isopropyl alcohol alternative.
Tom85
PostPosted: 21:23 - 23 Sep 2011    Post subject: isopropyl alcohol alternative. Reply with quote
Well i'm going to brave replacing my rim tape tomorrow and want something to clean the sticky stuff off left over from my old rim tape. I've been told the best thing is isopropyl alcohol, problem is i can't get hold of any. Could i just use meths or something similar or will this damage the finish on my wheels?
mattress
PostPosted: 21:32 - 23 Sep 2011    Post subject: Re: isopropyl alcohol alternative. Reply with quote
Any PC repair shop should have some for sale. If you still can't get any, try the suggestions on the site below:
https://tipnut.com/25-helpful-items-to-remove-sticky-adhesive-goo/
PostPosted: 21:42 - 23 Sep 2011    Post subject: Reply with quote
Maplins sell it
https://www.maplin.co.uk/search?criteria=isopropyl+alcohol
Triumph Trophy Launch Edition
PostPosted: 21:57 - 23 Sep 2011    Post subject: Reply with quote
Depends on the finish. Try a chemist, ask for rubbing alcohol. Failing that, meths, white spirit, petrol or acetone based nail varnish remover - I used that on my GPZ, probably not the best choice but it was the closest to hand and didn't harm the finish.
Nope.
PostPosted: 22:09 - 23 Sep 2011    Post subject: Reply with quote
WD40 works brilliantly for removing sticky gunk. Spray some on a cloth and then rub it on the gunk. If it doesnt remove it straight away, spray it directly onto the gunk and then rub. That should remove it all.
Then use water to get rid of the WD40 and dry it off.
c-m
PostPosted: 23:52 - 23 Sep 2011    Post subject: Reply with quote
Hmm WD40 is oil based so you'll then need an water based de-greaser to remove the WD40.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
ClockworkJesu...
PostPosted: 01:11 - 24 Sep 2011    Post subject: Reply with quote
Especially as WD40 stands for Water Displacer - 40th Attempt. Rolling Eyes
Tom85
PostPosted: 08:31 - 24 Sep 2011    Post subject: Reply with quote
I've got some meths in the garage so i'll give that a go on a little spot and leave it a while see how it goes. Cheers.
PostPosted: 10:24 - 24 Sep 2011    Post subject: Reply with quote
What's wrong with a petrol-soaked rag? A long-forgotten service-shop essential.
cyberglass
PostPosted: 12:42 - 24 Sep 2011    Post subject: Reply with quote
As above. To much over thinking going on here a bit of petrol on a rag will take the shite off. Dry it off and stick the tape on. Thumbs Up
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
c-m
PostPosted: 17:00 - 24 Sep 2011    Post subject: Reply with quote
Especially as WD40 stands for Water Displacer - 40th Attempt. Rolling Eyes[/quote]
Lol i meant oil-based de-greaser
The last post was made 14 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 70.42 Kb
