Lights problems..
sunnyj58
PostPosted: 21:34 - 25 Sep 2011    Post subject: Lights problems.. Reply with quote
Hi all,
Heres my problem..
Last night I start riding the bike after it sat idle for about 2 weeks. The lights come on at first, then the front light goes off after a few seconds. I turn the highbeams on and they are then ok for the next minute before they to go off.
Note, at this point I didnt check the backlights was working..
So today, I thought it was just the front light bulb, so I went got a new one put it in and put the 3 seperate wires back in and the front light works, just very dull.
Then tonight I get pulled over by police who say my backlights are not working..
So, I take the cover off the bike, and If I take one of the 3 wires out, the front light goes off, but the backlight now works. If I take all 3 wires out, backlight works fine. Ive found some combinations of putting wires where, the front light works on normal but backlight doesnt, then if I put highbeams on, the front goes off and the backlight comes on.
Does anyone have any idea what could be wrong?
orac
PostPosted: 22:00 - 25 Sep 2011    Post subject: Reply with quote
sounds like got a corroded terminal or something.
it may sound daft but try charging the battery, small bike (i dont know what your riding) depend heavily on the battery for the lights, and most even need input from the altenator too
Teflon-Mike
tl;dr
PostPosted: 22:08 - 25 Sep 2011    Post subject: Reply with quote
It sounds like a duff earth. Volts on headlamp earth being higher than volts on tail lamp, resitance of bulbs higher than resistance through corroded earth, so volts take line of least resistance.
BUT; would help to know what bike; and as suggested likely to not be aided by weak battery and low revs.
MickC
PostPosted: 22:11 - 25 Sep 2011    Post subject: Reply with quote
Also try tracing the earth wires, do you have a multimeter?. If so check the wiring to see if its shorting out somewhere. As 'Orac (how's Blake doing?)' said bad connections or terminals.
EDIT; Teflon beat me to it
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
sunnyj58
PostPosted: 22:40 - 25 Sep 2011    Post subject: Reply with quote
Thanks for advice.
Its on a piaggio zip 2t.
Just took another look, and noticed that.. When I turn the highbeams off and the light comes on, the backlight IS actaully on, just REALLY dim.
Also I did notice when the highbeams are on, so the backlight is working its flickering slightly like when the bike is running of the alternator and not battery. I checked the fuse near battery thats fine.
So im wondering is it possible that the new headlight bulb is taking to much power? Im not 100% sure its the right one for the bike.
orac
PostPosted: 22:50 - 25 Sep 2011    Post subject: Reply with quote
take the head light bulb out and then see what the the tail light does, if it does the same then its not headlight issue, if it fixes it then its the opposite.
if its not the headlight the wiring will need to be checked.
dunno, not spoken to him since liberator was destroyed.
PS i have never seen much of blakes 7, orac became my handle after a friend saw a PC a built and said it looked like orac
The last post was made 14 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 50.01 Kb
