| chris-red |
| P.addy |
 P.addy Red Rocket
| chris-red |
 Posted: 11:56 - 29 Sep 2011 Post subject: |
| ##Paddy## wrote: | Sorry if this makes you sound dumb, but on side stand, is the handle bar turned also. If so tight cable/not correctly run.
On the stand and leaking fuel. If you can find where its leaking from exactly, could be float bowl gasket/o ring has perished slightly. But the bowl should stop filling, so would assume float isnt actually operating properly and closing it off. |
It's not the throttle cable it isn't instant either, there is about 5-10 seconds lag then it starts over reving you pick it up and in about 5-10 seconds it goes back to normal.
TBH if it wasn't leaking I would probably leave it, it aids the warm up. Unfortunately as the leak is gradual I haven't been able to trace it.
It did set the float height up when I cleaned the carb, maybe it got knocked or needs it set lower. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| P.addy |
 P.addy Red Rocket
| chris-red |
| m3-paul |
 m3-paul Spanner Monkey
| cb1rocket |
 cb1rocket World Chat Champion
The last post was made 14 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
