| sunnyj58 |
 sunnyj58 Two Stroke Sniffer
 Posted: 21:34 - 25 Sep 2011 Post subject: Lights problems.. |
Hi all,
Heres my problem..
Last night I start riding the bike after it sat idle for about 2 weeks. The lights come on at first, then the front light goes off after a few seconds. I turn the highbeams on and they are then ok for the next minute before they to go off.
Note, at this point I didnt check the backlights was working..
So today, I thought it was just the front light bulb, so I went got a new one put it in and put the 3 seperate wires back in and the front light works, just very dull.
Then tonight I get pulled over by police who say my backlights are not working..
So, I take the cover off the bike, and If I take one of the 3 wires out, the front light goes off, but the backlight now works. If I take all 3 wires out, backlight works fine. Ive found some combinations of putting wires where, the front light works on normal but backlight doesnt, then if I put highbeams on, the front goes off and the backlight comes on.
Does anyone have any idea what could be wrong? |
| orac |
 orac World Chat Champion
| Teflon-Mike |
 Posted: 22:08 - 25 Sep 2011 Post subject: |
It sounds like a duff earth. Volts on headlamp earth being higher than volts on tail lamp, resitance of bulbs higher than resistance through corroded earth, so volts take line of least resistance.
BUT; would help to know what bike; and as suggested likely to not be aided by weak battery and low revs. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| MickC |
 MickC Spanner Monkey
 Posted: 22:11 - 25 Sep 2011 Post subject: |
| orac wrote: | sounds like got a corroded terminal or something.
it may sound daft but try charging the battery, small bike (i dont know what your riding) depend heavily on the battery for the lights, and most even need input from the altenator too |
Also try tracing the earth wires, do you have a multimeter?. If so check the wiring to see if its shorting out somewhere. As 'Orac (how's Blake doing?)' said bad connections or terminals.
EDIT; Teflon beat me to it ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| sunnyj58 |
| orac |
The last post was made 14 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
