Bike tyres
FirebladeRuss
PostPosted: 09:32 - 26 Sep 2011    Post subject: Bike tyres Reply with quote
Whilst bumbling up the A3 today at my usual 50-55mph (it's all the bike will do comfortably!), it dawned on me that having a tyre blow out on a motorbike would be pretty disasrtous.
Has anyone suffered from this before? Are bike tyres designed to withstand catastrohpic failure?
......after that jolly thought, i went back to whilstling the tune that I woke up to at 6am this morning.
Twitter is for people who can't STFU even when they're by themselves
garth
PostPosted: 10:49 - 26 Sep 2011    Post subject: Reply with quote
I've had a rear go down at 120 two up and 140 solo, and I'm still alive.
PostPosted: 10:53 - 26 Sep 2011    Post subject: Re: Bike tyres Reply with quote
Rear tyre generally is fine.
Front tyre leaves you a lot more to worry about.
I've been going along the M4 at under triple figure speeds (shan't say how much under Wink) and not noticed for a while that my rear was entirely flat.
FirebladeRuss
PostPosted: 11:36 - 26 Sep 2011    Post subject: Reply with quote
Well, that's concouraging! Very Happy
sickpup
Old Timer
PostPosted: 00:20 - 27 Sep 2011    Post subject: Reply with quote
Had a front delamination and blow out on a GSXR1100 at speed on the M1 or possibly the M6, can't remember which it was so long ago.
DrDonnyBrago
PostPosted: 11:04 - 27 Sep 2011    Post subject: Reply with quote
You should probably bear in mind that you are only hearing from the survivors Thumbs Up .
iooi
PostPosted: 11:16 - 27 Sep 2011    Post subject: Re: Bike tyres Reply with quote
Well there was a thread about this very subject not long ago......
Someone had the front blow out.....
PostPosted: 11:19 - 27 Sep 2011    Post subject: Reply with quote
Indeed, craig's granddad (who had been to some BCF rides I think) was killed when his front tyre suffered a blow out.
Believe he hit the barrier in the central reservation.
I've had plenty of flat front tyres riding off road, but everything's a bit different then.
ians238
PostPosted: 01:23 - 29 Sep 2011    Post subject: Reply with quote
I've had both go flat at speed, wasnt nice, like riding on marbles with a tankslapper and drifting the back out all at the same time, both feet down easing it to a stop, change of pants required at that point,,
I bought two pilot power tyres and had them fitted by a very reputable bike shop in south Glasgow, went about ten miles up the motorway at 60 and both went flat, bike was like jelly, pulled in walked the bike to the nearest garage and blew them up, turned out they werent put on the bead right. put 80 psi in both and let them down to the right pressure wasnt a problem after that.
needless to say I dont like pilot tyres. not sure what a blowout would be like though I wouldnt want to try it.
rtho782
PostPosted: 07:03 - 29 Sep 2011    Post subject: Reply with quote
Front blew out on the M4 at the end of august this year.....
ER-6f was a write off, I'm mostly OK now except that my shoulder dislocates now and then.
I posted a thread about it at the time.
c-m
PostPosted: 08:37 - 29 Sep 2011    Post subject: Reply with quote
Had a front tyre blow out on the Autoroute at 80mph. Front the looks of it, the metal banding in the tyre failed. The tyres lost pressure, then overheated blowing a massive hole on the tyre.
It was all a bit of a non--event though. All that happened was that the steering got very heavy then the head of the bike shook violently, but it was easy enough to slow down and pull over.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
sickpup
Old Timer
PostPosted: 19:25 - 29 Sep 2011    Post subject: Reply with quote
If they weren't on the wheel correctly and allowed air to escape you wouldn't have got to the end of the street let alone 10 miles away.
The last post was made 15 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 73.15 Kb
