Removing GS500 seat
_Troy_
PostPosted: 09:16 - 17 Sep 2011    Post subject: Removing GS500 seat Reply with quote
Good morning all.
I am trying to replace the battery on the GS and I can't get the seat open.
The catch is broke , so using the key does nothing. Is there any other way of getting it off?
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
Paxovasa
PostPosted: 09:43 - 17 Sep 2011    Post subject: Reply with quote
Coat hanger and hook it over the release.
It will be trial and error.
_Troy_
PostPosted: 09:44 - 17 Sep 2011    Post subject: Reply with quote
Any idea where the release roughly is? I've been trying this but am having no luck at all
Paxovasa
PostPosted: 09:56 - 17 Sep 2011    Post subject: Reply with quote
Near the rear of the seat, you might be able to lift the seat a fraction and see it..
_Troy_
PostPosted: 10:15 - 17 Sep 2011    Post subject: Reply with quote
Can't seem to see it. Any ideas on what it looks like?
I would have thought there would have been some bolts that allow you to take the rear plastics off...
Paxovasa
PostPosted: 10:21 - 17 Sep 2011    Post subject: Reply with quote
https://pinwallcycle.com/ebay/bike3035/516.jpg
With a cable linking it to the seat release lock.
_Troy_
PostPosted: 10:27 - 17 Sep 2011    Post subject: Reply with quote
So it is the thing I've been attacking for a while.
Cheers for the help. I shall keep trying.
Like Mr Clarkson once said 'if you believe something will happen, it will happen '
Paxovasa
PostPosted: 10:29 - 17 Sep 2011    Post subject: Reply with quote
Good luck chap. My fingers are crossed for you Wink
_Troy_
PostPosted: 10:37 - 17 Sep 2011    Post subject: Reply with quote
Just out of interest is this supposed to be an easy task? I'm getting thoroughly cheesed off and am getting nowhere at all
Paxovasa
PostPosted: 10:41 - 17 Sep 2011    Post subject: Reply with quote
It gets easier with experience of doing it..
It is the cable that goes from the above image that you need to hook and then give it a tug (while you lift the seat). Thumbs Up
_Troy_
PostPosted: 10:55 - 17 Sep 2011    Post subject: Reply with quote
So there should be a cable coming off that unit? The cable that is attached to the key unit is still attached to the key unit, and it is the other end where it has come off...
Paxovasa
PostPosted: 10:58 - 17 Sep 2011    Post subject: Reply with quote
Yes, there should be a cable coming from the above unit.
It might not have come off, it may just be a little seized.
If it has come off, then you will have a problem.
Check this ebay link out:
https://www.ebay.co.uk/itm/SUZUKI-GS500-K1-SEAT-RELEASE-CABLE-/230632503171
_Troy_
PostPosted: 11:07 - 17 Sep 2011    Post subject: Reply with quote
I can't see any cable coming from it. I can only just about make out a little bit of gold from the unit. Could it be hidden, or would the cable be easy enough to see?
That's the cable which is still attached to the key end, and not the unit...
Paxovasa
PostPosted: 11:09 - 17 Sep 2011    Post subject: Reply with quote
The cable will not be very visable. check the ebay link above, as that shows you were the cable is attached onto the release mechanism.
_Troy_
PostPosted: 11:14 - 17 Sep 2011    Post subject: Reply with quote
Yea see the above edit, that's the cable that is attached to the key end, and is freely dangling around
Paxovasa
PostPosted: 11:19 - 17 Sep 2011    Post subject: Reply with quote
Yikes, the cable has broke or come loose from the release mechanism.
If that is the case then I don't know if it is possible to get to the release mechanism without forcing the seat off.
Hopefully someone else may be able to help.
_Troy_
PostPosted: 11:22 - 17 Sep 2011    Post subject: Reply with quote
Bollocks.
Is there any way of taking the whole seat unit off by removing bolts underneath?
P.
PostPosted: 11:25 - 17 Sep 2011    Post subject: Reply with quote
You can force it off.. its literally a lipped piece of metal.
I got mine off by removing the half snapped side panel...
You should be able to lift it enough at the rear without breaking it, enough to get a screwdriver in there and nip the catch open.
_Troy_
PostPosted: 11:36 - 17 Sep 2011    Post subject: Reply with quote
Hey Paddy,
Care to elaborate on all that. I can force the rear of the seat up a tiny bit. But where is the catch I need to get to.
Paxovasa
PostPosted: 11:38 - 17 Sep 2011    Post subject: Reply with quote
In the ebay link I provided, the cable attaches to a slide release.
You will need to force the seat up far enough for you to get a screwdriver onto the slide release and move the release to the left (when stood behind the bike).
_Troy_
PostPosted: 17:02 - 17 Sep 2011    Post subject: Reply with quote
Thanks for all the help guys. Managed to get the seat off and the bike is running brilliantly.
The last post was made 14 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 104.12 Kb
