Scottoiler, how often do they need filling?
Marmalade
PostPosted: 19:00 - 04 Oct 2011    Post subject: Scottoiler, how often do they need filling? Reply with quote
looking at getting a scottoiler for the XT and wondering if it'd be worth me getting the high capacity touring model as i've been doing a couple of hundred miles a day regularly on it.
How many miles do you get out of a fill?
oh, and can you fill it with any old junk, like used engine oil?
Fisty
PostPosted: 19:11 - 04 Oct 2011    Post subject: Reply with quote
Depends on many many things, single ar dual injectors, flow rate you set it at, viscosity of the oild you use, temperature, blah blah blah.
I fill mine with ATF oil from work and fill it up when it runs out. Buy one, fit it and enjoy your prolonged chan life.
Fatter and faster than Fret
Marmalade
PostPosted: 19:18 - 04 Oct 2011    Post subject: Reply with quote
Single injector. 10/40 used oil. getting a bit chilly now
Fisty
PostPosted: 19:27 - 04 Oct 2011    Post subject: Reply with quote
I get roughly 1000 miles out of mine. But that is a rough guess. If you are using old engine oil it shouldnt matter a stuff how long you get between fills as it only takes a matter of seconds to do.
Marmalade
PostPosted: 19:34 - 04 Oct 2011    Post subject: Reply with quote
Thats ok. I was thinking it might be 400 miles and could need doing every day on some occasions and it'd do my head in.
Might look for the touring kit so i just top it up once a week
Fisty
PostPosted: 19:40 - 04 Oct 2011    Post subject: Reply with quote
I bought a second hand setup off egay(sic) for £15 and it has served me well on 3 bikes over 4 years now. I wouldnt pay full price for a new one at the mo.
Chriss
PostPosted: 20:19 - 04 Oct 2011    Post subject: Reply with quote
Hi,
If like mine it's actually quite inaccessible (under the front seat) then the follow should give you a few ideas.
https://www.xrv.org.uk/forums/attachments/bodgers-corner/2858d1226672980-diy-scottoiler-bottle.jpg
https://www.xrv.org.uk/photopost/data/500/medium/DSCN0741.JPG
I used a fairy washing up liquid bottle, for what it's worth, the black tubing fits nicely in the top of the bottle, bit of epoxy and a hole for the air to go in and job's a good 'un!
I do happen to have a high capacity reservoir too, and my biggest complaint is you have to remove the number plate to top it up. It's also so long between top ups I forget to actually check it.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
robocog
PostPosted: 20:33 - 04 Oct 2011    Post subject: Reply with quote
Mine (std sized reservoir) seems to need filling about every 3rd fill up (so 500/600 ish miles) on the GPZ500
I do however have a slightly annoying drip that continues after the ignition is turned off ...and I have started to leave small patches where I park up despite me stripping and cleaning the unit and replacing the delivery tube
"engine off" drip patch size does vary- this mornings was a bit of an impressive slick...then after my luchtime sammich run it only left a 10p sized blob by hometime
Currently running a 50/50 blend of chainsaw oil (testing the low fling properties) and used (but filtered through a spray paint filter) engine oil - which is also a blend of 10/40 and 5/30 from the fleet that litters the driveway and garden (I may have chucked some fork oil in there a few times as well)
I have placed my reservoir pretty much vertical next to the heatsink attached to the regulator recifier to try and keep it a consistant temp (though is possibly made of fail due to the length of fairly exposed tubing)
I'm currently not getting /much/ fling or splatter from this mix and the chain is certainly "wet" with lube (not bothered counting 1 drip every 2 mins with my "new blend" yet)
I should possibly turn the drip rate down a tad...but I am not coating my tyre with the stuff and it looks like I pretty much have a lifetime free supply even at this high rate
Regards
Rob
Needs a bigger garage...
Marmalade
PostPosted: 20:39 - 04 Oct 2011    Post subject: Reply with quote
Just lost one on ebay despite bidding £22 on it.
There's no more ending for 2 days. Have to keep on spraying it with lube
yen_powell
PostPosted: 21:30 - 04 Oct 2011    Post subject: Reply with quote
A dripping scottoiler is usually a knackered one way valve. The small rubber L-shaped bit that connects to the carb vacuum take off. They are cheap so just replace it.
If you put the oil reservoir where you can see it then you can turn it to a lower setting if you think you are using it up too fast. My last one was actually in the fairing next to the clocks.
Everyone I know personally that had the numberplate touring pack never got it to work properly.
XT1200Z and a DR350 in bits
robocog
PostPosted: 22:08 - 04 Oct 2011    Post subject: Reply with quote
Don't forget to search for "scotoiler"
IIRC mine was a single "t" typo'd bargain
Can see one on there now at £20 buy it now (admittedly without tubing)
The vac and feed tubing can be sourced from a scrappy or a car spares place
feed tube is the same as windcreen washer tube and the vac tube and a 90 degree elbow can be sourced from under the bonnet of certain modern cars - despite the death of vacc operated advance/retard dissys from the 70's/80's- narrow bore hard plastic tube (PTFE?) seems to still be in flavour for vac operated solenoids and EGR valves and such decades later
(the "nibs" that dispense the oil to the sprocket is also the same stuff)
Regards
Rob
Marmalade
PostPosted: 22:16 - 04 Oct 2011    Post subject: Reply with quote
I've got it on my watching list but would rather pay another fiver to have it arrive on my doorstep with all the pipes and bits.
robocog
PostPosted: 22:35 - 04 Oct 2011    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Classic-Advance-Retard-Vacuum-Tube-Hose-Pipe-BMC-Ford-/270776637573?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0b8b9885
plus
https://www.ebay.co.uk/itm/WASHER-JET-TUBE-TUBING-1-8-3mm-PIPE-/310226753547?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483af4980b
will almost leave change for a mars bar from your fiver (to be consumed whilst adjusting the drip rate?)
There may even be someone doing it cheaper off the roll locally to you?
I bought my new feed pipe from Halfords and cannot recall how much I paid...wasn't silly expensive tho
Regards
Rob
DrDonnyBrago
PostPosted: 07:45 - 05 Oct 2011    Post subject: Reply with quote
Mine lasts about 1000 miles but you can DIY a high capacity reservoir. Basically secure a bottle to your bike, fill it with oil and route the filler tube/air breather pipe from the top of the scottoiler into the bottle of oil.
i.e. the sauce bottle:
EDIT: I didn't read the above posts, I have been beaten to it.
shereen
PostPosted: 07:54 - 05 Oct 2011    Post subject: Re: Scottoiler, how often do they need filling? Reply with quote
https://www.ebay.co.uk/itm/scottoiler-good-used-condition-/120787201903?pt=UK_Motorcycle_Parts&hash=item1c1f7a6f6f#ht_500wt_1282
mistergixer
PostPosted: 08:12 - 05 Oct 2011    Post subject: Reply with quote
Tip: if you have an issue with your Scottoiler, contact their technical support department - I bought a second hand one from eGay a few years ago, it dripped a bit when the bike was standing, no matter what I did to adjust it.
I spoke to one of their tech-support chaps, and he gave me a few things to try - when these didn't fix the problem, he told me to send it up to them to look at.
They replaced about 90% of the components and shipped me back a fully working oiler......for free!
Space Monkey #7
Marmalade
PostPosted: 15:17 - 09 Oct 2011    Post subject: Reply with quote
Just blagged a complete kit with high capacity touring reservoir for £35 on ebay.
Nobody else bid on it Very Happy
yen_powell
PostPosted: 17:05 - 09 Oct 2011    Post subject: Reply with quote
If you are going to greenlane the XT then it might be better to point the outlet at the front sprocket rather than the rear as they get torn off by ruts/vegetation.
Marmalade
PostPosted: 18:45 - 09 Oct 2011    Post subject: Reply with quote
I was thinking that.
The rear sprocket might be a bit open for it. It'll be hidden behind the frame somewhere and piped securely.
stonesie
PostPosted: 19:18 - 09 Oct 2011    Post subject: Reply with quote
It might be made of fail, the reg/rec get's bloody hot, the frame behind mine on the sv does anyway and it's working just fine.
Try touching that heatsink after rideing for half an hour or so (wet your finger first, no you won't get an electric shock unless the R/R is fecked)
robocog
PostPosted: 20:57 - 09 Oct 2011    Post subject: Reply with quote
Congrats on the oiler setup Marmalade
If your bike has one of those plastic chain guide thingies on the swing arm I reckon something could be added to drip oil in there somewhere - and could be made pretty robust for little effort/cost
anyway I have managed to fix my leaky issues
dunno what I did differently this time
stripped it down completely (again) , gave it all a good clean internally, gave the spring under the diaphragm a bit of a tug (lengthened it by a cm or so) popped it all back together set it up as 1 drip every 2 mins...engine off ....hey presto no more leaks
(took longer to initially prime than it usually does from empty so maybe my spring or valve had become unseated ?)
Went to the Brightonia doo today, when I came back to my bike several hours later I was pleasently surprised to see no oil had dripped (ok there was literally about 1 drip mark from under the front sprocket..but none from the rear where the dispenser nozzle sits)
Checked the levels in the reservoir when I got back and its hardly used any at all - it has dropped , but not by much
Will double check its /still/ set to roughly 1 drop every 2 mins when I get time this week
could be on target for the quoted circa 1000 miles between fill ups Smile
Regards
Rob
The last post was made 14 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 120.06 Kb
