What should you expect from a rear drum brake on a 125?
EazyDuz
PostPosted: 19:54 - 01 Oct 2011    Post subject: What should you expect from a rear drum brake on a 125? Reply with quote
Marauder in my case.
I dont know if its me being paranoid or the back brake just isnt very good.
Me and Tef removed the drum and the brake pads themselves have plenty of life so i can rule that out.
Here is the problem. If i change the position of the brake actuator to the left (or clockwise on the spindle) the brake will bite sooner. But say if i set the actuator and the brake adjustment screw on the cable itself so its set up with no pedal slack, and i press the brake pedal, i dont get much strength from the brakes.
They work but i can push the pedal about 80% down and in that 80% there is some power, but the last 20% is where most of the brake power comes from, but thats with me pushing down on the pedal quite hard.
I cant screw the adjustment screw any further because if i do the brakes start to bite. I tested this when the bike was on axle stands and i can feel when i roll the wheel freely that they do start to bite, i probably wouldnt notice if the wheel was on the ground though. Is that how you should judge it? Because i dont want them biting slightly all the time while im riding, ill lose power and wear the pads out...
Is that just how drum brakes are? Or should they instantly be able to lock the back wheel if you press firmly on the pedal? Because mine just doesnt...
Thanks
Teflon-Mike
tl;dr
PostPosted: 21:44 - 01 Oct 2011    Post subject: Reply with quote
Yes.
I adjusted it up for you how it OUGHT to be; Ie very small movement before they bite, then rest of pedal actually applying pressure.
BUT you diddn't like the feel, and had me back it off, as you like it more progressive. trouble is that means that the lever is working in a more perverse portion of travel, where the leverage is against you.
The 'problem' is the erganomics of your bike, and where the (bent) brake pedal sits, that we didn't have time to look at.
Messing about with the lever, getting the 'stop' set right, and bending the actual pedal to a more useful possition for YOUR erganomics is where you need to start.
THEN you can return to the cable & arm and set that up so it starts 'biting' early in travel with the lever ratio decreasing so more pedal movement gives less pad travel and more force.....
PS: I got a half garbled txt message off you on my 'phone today, when I checked it and found that the wall socket the charger is in is 'duff'..... said 'text missing' and something about £80 for a Pirelli Tyre?!? Thought you had that fitted, before you got the wheel straightened? There was something about tappets too?
If you want to pop over and play spanners; you are welcome; I have plans for tomorrow though, and my kids next weekend so it will have to be in the week.
Snowie has a big crow bar and a hammer; sure she'd LOVE to assist 'straightening' your brake pedal Wink
Shielder
PostPosted: 21:56 - 01 Oct 2011    Post subject: Reply with quote
My back brake is pants too. Came in very handy on the Mod 1, no way in hell I was going to be able to skid with that! It does work, but you have to really press hard on it.
If you're anything like me, most of the braking is done on the front anyway (don't tell me CBT instructor though!) it's only when you are really going slowly that you need to use it I reckon.
Andy
CBT - 22/10/08 & 30/5/11, Theory - 13/06/11, Mod 1 - 26/9/11, Mod 2 - 29/9/11
'00 Suzuki Intruder VL 125 (06/06/09 - now)
EazyDuz
PostPosted: 22:38 - 01 Oct 2011    Post subject: Reply with quote
Teflon-Mike wrote:
Yes.
No i didnt like the feel because if the weight of a feather landed on the pedal, the wheel pretty much locked up lol.
What i dont understand is how did you set it like that without the brakes biting slightly on the wheel without the brake being applied? Or was it biting slightly? I guess no one would know unless you spin the wheel freehand when it is elevated...
The text about the tyre is about a week old, the second text is from today. Yea i will be able to make it some time during the week, maybe monday?
Thanks
Teflon-Mike
tl;dr
PostPosted: 23:08 - 01 Oct 2011    Post subject: Reply with quote
See, THAT is how GOOD it COULD be!
But yes; you're a newbie, and a bit of a clod-hoppingly clumsy one, and its a tail-endy cruiser you will have to use more back brake on, which was why I was happy to back it off....
'sharp' brakes offer power, but if you dont apreciate the fact that the react quickly or have the delicate 'touch' to balence braking, can be more of a dissadvantage, than an advantage.
Need to find a happier 'medium'.
No, it was 'free'.... but I had the brake arm rotated round so it was 'off' the cable when the shoes were on the flats; then when the wheel went in, and the cable connected up, it pulled up the 'free' travel, before the shoes bite.
The 'problem' with your brake is that the actuation cam expanding the shoes against the drum is near 45 degrees when its biting, which means its giving most shoe movement for least lever movement, and lever is nearing virticle to cable so gioving most lever movement per mm of cable travel, making it all rather fearce...
Setting up from the front end, getting pedal in the right place for you is the starting point, then working through; and we MAY have to 'shim' the shoes, packing the faces, to lift them closer to the drum, with the cam closer to horezontal, so that they are 'biting' in the region where it takes more pedal travel to get the same movement..... BUT wont know till we get there.
OK; well it was all chopped up and said 'some text missing'...
Monday ought to be OK; don't think I have anything on; Have lad Wednesday after school. But Snowie wont be able to come 'guide' you from the Hinkley Knight; she's 'grounded' at the mo due to unforseen 'problem'....
EazyDuz
PostPosted: 23:23 - 01 Oct 2011    Post subject: Reply with quote
But that is how i set mine up today but it didnt have the same affect as when you did it. I set the brake adjustment screw so tight that it was about 1 turn away from biting the brakes, so therefore any force on the lever should engage the brakes to some extent, but even set up like that i could still push the lever quite far down with minimal braking...
So you are saying when you set them really strong, the actuator was set at around 7 o'clock? Well mine right now is set between 6 and 7 oclock and then adjusted using the cable screw so with no brakes applied it is at about 6 o'clock, adjusted any tighter and the brakes engage slightly, but even then, if i push the pedal down i dont get all that much brake power, why?
Also i'll be lost without Snowie the sat nav :/
The last post was made 15 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 57.71 Kb
