Aprilia rs carb setup?
2-stroke madness
PostPosted: 21:49 - 05 Oct 2011    Post subject: Aprilia rs carb setup? Reply with quote
hi there, im currently having a full engine rebuild on my rs 125 extrema 1994, reasons for this i seized it, it was running fine, power was great, then one night out it started to 'bog/fail' out at about 11,000, and over a period of a few days, this got worse and the point of 'bogging' out lowered in rpm, eventually only letting me rev to about 3500 rpm, i then changed the plug and it let me run it for a while, still not getting to 12,000 though, nd after about half an hour it clonked out on me, and wouldnt start again for sure, sstripped the engine and this is what i found, i dont have any idea what caused this, mixture? jets? spark plug? im running a std airbox with 34mm VHSB, 153 main jet, iridium br9eix plug, also when i stripped the engine, the main bearings were knackerd, big end gone and small end gone. i just want to make sure this doesnt happen again with my new engine any ideas would be very helpful, thanks
live life to the max.... Buy a 2-stroke
PostPosted: 10:47 - 06 Oct 2011    Post subject: Reply with quote
Forget trying to hit 12k. The red line is at 10750 which is also pretty close to peak power. Revving further you will just be losing power rapidly while giving the engine a really hard life.
From the pictures difficult to tell. That is either most likely detonation (what is your ignition timing set to, and you do realise that an RS that old is set up to use high octane petrol as standard - 97 RON min), or a bit of piston ring / circlip has escaped and bounced around for a bit. Prolonged detonation might also explain the wrecked big and little end bearings (but revving it to 12k would likely accelerate their deaths as well).
If you are thrashing the bike and going to the red line regularly (let alone through the red line) then use a 10 plug. Stock is a BR10EG. Stock jetting for a 1993 bike is 155 main jet, 36 for "min jet", DP266 attomiser tube, K57 needle on the first notch and air screw 1.5 turns out.
2-stroke madness
PostPosted: 15:44 - 06 Oct 2011    Post subject: Reply with quote
thanks for that Smile ill be putting high octane in all the time now, and if i werent to thrash it all the time would a 9 plug be better?
and how can i find the ignition timing? and also where is the attomiser tube located
thanks alot
PostPosted: 16:06 - 06 Oct 2011    Post subject: Reply with quote
The number with NGK plugs is the heat range of the plug, which comes mainly down to the amount of insulation around the inner electrode. The lower the number the hotter the plug (for colder running engines) with more insulation, the higher the number the colder the plug (for hotter running engines) with less insulation. A spark plug has a limited range that it works properly in, and if it gets too hot it will blister and fail, while if it doesn't get hot enough it will foul up (and fail). Fouled plug is a pain (but easy to carry a spare).
A 10 is standard and fine normally, but if you are doing lots of low speed riding it won't get hot enough to burn off the build up of carbon on it and will foul up. The 9 should avoid this but might blister and fail if thrashed.
The ignition timing is set by the position of the stator under the flywheel. To alter it you need to remove the flywheel. To check it you use a dial gauge. There is a small hole in the flywheel which matches up with a notch in the stator at the point used for setting the static timing. You use a suitable size pin to lock the flywheel to the stator at this point and check the crank position compared to tdc using the dial gauge (from memory it is a 1.8mm before TDC, but don't rely on that figure without checking it). Basically you get the engine to tdc (there is a bolt under the engine to remove and replace with a longer one to lock it at TDC) and set up the dial gauge. Then remove the bolt and turn the crank back until you can lock the flywheel to the stator and check the dial gauge reading there.
Attomiser tube is in the carb, in the middle of the float bowl. Part number 3 in the following diagram:-
https://www.dellorto-carbs.co.uk/graphics/del16.jpg
2-stroke madness
PostPosted: 16:14 - 06 Oct 2011    Post subject: Reply with quote
thanks, ill have to check the timing when i get my engine back, but ive just checked my jets, its got a 155 main, 60 choke, and doesnt have a pilot jet, it has a jet that actually is sat inside the thread, about 10mm down... whats that all about?
PostPosted: 16:20 - 06 Oct 2011    Post subject: Reply with quote
60 choke jet / starter jet (the Italian translations can get to be a bit strange) is correct. Main jet is within the normal bounds
You can see the min jet as number 7 or number 8 on the previous diagram (not that it is that clear).
2-stroke madness
PostPosted: 23:05 - 06 Oct 2011    Post subject: Reply with quote
Thankyou for all the advise again Smile
do you reccomend anything when i am running my new engine in, im going to try a 158 main instead of a 155 and fiddle about with the air screw, run it on high octane and expensive 2stroke oil... any more suggestions?
PostPosted: 23:15 - 06 Oct 2011    Post subject: Reply with quote
The RS runs fairly rich as stock so is fairly safe. Although it you are using an aftermarket exhaust it might help (stock early RS exhaust isn't bad).
Running in I tend to do 500km at under 5000rpm then add 1000rpm every 100km. Probably a bit excessive though.
2-stroke madness
PostPosted: 06:11 - 07 Oct 2011    Post subject: Reply with quote
i heard about doing 2 heat cycles, then ride it normal but obviously no thrashing, instead of riding at the same rpm all the time which so ive read it 'doesnt get enough oil' to the engine... is ths theory correct?
thanks
PostPosted: 09:23 - 07 Oct 2011    Post subject: Reply with quote
Good question, and one I doubt few can answer on a carefully built new engine let alone one rebuilt.
Couple of heat cycles seems to normally be accepted for competition engines which will likely only have a single ring piston to bed in and where long engine life isn't really something they care about.
Formerly known as
P.
PostPosted: 09:54 - 07 Oct 2011    Post subject: Reply with quote
Not going against God's posts above..
But
What I did with my RS was a completely new top end/barrel and main bearings. I ran that until about 250miles around 5000rpm. After that I started pinging it up to around 7k/8k every now and then, but sitting around 5k normally. Did that until about 450 miles then started opening it up a lot more.
After about 500 miles, was riding as per normal, thrashing the crap out of it, and it was perfect... felt like a totally new bike Thumbs Up
PostPosted: 10:01 - 07 Oct 2011    Post subject: Reply with quote
Very similar to me, just marginally less distance (and on that I probably am being excessive). I just work in km as that is what the clock reads in.
2-stroke madness
PostPosted: 12:40 - 07 Oct 2011    Post subject: Reply with quote
thanks for the advice, also now the cold weather is coming in do you suggest anything that could help me keep my engine in tip top shape?
thanks
PostPosted: 13:05 - 07 Oct 2011    Post subject: Reply with quote
Warm it up properly before thrashing it (and watch out for the temp dropping when the stat first opens).
Otherwise just service it nicely and check for anything wearing out (inlet rubber cracking for example).
2-stroke madness
PostPosted: 13:10 - 07 Oct 2011    Post subject: Reply with quote
okay thanks Smile still use a 9 or 10 plug? and what do you think to the iridium ones compared to the standard ?
PostPosted: 13:13 - 07 Oct 2011    Post subject: Reply with quote
With plugs fouling easily I would be inclined to say it is better to replace the plug twice as often rather than use one that could last twice as long.
The spark plug is there to cope with combustion temperature which shouldn't really depend much on air temp. So still stick to the one depending on how you are riding (although if it snows I doubt you will be thrashing it Laughing )
2-stroke madness
PostPosted: 13:42 - 07 Oct 2011    Post subject: Reply with quote
haha i know im gonna be killing my self if i dont get a good ride out on it, engine should be back with in a 8-9 days, its up at ARD racing in newcastle
getting full piston kit inc conrod and barrel aswell, so cant wait to see what it can do Very Happy
PostPosted: 14:22 - 07 Oct 2011    Post subject: Reply with quote
As I am sure you are aware, with an RS125 what it can do is somewhat down to how accurate the speed is (or not).
Had 185kmh on the clocks on mine on level ground (115mph). As you can no doubt tell, that shows the speedo as being way out.
2-stroke madness
PostPosted: 14:29 - 07 Oct 2011    Post subject: Reply with quote
Haha i know what you mean, what years your rs? and what parts you running it with? airbox, carb, jets, exhaust, piston etc
Formerly known as
P.
PostPosted: 14:43 - 07 Oct 2011    Post subject: Reply with quote
Just as a baseline, mine was a 2000 model, full arrow exhaust, power valve jammed open. Saw an indicated 102, but GPS showed 91. Which is still quick for a little 125 Laughing
2-stroke madness
PostPosted: 14:55 - 07 Oct 2011    Post subject: Reply with quote
thats not too bad Smile would you sy its better to have the power valve jammed? personally i love that rush when it opens at about 7600rpm,
just cant beat it Smile
Formerly known as
P.
PostPosted: 14:58 - 07 Oct 2011    Post subject: Reply with quote
Still get the big power push at about 8k, just think it makes the mid range a little lacking, cant say it bothered me, was always in 50/70 zones, so was trying to keep high revs anyway Thumbs Up
PostPosted: 15:23 - 07 Oct 2011    Post subject: Reply with quote
Mine is a 1993 bike. One of the first batch in the country (I was friendly with the local dealer, he collected it on a Wednesday and it was still in his van on the Thursday when I popped in - I got it out of the van to look at, then rang the next day to buy it). It is standard (well, other than a blown crank at the moment).
The power valve doesn't really give you top end power. That is down to the porting, exhaust, etc. The power valve just salvages some of the bottom end power to make it usable when otherwise tuned for top end power.
If you jam the power valve fully open you will have a hell of a lot more of a kick at around 7k~8k. You will also have stuff all go when moving off (makes moving off with a pillion on a hill a nightmare).
Formerly known as
P.
PostPosted: 15:27 - 07 Oct 2011    Post subject: Reply with quote
Laughing Pulling away with a slightly tubby mate on the back was...and experience on a hill.
Definite kick up the arse at 8k, 100% Laughing
2-stroke madness
PostPosted: 16:08 - 07 Oct 2011    Post subject: Reply with quote
which ports do you think are best to polish? and ive heard its not a good idea to polish the inlet port to the piston?
The last post was made 14 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 134.84 Kb
