Repositioning rear shock
LustyLew
PostPosted: 13:55 - 26 Sep 2011    Post subject: Repositioning rear shock Reply with quote
Hi all,
recently purchased an MT-03.
When The bike was originally owned by quite a short guy, so he had an after market shock fitted and had this further modified to bring the bike down lower.
Looking at the shock, it appears to have been drilled to allow the bike to sit lower to the ground. The swing arm also appears to have been filed/ground slightly to allow for clearance of the shock in its new position.
I'm not too concerned about the swing arm as it's only a minor mod.
However, if I were to move the pivot point back to the original location on the shock, would this be a risk of snapping due to the hole drilled?
I've not yet taken the shock off to see if both holes are as manufactured, or done by the previous owner/mechanic.
Any thoughts?
Pics attached.
Thanks!
PostPosted: 14:10 - 26 Sep 2011    Post subject: Reply with quote
I wouldn't be happy with it, keep an eye out for a shock on Ebay.
https://www.ebay.co.uk/itm/YAMAHA-MT03-MT-03-660-2006-REAR-SHOCK-ABSORBER-C18-/190435047534?pt=UK_Motorcycle_Parts&hash=item2c56d0386e
Thumbs Up Thumbs Down
The Artist
PostPosted: 15:01 - 26 Sep 2011    Post subject: Reply with quote
CHR15 wrote:
thats dodgy as fuck.
+1
sickpup
Old Timer
PostPosted: 20:15 - 26 Sep 2011    Post subject: Reply with quote
Why are there two bolts through the shock bottom? It looks like the previous owner may have also made a bit of a mess of the swing arm as well as the fork.
https://www.bikechatforums.com/download.php?id=80556
PostPosted: 20:22 - 26 Sep 2011    Post subject: Reply with quote
I was going to ask that. They can't both be bolted through the arm surely?
PostPosted: 20:24 - 26 Sep 2011    Post subject: Reply with quote
+1 for the swingarm looking dodgey as well.
I'd have run a mile after seeing that mod!
Mikey CB500
Ones just a rubber blank off by the looks of it
PostPosted: 20:27 - 26 Sep 2011    Post subject: Reply with quote
In the other pic it looks a bit like a blind grommet, but far from certain.
If it is 2 bolts going through the shock and arm then I hate to think what has been done.
LustyLew
PostPosted: 21:08 - 26 Sep 2011    Post subject: Reply with quote
Hi,
yes the shock & swing arm are only connected through the right hand bolt.
The left is just a grommet...
The swingarm has not been drilled in any way.
PostPosted: 21:20 - 26 Sep 2011    Post subject: Reply with quote
LH-ER5 wrote:
Hi,
That's not the end of the world. Try an pick up an Ohlins unit if they stock them, for added bling.
The last post was made 15 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 65.29 Kb
