piaggio typhoon 50 2003
rsssutton4ros...
PostPosted: 15:07 - 27 Sep 2011    Post subject: piaggio typhoon 50 2003 Reply with quote
can any one help me? iv owned my 2003 typhoon now for about 6 months and its been fine, just the last month its started smoking a lot wen i start it and wen i take off its like theres not enought fuel getting through and no power then after about 10 seconds of full throttel the smoke clears up and the power comes back. its been derestriced and has a viper exhaust. also have tryed up jetting but after buying a 6mm jet the thread was rong (would not fit) so got a 5mm one and was too small. any help would be great thanks Very Happy
can i have sum luck???
at106
PostPosted: 17:26 - 27 Sep 2011    Post subject: Reply with quote
Take the spark plug out and see what colour it is, that'll tell you if it's jetted correctly.
The problem with power could be that the autochoke isnt working correctly. If you have a haynes manual it'll tell you how to test it.
rsssutton4ros...
PostPosted: 20:34 - 27 Sep 2011    Post subject: Reply with quote
the spark plug is dark (nearly black) and dry, also iv heard that the standard jet size is round 50-56? the jet allready on is a 72.
at106
PostPosted: 20:48 - 27 Sep 2011    Post subject: Reply with quote
It sounds ok. Its most likely the choke.
rsssutton4ros...
PostPosted: 19:27 - 28 Sep 2011    Post subject: Reply with quote
is all sorted with the power just un pluged the choke run it for 2mins then pluged back in and now runs fine. all i need to do now is sort out the smoke, its smoking a lot of blue smoke wen i open the throttle and doesnt seem to clear up after 100 or so yards (can see the cloud in mirrors Question ) does anyone know how to sort it please??? and thanks at106 for the help Very Happy
rsssutton4ros...
PostPosted: 20:02 - 28 Sep 2011    Post subject: Reply with quote
forgot to mention the sparkplug is still black an a bit sooty but a little bit wet (more damp really??)
at106
PostPosted: 21:24 - 28 Sep 2011    Post subject: Reply with quote
It's most likely running slightly rich. Have you changed anything like the oil brand recently? If it only smokes for the 1st 100 yards then i wouldnt worry.
rsssutton4ros...
PostPosted: 21:48 - 28 Sep 2011    Post subject: Reply with quote
no havent changed the oil or nothing, it started off smoking for only 100 or so yards but now constantly smokes. went for a ride today and after 5 minuets it was still smoking??
Livefast123
PostPosted: 21:56 - 28 Sep 2011    Post subject: Reply with quote
If the plug is dark and sooty then it's running rich, the plug should be a nice coffee colour. A main jet 20 sizes over the normal size sounds slightly excessive, maybe try a 65.
Excess smoke could be down to the oil pump needing adjusting, if thats possible on that bike. The fact thats it's running rich anyway isn't going to help the situation with the plug getting carbonised. I'd also check your airfilter is clean as a dirty one will make it even richer.
Current ride - Yamaha MT-07
rsssutton4ros...
PostPosted: 13:17 - 29 Sep 2011    Post subject: Reply with quote
hi thanks to all who helped me!! iv fitted a pm air filter and all seems fine for now if not you will here from me soon lol!!
Livefast123
PostPosted: 16:30 - 29 Sep 2011    Post subject: Reply with quote
Thats because it was running far too rich and the induction filter has leaned the mixture out.
You'll still need to do a plug chop with a new plug to check what the mixture is like.
at106
PostPosted: 17:05 - 29 Sep 2011    Post subject: Reply with quote
If you've fitted the filter to a standard 50cc engine you wont notice any gain in performance and you'll be using more fuel. If you wanted better fuel economy you'll need to refit the standard filter and fit a smaller jet and you wont loose any performance.
rsssutton4ros...
PostPosted: 22:14 - 29 Sep 2011    Post subject: Reply with quote
hi i think im going to keep the bike like it is for the moment, it seems fine now everythings sorted plus i need a bike to get to and from work for a copple of weeks then im getting a tzr125 or yzf. Very Happy
The last post was made 14 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 74.77 Kb
