Braided or not? Standard or Race?
speedysi
PostPosted: 21:21 - 23 Sep 2011    Post subject: Braided or not? Standard or Race? Reply with quote
Is it worth changing my brake lines to braided? If yes race or standard 3 cable?
Thanks
1999 CBR 600F😄
Theory Test passed 15/08/2011👍. Off Road passed 20/09/2011👍. On Road passed 5/10/11👍
PostPosted: 21:51 - 23 Sep 2011    Post subject: Reply with quote
Depends on the condition of the hoses on there. Main advantage is that it forces you to bleed the brakes properly.
As to 2 hose or 3 hose, makes no difference other than cost. 2 hose kits are cheaper, but the only reason they are referred to as race style is because some race rules do no permit the brake hoses to split below the bottom yoke.
whitedevil
PostPosted: 00:00 - 24 Sep 2011    Post subject: Reply with quote
You'll get much better results from servicing your callipers and fitting new pads, seals, fluid and properly bleeding the system. I'd only fit braided hoses if the hoses there now are perished.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
herulach
PostPosted: 00:15 - 24 Sep 2011    Post subject: Reply with quote
Are the original hoses still on it?
The fazer is the same age and the brakes feel insanely better with braided hoses - you could feel the old ones expanding when you pulled the lever.
YBR 125>FZS600
herulach
PostPosted: 00:54 - 24 Sep 2011    Post subject: Reply with quote
Rob Fzs wrote:
Shocked can't wait to swap um on mine
Do it. mine felt like they were in desparate need of bleeding (despite having about a litre of fluid through them over the course of 2 or 3 weeks. Still stopped, but new hoses are like night and day.
YBR 125>FZS600
PostPosted: 01:35 - 24 Sep 2011    Post subject: Reply with quote
I upgraded mine from the originals on a 1999 bike. Probably the best thing I have done to the bike. I have 2 lines from the front master cylinder and they do make a big difference. I also done the rear.
I'm guessing on newer bikes the difference isnt as noticable but after 12 years on the bike the OEM parts were due replacement anyways.
PostPosted: 08:32 - 24 Sep 2011    Post subject: Reply with quote
Not so sure. Changed some on the GPZ500 we had that were 18 years old. Made no difference. Think a hell of a lot comes down to the particular lines and how well bled the system is. Charlottes 900 Thunderbird has braided lines as stock and the brakes regularly go spongy. Problem there is the twin pot sliding calipers that need a regular strip down and clean (which is a doddle of a job on those calipers, nice thing about sliding calipers).
A few years ago I measured how much the outside of the hoses of a few of the bikes expanded when pulling the lever hard. Ones that expanded the most were the braided lines on the Triumph. The (at the time) 13 year old rubber lines on the RS125 expanded nothing like as much.
Either way, if you change them it is very important to make sure you route them to avoid rubbing on anything. Braided steel hoses will wear through and damage things fairly easily, and also as they do not have a thick rubber protective covering they are more easily damaged (then this happens).
rac3r
PostPosted: 12:06 - 24 Sep 2011    Post subject: Reply with quote
Apart from my 125 all the bikes I've had already had them fitted so I don't know the difference Laughing The Ducati's have them as standard Cool
Chequered Flag
Slacker24seve...
PostPosted: 12:12 - 24 Sep 2011    Post subject: Reply with quote
Made a huuuuuuuge difference to the Hornet, although to be fair I did fit some EBC pads too. Wink
Banger rallies are ace
DrDonnyBrago
PostPosted: 15:52 - 29 Sep 2011    Post subject: Reply with quote
If I was an honest man I would say that I fitted braided lines because the originals looped over a lot and made bleeding a pain in the ass.
However I am not so instead I will say they do make quite a nice difference to the feel of the brakes and that this is the sole reason I replaced my rubber hoses with rusty fittings for some shiny braided ones.
PostPosted: 15:55 - 29 Sep 2011    Post subject: Reply with quote
I got braided purely down to price, were going cheap on ebay.
Cant really tell if there is a difference, I was practically riding without front pads before... so unsure if braking has been significantly improved Laughing
The last post was made 15 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 75.79 Kb
