Optimate 4, any good? + Queries
demon9374
PostPosted: 19:24 - 30 Sep 2011    Post subject: Optimate 4, any good? + Queries Reply with quote
Looking at some reviews, but do any of you guys use them? Any good?
7 week ago I got hit by a car and my insurance have had my bike all that time whilst lending me a scooter. Anyhow from my understanding, it got fixed on week 6, so it's been stood I bet all that time without a charge/being ran.
(RS 125 I'm talking about).
Anyhow, since getting it back, I've had nothing but starting problems. This morning I went to start her up to go work, button did nothing, then a tiny bit of life, but didn't start, so had to bump start. My daily work commute is about 24 miles, guessing not enough for the rectifier to charge it fully, but it doesn't top it up enough for when I finish my 2 hour shifts and come home, albeit the starting sounds very weak, but does start atleast, so as I said, I'm guessing after getting to work, there's enough charge for coming back home, but after a night of no use it's just dead basically, although (as inaccurate as they are) the display shows 11-12v so it's not completely flat..
So yeah, thinking of getting one of these chargers, would you recommend them? Before they took the bike, she started first time everytime perfectly, so I doubt the start motor has gone as all it's probably done is sat there in the workshop for 6 week which leads me to believe the battery has lost some charge.
On the topic of charging, I'm thinking of selling the bike, they're too much hassle for me and getting a 4 stroke YZF R125, would I be best off keeping the charger or selling it on with the RS?.. Does the YZF need to be frequently run to keep a good charge?
PostPosted: 20:02 - 30 Sep 2011    Post subject: Reply with quote
I would say, presuming the charging circuit is OK, you battery is goosed. You would be better getting a new one before an optimate. Knackered batteries cause all sorts of wonderful problems with modern bike electronics.
Triumph Trophy Launch Edition
demon9374
PostPosted: 20:13 - 30 Sep 2011    Post subject: Reply with quote
Seems abit wierd it would be goosed, was fine before insurance took the bike away, can't have just gone like that whilst in their care, unless they've pissed on it Laughing Surely it's just lost some charge & a charger will bring it back & keep it maintained, found an Oxford one which is on par with the Optimate for £29.99, dunno what to do. Then again, wouldn't I need to charge a new battery anyways? I am currently without a charger, only charger I can borrow is a car one, which is no good.
swampy
PostPosted: 20:19 - 30 Sep 2011    Post subject: Reply with quote
I agree with battery being goosed.
I would expect it to be charged over a 24 mile ride to at least a point where it would start 2 hours later (the engine would barely have cooled by then). Have you got a multi meter ? Could be worth checking the state of play with that rather than forking out on a charger...
demon9374
PostPosted: 20:36 - 30 Sep 2011    Post subject: Reply with quote
Oops, didn't make it clear, I do 2 hours in the morning, 12 mile round trip, 2 hours at teatime, 12 mile round trip again. Not a continuous 24 mile ride.
Set off at 6.20am work 7-9, come home, out again at 4.20pm 5-7
Upon thinking about it, in total, I think it's nearer 17 miles I do in a day. Never really go out on her on days like today, never feel in the mood for it, just go to work on it lol
I've never got round to buying one, gramps has one, but I don't think it shows voltages, loads of settings, but nothing I understand on it to find a setting for "Show me teh voltage" lol
johnsmith222
PostPosted: 21:01 - 30 Sep 2011    Post subject: Reply with quote
Anything that says DC with numbers? you'll want to set it to the lowest number you can that is above 12. On mine it is 20.
J4mes
PostPosted: 21:08 - 30 Sep 2011    Post subject: Reply with quote
It'll have a symbol like this on it normally
https://t3.gstatic.com/images?q=tbn:ANd9GcQAwbEj3BD10sqcEElUCufLuJuWde4xIFYBArkUzrA_EE0uFlod0h3unRrd
Measure the battery while you turn the starter over, this will give you a true representation of the condition of the battery.
jimspeed
PostPosted: 22:30 - 30 Sep 2011    Post subject: Reply with quote
maybe someone at the repair place needed a battery Confused it happens especially if its been sat there for 6 weeks in a corner of the yard.
I have a ring smart charger which cost £24 i think and can be left permanently connected etc.
A car charger will be ok just set it on the lowest setting and don't leave it connected all night unless its a smart type.
I would sort it sooner rather than later as you are putting a lot of strain in the charging system with a completly flat battery (plus its having to run lights etc too).
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
demon9374
PostPosted: 22:32 - 30 Sep 2011    Post subject: Reply with quote
Cheers, will go down tomorrow & have a ganders at it.
Again although the display isn't accurate, whilst riding the volt reading shoots down to 12-13 from 14.3 when I either use brakes or put lights on, not sure if that's right or not. Eitherway I'll give it a shot tomorrow.
Whilst I'm here, is it called Redex? It's on offer in Wilkinsons, cleans fuel, carbs etc, dunno if it's worth picking any up, says add half to 50 ltrs of fuel, so I'm guessing I only want to use the tiniest smidge, was only thinking about it as bike is alittle boggy setting off at the lights, have to pump clutch and feather the throttle abit unless I get above low rpm. Could be jets etc, but I thought I could save hassle & see if this Redex would clean em out for me, think it's £2.47 down from £4.95
Again though, if I got a new battery, would I not need a charger still anyways? If so, wouldn't it be best getting the charger, seeing if it sorts my current battery out before buying a new battery first?
Edit, from memory, although it was quite some time ago, it looked liek this one..
https://www.tecpel.com/Multimeters/Dmm_80072.JPG
I'm guessing top right quarter "V" and set to 20? Providing it's the same and has not other values between 12 & 20, also set to DC, if it has that option that is.
swampy
PostPosted: 22:38 - 30 Sep 2011    Post subject: Reply with quote
Anecdotally, Redex does precisely bugger all to be honest, although you may notice a placebo effect.
Fair point on the charger, you will probably need one if you buy a new battery, so cant think of a reason not to get one and give your existing battery a try.
I would keep it if you sell the bike though, always handy to have.
Edit for your edit.
You want to set it to this:
https://i1098.photobucket.com/albums/g378/swmpy50/Dmm_80072.jpg
Looking for over 12v at rest, should be 14.5v ish when bike running.
demon9374
PostPosted: 22:39 - 30 Sep 2011    Post subject: Reply with quote
Just saw this after posting, his car charger has no settings at all and I've tried it on a previous RS's battery, didn't do much good lol
I'll see what the verdict is tomorrow then order something lol
jimspeed
PostPosted: 22:41 - 30 Sep 2011    Post subject: Reply with quote
Ok I'm guessing a bit here, your bike has a volts display on the dash yea ?
whats happening is the charging system is just about managing to get the power up to 14.2 (good) then you are adding an extra 21w of load (the brake light bulb) which is then dropping the voltage down as the alt cannot try to charge the battery AND run the lights and brake light. sounds like the battery is knackered to me really if its that bad but yea a charger would be handy anyway as you said a new battery will be flat too.
REDEX , I dont think I would be happy running it thru a 2 stroke to be honest and you may find that sorting the battery problem will sort the flat spot too as there is more electrical power to run the coil etc.
demon9374
PostPosted: 22:47 - 30 Sep 2011    Post subject: Reply with quote
Good job I didn't get any then lol
Aye, well it's only £29.99 so wouldn't be any point trying to up the sale by including the charger, would only end up buying another in the future when things go wrong lol
Might aswell take carb out and give it a blast whilst I'm there & check what jets are in it, see if any can be replaced to get rid of the bogging/slow starts. Idle jet I'm guessing could be the culprit.
Choke does my head in, I ride with choke on for a while in the mornings, as I cba with hassle off neighbours warming a 2 stroke up, doing nothing wrong, but I can see it be an annoyance, so I just choke & ride away before he hangs out of the window yelling abuse. Anyhow, choke, whilst riding, bike is very, dunno the word.. croaky and doesn't pull well?
demon9374
PostPosted: 22:51 - 30 Sep 2011    Post subject: Reply with quote
Ah yeah fair point, I'm not too knowledgable on bikes, forgot all about coil etc, I've stripped my previous RS's carb (28mm are horrible!!) and sorted out that bike, didn't run well at all, would bog and die straight away, but sorted it all with help from some awesome guys on here. Sold it though as it needed some tlc & needed new piston & rings by the looks of the compression reading lol, guy only went on to try & sell it for £1300, I sold it for £700, same I paid for the shit heap lol
The last post was made 14 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 88.51 Kb
