clutch problem?
BLOWerMEat
PostPosted: 15:01 - 27 Sep 2011    Post subject: clutch problem? Reply with quote
the bike rolls like its in neutral through all the gears . do I need a new clutch or is it a bigger problem?
u cant phase me you people who ( Cant Understand Normal Thinking.)s
PostPosted: 17:21 - 27 Sep 2011    Post subject: Reply with quote
the bike
Information gains better answers.
My guess. Your friction plates are worn.
Other guesses will follow.
[edit] If Kickstart answers don't read it. He's a wrong 'un. Razz
Last edited by Howling TerrorOutOfOffice on 17:33 - 27 Sep 2011; edited 1 time in total
PostPosted: 17:28 - 27 Sep 2011    Post subject: Reply with quote
Even with very worn plates I would expect more resistance than in neutral.
Take the front sprocket cover off and check that the output shaft is actually turning. It is possible for the teeth to wear away totally so the chain just slips on the sprocket, and also for the splines on the sprocket to wear out.
Also possible that the clutch is wrongly adjusted and stopping it working. Not sure on the SRAD, but on earlier GSXRs the cable goes to the sprocket cover, and there is a small adjuster screw under a cover there as well. It this is tightened up then it will push on the clutch operating rod whatever you do with the cable (even disconnecting it).
Gazdaman
I did a trackday!!!
PostPosted: 18:23 - 27 Sep 2011    Post subject: Reply with quote
Does it 'clunk' into gear properly?
Has the chain snapped and come off?
Is it literally no more resistance when in gear than without? Or is there some resistance, just not as much as there should be.
As Keith said, check the front sprocket, see if it's turning, and see if the chain's gripping the teeth properly.
Gaz
BLOWerMEat
PostPosted: 18:35 - 27 Sep 2011    Post subject: the bike being a 97 gsxr 600 that is not stolen. Reply with quote
The sprockets are good I just changed them and that might lead me to suspect the clutch pin maybe it the clunking part Im not sure Ill go test it and see. thanks to all who can give me their helpful wisdom. Very Happy
BLOWerMEat
PostPosted: 19:37 - 27 Sep 2011    Post subject: Reply with quote
Gaz
It clunked one time and then its hard to even get it out of nuetral now .
BLOWerMEat
PostPosted: 19:38 - 27 Sep 2011    Post subject: Reply with quote
Gaz
when I was pushing it home last night it felt like there was no difference when it was in any gear.
PostPosted: 22:43 - 27 Sep 2011    Post subject: Reply with quote
I would guess that it is the clutch pushrod then. Possibly not seated correctly when you put the sprocket cover back on after changing the front sprocket.
The last post was made 14 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.92 - MySQL Queries: 13 - Page Size: 59.76 Kb
