re frame a bike? legality?
Welshd1k
PostPosted: 17:59 - 10 Sep 2011    Post subject: re frame a bike? legality? Reply with quote
say i could get a cat b/a bike if i get anothr frame and V5 then i can swap it all over correct then inform dvla of engine change
Nexus Icon
PostPosted: 18:01 - 10 Sep 2011    Post subject: Reply with quote
You can re-bike a frame but re-framing a bike is more tricky. The identity of the bike is in fact the identity of the frame.
Hope that makes sense.
Greetings from Shitsville!
mad4it028
PostPosted: 18:17 - 10 Sep 2011    Post subject: Reply with quote
strictly speaking you cant do it because your using more than 75% or whatever % of another bike but in reality they cant proove that so just say you bought an engine and changed numbers with dvla
Welshd1k
PostPosted: 20:20 - 10 Sep 2011    Post subject: Reply with quote
Rob Fzs wrote:
mattspratt reframed his old r6 i think,thead on here somewhere
and that was a ringer.....
tbh the bike needs a frame / bodywork / forks but ti was V V vheap for what it was so i dont mind if it has to Q plate or w/e
MaybeGuy
PostPosted: 00:04 - 06 Oct 2011    Post subject: Reply with quote
Err... No it wasn't before you go saying shit like that.
New frame with V5 and reg number, sent the V5 off to the DVLA to get the engine numbers swapped.
It was a legit bike.
Cunt
Gazdaman
I did a trackday!!!
PostPosted: 10:20 - 07 Oct 2011    Post subject: Reply with quote
As above, I've reframed a bike before. The identity is with the frame, so as long as you keep the v5 for the frame, and the finished bike becomes the frame's reg.
Then send off the v5 with the new engine number, job's a goodun.
Gaz
weasley
PostPosted: 12:49 - 07 Oct 2011    Post subject: Reply with quote
Well you can't re-use any parts off of a Cat A bike (the whole thing must be crushed), and with Cat B you can only re-use serviceable, non-structural parts. Counts out things like subframes, swingarms, front ends etc.
PostPosted: 13:01 - 07 Oct 2011    Post subject: Reply with quote
Insurance categories is a strange area. It appears that the categories are assigned by the insurance companies with an attempt to make it seem like they are legally binding. However it appears that VOSA will often do a VIC check on a cat a or b vehicle which it will likely pass as it is mainly checking the id (ie, that it isn't a stolen car being given the write offs identity), and once that is done the DVLA will accept it.
Doesn't appear to be any legal backing behind what parts (if any) from a write off can't be reused.
PostPosted: 13:31 - 07 Oct 2011    Post subject: Reply with quote
Cant use forks from a cat b?!
Whoops Laughing
The last post was made 14 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 65.86 Kb
