NC30 on it's nose from A road speeds without too much effort. If you can't with good hoses and pads, then yes, sounds like it needs a service . |
| shereen |
| P. |
 P. Red Rocket
 Posted: 09:32 - 16 Sep 2011 Post subject: |
My brakes are absolutely fantastic since I put braided lines, new pads and stripped and cleaned them. I rarely have to use more than 1 finger lightly squeezing Used to be 4 fingers and digging feet into the floor
Give them a strip down and give them a nice clean  |
| shereen |
| P. |
 P. Red Rocket
| MarkJ |
 MarkJ World Chat Champion
| shereen |
 Posted: 11:08 - 16 Sep 2011 Post subject: |
| ##Paddy## wrote: | Well, not sure how your calipers are, but mine split into 2 pieces, I pumped the pistons out, cleaned inside them with brake cleaner and a soft toothbrush. Reassembled and then bled them etc.. The difference that it made is crazy, i'll be doing it again after winter. |
| MarkJ wrote: | If you're going to do everything you'd also need to pull all the pistons out, clean any corrosion out from behind the seals, replace any seals that are knackered and replace any pistons that are pitted. Might need to replace the orings that seal both sides of the calipers if they're opposed piston calipers, too. |
Righto, so I'l be taking it to the garage then  ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| P. |
 P. Red Rocket
 Posted: 11:09 - 16 Sep 2011 Post subject: |
You can DIY It really isnt as hard as it sounds.
You just remove them and reassemble is the right order  |
| DrDonnyBrago |
| shereen |
 Posted: 11:34 - 16 Sep 2011 Post subject: |
Hmmmm better dig the Haynes manual out then  ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| temeluchus |
| chris-red |
 Posted: 16:10 - 16 Sep 2011 Post subject: |
I might be crazy but what about just bleeding them.
Why has no one mentioned that yet?
If you have decent pads and braided lines try that, it will cost you £3 in brake fluid and take you an hour if you are borderline retarded.
As for cleaning them up this is also a piece of piss, although a little more expensive if you haven't got the bits.
You will need to buy brake cleaner £5
Toothbrushes 11p for 2 in Tesco
Silicone grease £????
Copperslip £????
Take the pads out, pump the pistons out, use the brake cleaner and tooth brush to clean them, then put the grease on and put them back together using copper slip on the back of the pads and on any pins/threads.
Brake seals are usually more expensive than the pads and don't often need doing. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| shereen |
 Posted: 16:18 - 16 Sep 2011 Post subject: |
If the brakes needed bleeding wouldnt the brake lever feel spongie? I dont want to get it wrong bleeding them as I could do more harm than good and get air in the system? Being as I am truly borderline retarded  ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| G |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:45 - 16 Sep 2011 Post subject: |
I can always give you a hand Shereen
You've got 4 pots anyway which are nice to work on .
Give them a good clean etc. If they are still no better let me know asap and if I've got time I will get you to order the parts and we can spend a morning doing them.
I love working on brakes as it's very satisfying at the end . ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Silentwalker |
 Silentwalker Two Stroke Sniffer
| Vincent |
 Vincent Banned
 Posted: 10:54 - 17 Sep 2011 Post subject: |
When was the last time the fluid was changed? I've just replaced mine and it's made a massive difference  ____________________ Space Is Deep |
| shereen |
 Posted: 12:48 - 17 Sep 2011 Post subject: |
| 0l0dom0l0 wrote: | I can always give you a hand Shereen
I love working on brakes as it's very satisfying at the end  . |
Thanks! I may well take you up on that. I will have a go when I get a chance and see how I get on with cleaning them.
The fluid was changed about 2000 miles ago when it last had a service. ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
The last post was made 14 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
