| Dragox2011 |
 Dragox2011 L Plate Warrior
 Posted: 00:35 - 24 Sep 2011 Post subject: New biker needs help with wiring problems :S |
Hello All,
I passed my CBT just under a month ago and got myself a nice 125cc bike called a Lifan Earth dragon 125-gy3.
My friends dad adjusted the free play on my rear brake and also adjusted the rear brake light so it would come on at the correct pressure.
Until now everything has been working perfect besides a few loose screws here and there. But a few days ago the brake light stopped working for the rear brake.
Both filaments intact and working perfect. Front brake activates the light and but the rear brake doesn't. I've tried adjusting the spring thing on the rear brake arm, and completely taking it off and pulling by hand but i just cant get the light to come on.
I did look at the front of the bike, and noticed a wire snapped of a little black box which is below.
https://www.chinesemotorcyclepartsonline.co.uk/partno_31215-PR08_1617_LF125GY-3.php?i=LF125GY-3
I re-attached the cable temporarily to see if that was the problem but still nada.
Below is the wiring diagram for my bike, the top right is the section im looking at but it just confuses me. The section cut off the left is just the gear indicator.
IMG_20110924_011754.jpg:https://imageupload.org/thumb/thumb_110291.jpg
This is a big problem if i cant get it fixed soon as i need it for Uni on monday
sorry for the wall of text and thanks in advance  |
| ClockworkJesu... |
 ClockworkJesu... Nitrous Nuisance
 Posted: 01:16 - 24 Sep 2011 Post subject: |
First off, Chinese bikes can have nasty switches. Try bypassing the switch if you can, see if that helps.
Also, the thing that stopped a light on my scooter from working, was that the Earth cable had broken -somewhere- on its way back to the battery. So, we cut the cable short and stuck it under a bolt against the frame to earth it. Light worked after that. So, see if its an Earthing problem.
otherwise, may be a fuse problem?
Edit: Just had a peek at the diagram and, whilst I'm no electrician, it could easily be a fuse.  |
| andy_uk |
 andy_uk World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:43 - 24 Sep 2011 Post subject: |
I really would recommend that you get a multimeter. You can get one for £7.49 from Maplin, for example. It'll take all the guesswork out of it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Dragox2011 |
| Dragox2011 |
 Posted: 16:05 - 24 Sep 2011 Post subject: |
Switch was naffed. £4 for a new one from local honda dealer  |
| ClockworkJesu... |
 Posted: 16:08 - 24 Sep 2011 Post subject: |
| Dragox2011 |
 Posted: 18:14 - 24 Sep 2011 Post subject: |
Thanks for the help all fitted and ajusted now and working brilliantly  |
The last post was made 14 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
