| BLOWerMEat |
 BLOWerMEat Borekit Bruiser
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 17:21 - 27 Sep 2011 Post subject: |
Information gains better answers.
My guess. Your friction plates are worn.
Other guesses will follow.
[edit] If Kickstart answers don't read it. He's a wrong 'un.  ____________________ Diabolical homemade music Bandcamp and Soundcloud
Last edited by Howling TerrorOutOfOffice on 17:33 - 27 Sep 2011; edited 1 time in total |
| Kickstart |
 Kickstart The Oracle
 Posted: 17:28 - 27 Sep 2011 Post subject: |
Even with very worn plates I would expect more resistance than in neutral.
Take the front sprocket cover off and check that the output shaft is actually turning. It is possible for the teeth to wear away totally so the chain just slips on the sprocket, and also for the splines on the sprocket to wear out.
Also possible that the clutch is wrongly adjusted and stopping it working. Not sure on the SRAD, but on earlier GSXRs the cable goes to the sprocket cover, and there is a small adjuster screw under a cover there as well. It this is tightened up then it will push on the clutch operating rod whatever you do with the cable (even disconnecting it).
| Gazdaman |
 Gazdaman I did a trackday!!!
| BLOWerMEat |
 Posted: 18:35 - 27 Sep 2011 Post subject: the bike being a 97 gsxr 600 that is not stolen. |
The sprockets are good I just changed them and that might lead me to suspect the clutch pin maybe it the clunking part Im not sure Ill go test it and see. thanks to all who can give me their helpful wisdom.  ____________________ u cant phase me you people who ( Cant Understand Normal Thinking.)s |
| BLOWerMEat |
| BLOWerMEat |
| Kickstart |
The last post was made 14 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
