VFR800 FiW Electrical Issues
Scooty
PostPosted: 09:12 - 20 Sep 2011    Post subject: VFR800 FiW Electrical Issues Reply with quote
Morning All,
I've been having a lot of issues with my 1998 VFR800 FiW recently. It's been off of the road for a couple of months now due to electrical issues. I thought that these had been solved, but apparently not... I'll tell you the tale so far.
For a while, the bike had been dropping power as I was riding. Pootling along, when suddenly the power drops, then goes back to normal, resulting in a jerking action. As it did this, the FI light would flash on, and then go out again. I tolerated this for a while, until I moved into my own house with a garage, where she sat for a couple of months.
I tried to start her, but she had a dead battery. So, I buy an Optimate, and leave her to charge. Put her in for an MOT at Farnham Honda (which she passed), then picked her up on a Friday morning. Friday evening, I was riding home, and stopped at a cash point. Turned engine off, but left lights on as I got cash out. Got back to bike, and she wouldn't start - dead battery again So, manage to get her rolling down a hill and bump start her. Pull up at a roundabout, and she cuts out. Get her rolling again, bump start again, and off she goes. Then cuts out. I repeated the cycle one more time, then called the RAC.
The chap arrived about half an hour later, and goes about checking the battery - dead. So he gets out his charger, and gets it going. He also replaces the main fuse which had blown, and discovers that the bike won't start with the sidestand down - very odd behaviour. So, after a while charging, we decide to see if she can limp home. She gets there, but it is kangarooing the whole way, with the FI light doing a strobe light impression. Not a relaxing way to ride. Especially as it is dark, and both of my tail lights had blown (not the brake light part though, they were still fine). So, that was the same day that the bike passed the MOT.
I put it in my garage, and started to do some research. I stuck the battery on to charge overnight, and then went about looking at the FI light flashes - seemed to be doing a single long flash. So I cleared the memory, and set about doing some poking about. I checked the fuses, the 10amp Fan fuse had blown, so that was replaced. The rest were fine. Checked the Regulator/Rectifier as detailed in my Haynes manual - seemed to be fine. Took connectors apart, sprayed them with contact cleaner. Checked my ECM. It seemed that one of the wires (B8 in my Haynes manual) when poked caused the engine to die. No warning light flashed though. I couldn't really test this properly though, as the battery kept on losing too much charge to start the engine.
So, I bought a new battery from Halfords, as well as some electrical tape, and some new tail light bulbs. Pulled out the wire B8, disconnected it from the metal plug, gave it a spray, re-attached it and pushed it back in. Charged the new battery, and put that it. Replaced the blown bulbs. Started the bike - all seemed well. Still wouldn't start if the sidestand was down, but I can live with issues like that Also added some foam pads to the bottom of the ECM to try and minimise movement, and bolted the cover over to stop it from moving about. That was Sunday night. Got too dark to test ride a bike I wasn't 100% sure about, so left it till last night.
Started first time (when the sidestand was up!), and rode well. Rode to the garage to check my tyre pressures - a bit low, so I sorted that. Then went out for a little bit of a blast. Was so nice to be back on her after 4 months off of the road.
Then the FI light flashed again (after being out for about 20 minutes). Oh dear. Power started to drop, then come back - leading to a nice jerk accompanied by and FI flash. Rode back home, with this happening every couple of minutes.
Stuck a jumper wire into the service check connector and turned the ignition on. Now, the FI light was reset before this ride, so I assume the reading was accurate - FI light stayed on constantly. So, looks like it will be one of the below:
FI light blinks - 0
Engine operates normally
1. Blown malfunction indicator bulb
2. Open or short circuit in malfunction indicator wire
3. Faulty ECM
FI light blinks - 0
1. Short circuit in malfunction indicator wire
2. Short in service check connector wire
3. Faulty ECM
Does anyone have any ideas what my next course of action should be? Other than go moan at Farnham Honda for refusing to look at my electrics, but giving it an MOT the same day that it broke down
This is the second summer that I have missed due to having a broken bike. First, it was the most reliable 125 bike, the CG125. Now, one of the most reliable big bikes, the VFR800. I might go and set fire to Mr Honda now...
[/rant][/img]
Current Bike: 2018 Honda CRF250L
Ex-Bikes: 2002 Honda CG125, 1998 Honda VFR800, 2011 Honda CBR600F, 2013 Triumph Sprint GT SE, 2015 Kawasaki ZX10R
sickpup
Old Timer
PostPosted: 10:08 - 20 Sep 2011    Post subject: Reply with quote
There is a cut out switch on the side stand to stop the bike starting when it is down.
The Reg/Rec needs replacing.
jjdugen
PostPosted: 10:49 - 20 Sep 2011    Post subject: Reply with quote
Amen to the reg/rec, classic symptoms.
Worth checking the stator too, three leads, same colour going into the reg/rec. Disconnect from the reg, multimeter set to OHMS measure resistance between each output lead. should be 4 - 8 ohms depending on the quality of the meter. Then measure between each lead and a good earth. Should be 'infinite', no short to earth. Any other reading would suggest a burnt winding shorting to the body of the stator.
Nick 50
PostPosted: 10:55 - 20 Sep 2011    Post subject: Reply with quote
Yep what sickup said Thumbs Up
It's quite a well known issue on that model of the VFR:
https://www.bikersoracle.com/vfr/forum/showthread.php?t=76159
Scooty
PostPosted: 12:17 - 20 Sep 2011    Post subject: Reply with quote
Cheers for the suggestions guys, will test the reg/rec again tonight, and try to fix the side stand switch.
Karma
sickpup
Old Timer
PostPosted: 22:03 - 20 Sep 2011    Post subject: Reply with quote
Karma
Theres nothing wrong with it.
Scooty
PostPosted: 09:22 - 21 Sep 2011    Post subject: Reply with quote
Karma
It should be able to start with the side stand down if it is in neutral, and it used to be able to. I think the switch is probably just a bit dirty and corroded from road filth, so hopefully stripping it, cleaning it and putting it back together will get it working again.
As to the rest of the issues, I bought some supplies from Maplins last night. Going to try and make my own earthing wires as discussed here:
https://www.vfrdiscussion.com/forum/index.php/topic/66045-urethra-i-found-it/page__st__30
SW Motech Shop UK
PostPosted: 17:55 - 24 Sep 2011    Post subject: Reply with quote
Have you checked the charging yet? be interested to know what the voltage is with the bike running and lights on.
I had a similar running issue with my 2000 VFR800 where the fuel pump was intermittently cutting out, turns out that was a faulty ECU. Took a risk and bought one on Ebay, sorted. Didnt have any effect on the charging system though. I would suggest your old battery woudnt hold a charge and you charging system is actually OK.
Just blown the rear shock on mine so its off the road again.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
Scooty
PostPosted: 08:48 - 26 Sep 2011    Post subject: Reply with quote
I've run all of the voltage checks. Bought a new battery for it recently, and seems to be holding charge well, even after been out riding. The R/R is the upgraded SH689DA version, but this was red-hot after a half-hour ride on Saturday. Might have to get a new one Sad
Scooty
PostPosted: 18:12 - 12 Jan 2012    Post subject: Reply with quote
Just an update - bike is still off the road due to this damn electrical issue that I still haven't managed to get to the bottom of. I've stripped out the earth block (https://www.vfrdiscussion.com/forum/index.php/topic/66045-urethra-i-found-it/page__st__30) and soldered the wires together, with a new wire running to the battery negative terminal.
As the sidestand switch was giving me issues, I just removed it and soldered the wires together - need to make sure I don't ride off with the sidestand down, but at least that is another possible issue crossed off.
Anyone have any ideas? I'd try and sell it, but I've dropped it, so don't think I'd get much for it Sad
https://www.bikechatforums.com/viewtopic.php?t=206463
sleepyboy
PostPosted: 20:48 - 29 Mar 2012    Post subject: Reply with quote
Vincent wrote:
I sorted my "cutting out" problem - it was the pink/black wire on the engine stop relay connector block - apparantly a common problem. I took the connector apart, cleaned up the spades, applied some contact cleaner and Bob's yer uncle Cool
I have similar symptoms to you - where is this connector?
Cheers, Paul
Bezzer
PostPosted: 21:48 - 29 Mar 2012    Post subject: Reply with quote
Didn't realise the Viffer had the same orange earthing block as the Blackbird, you won't find it on any wiring diagram, they just use it to set /test everything at the factory then it's taped up....badly.... never to see the light of day until the connections rot out.
Blackbird owners are advised to cut it off and hardwire it sooner rather than later to prevent problems, some people left it too long after first seeing the random FI light and ended up having to replace electrical items, one poor sod had to replace Reg/rec, stator and the ECU to get it sorted.
Mine went years ago and I ended up experimenting and writing the 'bird fix that's on the various owners forum.
https://www.bikersoracle.com/blackbird/forum/showthread.php?t=16438
Possible that this one has gone too far and affected other items.
The last post was made 14 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 101.91 Kb
