| 2-stroke madness |
 2-stroke madness Two Stroke Sniffer
 Posted: 21:49 - 05 Oct 2011 Post subject: Aprilia rs carb setup? |
hi there, im currently having a full engine rebuild on my rs 125 extrema 1994, reasons for this i seized it, it was running fine, power was great, then one night out it started to 'bog/fail' out at about 11,000, and over a period of a few days, this got worse and the point of 'bogging' out lowered in rpm, eventually only letting me rev to about 3500 rpm, i then changed the plug and it let me run it for a while, still not getting to 12,000 though, nd after about half an hour it clonked out on me, and wouldnt start again for sure, sstripped the engine and this is what i found, i dont have any idea what caused this, mixture? jets? spark plug? im running a std airbox with 34mm VHSB, 153 main jet, iridium br9eix plug, also when i stripped the engine, the main bearings were knackerd, big end gone and small end gone. i just want to make sure this doesnt happen again with my new engine any ideas would be very helpful, thanks ____________________ live life to the max.... Buy a 2-stroke |
| Kickstart |
 Kickstart The Oracle
 Posted: 10:47 - 06 Oct 2011 Post subject: |
Forget trying to hit 12k. The red line is at 10750 which is also pretty close to peak power. Revving further you will just be losing power rapidly while giving the engine a really hard life.
From the pictures difficult to tell. That is either most likely detonation (what is your ignition timing set to, and you do realise that an RS that old is set up to use high octane petrol as standard - 97 RON min), or a bit of piston ring / circlip has escaped and bounced around for a bit. Prolonged detonation might also explain the wrecked big and little end bearings (but revving it to 12k would likely accelerate their deaths as well).
If you are thrashing the bike and going to the red line regularly (let alone through the red line) then use a 10 plug. Stock is a BR10EG. Stock jetting for a 1993 bike is 155 main jet, 36 for "min jet", DP266 attomiser tube, K57 needle on the first notch and air screw 1.5 turns out.
| 2-stroke madness |
 Posted: 15:44 - 06 Oct 2011 Post subject: |
thanks for that ill be putting high octane in all the time now, and if i werent to thrash it all the time would a 9 plug be better?
and how can i find the ignition timing? and also where is the attomiser tube located
thanks alot ____________________ live life to the max.... Buy a 2-stroke |
| Kickstart |
 Posted: 16:06 - 06 Oct 2011 Post subject: |
The number with NGK plugs is the heat range of the plug, which comes mainly down to the amount of insulation around the inner electrode. The lower the number the hotter the plug (for colder running engines) with more insulation, the higher the number the colder the plug (for hotter running engines) with less insulation. A spark plug has a limited range that it works properly in, and if it gets too hot it will blister and fail, while if it doesn't get hot enough it will foul up (and fail). Fouled plug is a pain (but easy to carry a spare).
A 10 is standard and fine normally, but if you are doing lots of low speed riding it won't get hot enough to burn off the build up of carbon on it and will foul up. The 9 should avoid this but might blister and fail if thrashed.
The ignition timing is set by the position of the stator under the flywheel. To alter it you need to remove the flywheel. To check it you use a dial gauge. There is a small hole in the flywheel which matches up with a notch in the stator at the point used for setting the static timing. You use a suitable size pin to lock the flywheel to the stator at this point and check the crank position compared to tdc using the dial gauge (from memory it is a 1.8mm before TDC, but don't rely on that figure without checking it). Basically you get the engine to tdc (there is a bolt under the engine to remove and replace with a longer one to lock it at TDC) and set up the dial gauge. Then remove the bolt and turn the crank back until you can lock the flywheel to the stator and check the dial gauge reading there.
Attomiser tube is in the carb, in the middle of the float bowl. Part number 3 in the following diagram:-
https://www.dellorto-carbs.co.uk/graphics/del16.jpg
| 2-stroke madness |
| Kickstart |
| 2-stroke madness |
 Posted: 23:05 - 06 Oct 2011 Post subject: |
Thankyou for all the advise again
do you reccomend anything when i am running my new engine in, im going to try a 158 main instead of a 155 and fiddle about with the air screw, run it on high octane and expensive 2stroke oil... any more suggestions? ____________________ live life to the max.... Buy a 2-stroke |
| Kickstart |
| 2-stroke madness |
| Kickstart |
| P. |
 P. Red Rocket
 Posted: 09:54 - 07 Oct 2011 Post subject: |
Not going against God's posts above..
But
What I did with my RS was a completely new top end/barrel and main bearings. I ran that until about 250miles around 5000rpm. After that I started pinging it up to around 7k/8k every now and then, but sitting around 5k normally. Did that until about 450 miles then started opening it up a lot more.
After about 500 miles, was riding as per normal, thrashing the crap out of it, and it was perfect... felt like a totally new bike  |
| Kickstart |
| 2-stroke madness |
| Kickstart |
| 2-stroke madness |
 Posted: 13:10 - 07 Oct 2011 Post subject: |
okay thanks still use a 9 or 10 plug? and what do you think to the iridium ones compared to the standard ? ____________________ live life to the max.... Buy a 2-stroke |
| Kickstart |
 Posted: 13:13 - 07 Oct 2011 Post subject: |
With plugs fouling easily I would be inclined to say it is better to replace the plug twice as often rather than use one that could last twice as long.
The spark plug is there to cope with combustion temperature which shouldn't really depend much on air temp. So still stick to the one depending on how you are riding (although if it snows I doubt you will be thrashing it )
| 2-stroke madness |
 Posted: 13:42 - 07 Oct 2011 Post subject: |
haha i know im gonna be killing my self if i dont get a good ride out on it, engine should be back with in a 8-9 days, its up at ARD racing in newcastle
getting full piston kit inc conrod and barrel aswell, so cant wait to see what it can do  ____________________ live life to the max.... Buy a 2-stroke |
| Kickstart |
| 2-stroke madness |
| P. |
 P. Red Rocket
 Posted: 14:43 - 07 Oct 2011 Post subject: |
Just as a baseline, mine was a 2000 model, full arrow exhaust, power valve jammed open. Saw an indicated 102, but GPS showed 91. Which is still quick for a little 125  |
| 2-stroke madness |
 Posted: 14:55 - 07 Oct 2011 Post subject: |
thats not too bad would you sy its better to have the power valve jammed? personally i love that rush when it opens at about 7600rpm,
just cant beat it  ____________________ live life to the max.... Buy a 2-stroke |
| P. |
 P. Red Rocket
 Posted: 14:58 - 07 Oct 2011 Post subject: |
Still get the big power push at about 8k, just think it makes the mid range a little lacking, cant say it bothered me, was always in 50/70 zones, so was trying to keep high revs anyway  |
| Kickstart |
 Posted: 15:23 - 07 Oct 2011 Post subject: |
Mine is a 1993 bike. One of the first batch in the country (I was friendly with the local dealer, he collected it on a Wednesday and it was still in his van on the Thursday when I popped in - I got it out of the van to look at, then rang the next day to buy it). It is standard (well, other than a blown crank at the moment).
The power valve doesn't really give you top end power. That is down to the porting, exhaust, etc. The power valve just salvages some of the bottom end power to make it usable when otherwise tuned for top end power.
If you jam the power valve fully open you will have a hell of a lot more of a kick at around 7k~8k. You will also have stuff all go when moving off (makes moving off with a pillion on a hill a nightmare).
| P. |
 P. Red Rocket
| 2-stroke madness |
The last post was made 14 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
