| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 21:27 - 28 Sep 2011 Post subject: Query Regarding Gears |
Now I'm querying over something here to what I've been taught and what I've been told.
Basically when you are approaching a junction say it has a red light in second, which are you meant to do (I was always taught method 1 by the way and that is the method I normally use)
Method 1: Slow down and drop into first whilst stopping and then go again when it is green.
Or
Method2: Slow down and stop stay in second and then go again when it is green.
Only asking as I was speaking to a person at uni today and he said he always stays at second and never drops to first.. he only uses first when he has started his engine after neutral obviously.
Also if he stalls he would start his bike on first (cbr) and never touch neutral... now he may be talking through his Ass (which is what I'm assuming) but just wanted ask on here for confirmation. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| anthony_r6 |
 anthony_r6 World Chat Champion
 Posted: 21:29 - 28 Sep 2011 Post subject: |
First gear is for pulling away. The guy at uni is on drugs. ____________________ a.k.a 'Geri'
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 21:39 - 28 Sep 2011 Post subject: |
Hes a douchebag. Ignore him. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| Mehty |
 Mehty Spanner Monkey
 Posted: 22:13 - 28 Sep 2011 Post subject: Re: Query Regarding Gears |
| P.addy |
 P.addy Red Rocket
 Posted: 22:21 - 28 Sep 2011 Post subject: |
I never use neutral Pointless gear on my bike
Erm, I've accidentally pulled away in 2nd and 3rd on the CBR... gearbox is a bit funky... so it knocks down 5 gears but doesnt infact change the gear.. just makes the clonking noise. Think i'll have to have a look at it soon
Pull away in 1st anyway... |
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:30 - 28 Sep 2011 Post subject: |
There's no right or wrong way to ride, and your retarded uni friend's idiotic method is just as valid as the sane technique that anyone with an ounce of common sense would use.
Consider the merits of taking advice from someone who still stalls their bike often enough to have a plan for dealing with it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Mehty |
| TheSmiler |
| Alex_B |
 Alex_B Brolly Dolly
| pinkyfloyd |
 pinkyfloyd Super Spammer
 Posted: 07:36 - 29 Sep 2011 Post subject: |
| anthony_r6 |
| Kwaks |
 Kwaks I'm not a fast rider
 Posted: 08:00 - 29 Sep 2011 Post subject: |
Just to throw a spanner in the works, I am very disapointed in all you who stated they stopped in first. Why not just do it properly, stop in second then change to first ready to make off, whilst being in the correct gear should the lights change as you approach  ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
| P.addy |
 P.addy Red Rocket
 Posted: 08:11 - 29 Sep 2011 Post subject: |
When you stall your clutch may have a switch in it... which is why holding the clutch and thumbing the starter should work.
I know my CBR one was disconnected as it has an MX clutch lever which has no switch, I just joined the wires  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:25 - 29 Sep 2011 Post subject: |
| TheSmiler wrote: | Roger remember the famous saying "By failing to prepare prepare yourself to fail". |
I prefer "By doubting your strengths, you only give strength to your doubts."
https://t3.gstatic.com/images?q=tbn:ANd9GcTTIbjKfWZ0LGtgHuRlmkBZc8mWFhW4jChz6H_ZW6JrtAj2maBsOq8KaZBvZg
OK, seriously, only you can decide the right thing for yourself, based on your preference, experience, and bike characteristics. ____________________ Biking is 1/20th as dangerous as horse riding.
| pinkyfloyd |
| P.addy |
 P.addy Red Rocket
| Mehty |
 Posted: 09:52 - 29 Sep 2011 Post subject: |
| P.addy |
 P.addy Red Rocket
| Kwaks |
 Posted: 12:49 - 29 Sep 2011 Post subject: |
| pl3ppp wrote: | | Kwaks wrote: | Just to throw a spanner in the works, I am very disapointed in all you who stated they stopped in first. Why not just do it properly, stop in second then change to first ready to make off, whilst being in the correct gear should the lights change as you approach  |
Because then you'v gotta keep the bike up with your right leg, while you change gear then swap legs. Not only do you look funny, but pretty sure i was taught to keep my right leg on the bike - just in case a car decides to go up the right hand side a little too close  |
yet you are doing it properly, like every other vehicle on the road, only engaging first when stationary. Also helps with those bikes which resist going into first when moving.Also allows you to sit in neutral waiting on the traffic, preferable to holding the clutch in.
the actual correct procedure is to stop in second,change to neutral,swap holding leg to cover rear brake,wait for change,swap leg and engage first and move off.
btw, if A car moves up your right close enough to hit you leg you might want to start a thread about road position, that advice would only apply to a cyclist riding in the gutter, not a bike who dominates his road position OR a bike that has filtered alongside a stationary vehicle ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
| Recluso |
 Recluso Brolly Dolly
 Posted: 20:49 - 29 Sep 2011 Post subject: |
I've always been taught/told to pull away from stationary in first. There's been the odd occasion where I've not dropped it out of second and it's taken an arse ton (tonne?) of revs to get the YBR away. That and it sounds like it's about to backfire with its 'putt putt putt' as it goes xD
Regarding the slow down, 9 times out of 10 I usually stop in second, flicking it down to first before I put my left foot down. I think. It's something like that. Come to think of it, even I'm not sure what I do... but it's something like that!
I don't think I'd ever pull away in second intentionally unless it was a slow down toward lights that I was praying were about to change and just tootling on when they do  ____________________ 'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900 |
The last post was made 15 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
