Bandit 400 Earth/Ground Point?
HD
PostPosted: 13:09 - 24 Sep 2011    Post subject: Bandit 400 Earth/Ground Point? Reply with quote
So a while back I found that there are two wires that I labelled that go to the battery. Now I've been rebuilding it I have three wires left to attach. Battery positive, battery negative and, err ... battery negative.
One is quite long so I am thinking its an earth but why would I label it as a battery negative? I'm guessing the shorter negative is for the battery as is the short positive but anybody got any idea where this wire goes or where the earth point is?
If anyone has a bandit 400, can you shed some light please Mr. Green
Help much appreciated Thumbs Up
HD
PostPosted: 19:51 - 24 Sep 2011    Post subject: Reply with quote
BUMP
Any ideas then guys? Or earthing points on other bikes? (especially bandit 600's?)
bombom
PostPosted: 22:36 - 24 Sep 2011    Post subject: Reply with quote
im going to be striping the carbs off mine tomorrow depending on the weather and il have a look for your bud see if i can see
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
HD
PostPosted: 22:47 - 24 Sep 2011    Post subject: Reply with quote
Ahh that would be ideal bud, thanks. If you can, would you be able to get a pic or two? Or is that taking the Piss a bit?
bombom
PostPosted: 19:28 - 25 Sep 2011    Post subject: Reply with quote
right from what i could see there was 2 wires going to the battery negative terminal (both crimped together in the square block that screws to the battery terminal)
tried to follow both wires, one went into the main relay and the other from what i could see disapeared into the loom.
as foor the pics, sorry i have built it all back together now lol plus my fones camera is pretty rubbish anyways
sorry i cant be much help
Current: 97 zx6r f3
at106
PostPosted: 20:03 - 25 Sep 2011    Post subject: Reply with quote
I cant help much but if you have a wiring diagram for the bike it should be quite obvious which wires go where. There may be one in the manuals section in this forum Thumbs Up
HD
PostPosted: 20:25 - 25 Sep 2011    Post subject: Reply with quote
I've got a manual pdf for it which is helpful but I'm shit with wiring diagrams. If I upload it, would one of you be able to interpret it for me?
And bombom, yeah I have those wires. One is short so I imagine that is the one you are on about that disappears.
The other one I have that I don't know what does is long. Now that is labelled battery negative but is quite long. But what I am thinking is does it go to the battery and then back into the loom then to the main relay (do you mean starter relay, indicator relay, starter motor, regulator? Confused )
That a good theory?
I mean I want to try and work it out before but if worst comes to worst, I'll just wire it up and the worst thing that can happen is it will blow a fuse, right?
But it had electrical problems so I want to limit the amount of things it could be, for instance just a component, rather than this random wire as well.
Cheers for the help though, gents Thumbs Up
orac
PostPosted: 20:30 - 25 Sep 2011    Post subject: Reply with quote
Hey man, just had a read, one will be the frame earth and the other will be loom earth. it alos possible that an extra wire has been added as a feed for the reg/rec if there were charging issues
at106
PostPosted: 20:33 - 25 Sep 2011    Post subject: Reply with quote
That a good theory?
If you upload the manual then i may be able to help
orac
PostPosted: 20:43 - 25 Sep 2011    Post subject: Reply with quote
i got a PDF manual but it takes an eternity to upload. If you want to to limit any issues that may arrise, unplug everything (specially the ingnition controller). once confirmed not to blow then plug each thing in one at a time swithcing the ignition on and off between each until everything is plugged in - simple fault finding can be used ot avoid excess damage in cases like this
and HD you have been speaking to me recently on another well known site owned by google
HD
PostPosted: 20:46 - 25 Sep 2011    Post subject: Reply with quote
Yeah thats pretty much what I have.
Mines just cleaner though Laughing
Nearly 300 pages so I don't know if it would upload anyway.
EDIT: Oh right, grapes?
And never tried that before. I'll just plug everything in and see if it starts, then I'll try eliminating problems one by one.
Buying a new reg/rec and battery anyway so hope that sorts out any issues.
And think thats the same pdf as I have haha!
orac
PostPosted: 21:31 - 25 Sep 2011    Post subject: Reply with quote
Yeh that was a scan of the manual i have, i had completely forgotten about the PDF on my array..
and i would try only connect what need to be first, so the starter and relay, ignition switch, ignition controller and the right hand switch gear - that all you need, once you know that works do the rest on at a time testing as you go
HD
PostPosted: 20:09 - 27 Sep 2011    Post subject: Reply with quote
We've got a picture of a wiring diagram, can someone tell me where the fucking wire goes? Laughing Laughing
orac
PostPosted: 21:28 - 27 Sep 2011    Post subject: Reply with quote
well the ideal situation would be to have labelled and photographed it before taking it apart. and i can garantee that no one can tell you were it goes , they may be able to hazard a gues.
but by the sound of thing you havent don much work on bikes in the past. like i said you have to have a wire attatched to the frame as there ae many idems that ground through the frame.
oh and most people wont even hazard a gues with the bike in front of them. and you havent posted a pick like previously requested si its impossible to even think about guessing
at106
PostPosted: 22:07 - 27 Sep 2011    Post subject: Reply with quote
Can you trace the wire to where it comes from?
HD
PostPosted: 23:14 - 27 Sep 2011    Post subject: Reply with quote
It disappers into the loom and I don't fancy breaking it all apart :/
orac
PostPosted: 23:21 - 27 Sep 2011    Post subject: Reply with quote
well if its definatly and earth, just bolt to the frame, use the reg/rec bolt of you like - that if its definatly and earth. like i said the frame should be earth to the negative terminal of the battery.
this is a simple problem that any budding engineer/bike tech would be able to solve fairly easily. along with all the documantation you made when taking the thing apart
serlant
PostPosted: 23:49 - 27 Sep 2011    Post subject: Reply with quote
one is a frame earth, the one thats not black with a white stripe. Black with a whipe stripe / other / i expect the longer one is the earth for the lighting system as the b/w goes to all the lights aswell as the speedometer.
Edit: so one goes to an earth on the frame the other goes to a black wire with white strip(it says tracer)which should be loose somewhere around the battery i'd expect.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
The last post was made 14 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 95.53 Kb
