Flushing Cooling System.
PostPosted: 12:41 - 12 Oct 2011    Post subject: Flushing Cooling System. Reply with quote
How would I go about this? The ZZR I'm sorting has scummy coolant, Is it worth flushing it through or would just changing it be ok?
steven_191
PostPosted: 12:48 - 12 Oct 2011    Post subject: Reply with quote
If you want to take the rad off flush it with a hose pipe. Otherwise fill it up and run it and drain it a few times. You can try disconnecting a pipe a putting a hose pipe on it but it won't flush everything. Restrictions like the pump might divert the water and only flush parts. Depends how thorough you want to be. And knowing you I would expect a call at the weekend asking me to come sort it for you.
Ill fix it with extra long bolts
StevenF
PostPosted: 12:50 - 12 Oct 2011    Post subject: Reply with quote
Been a while since I did it, but I'm sure I removed the hose which returns the fluid to the radiator, drained all the fluid out, opened the radiator cap and put a garden hose in it and let it all run through for a few minutes.
PostPosted: 13:17 - 12 Oct 2011    Post subject: Reply with quote
You can come help at the weekend if you want, Carbs are off ready to be cleaned. I worried about some gunge in the tank, have you got the rust stuff you used on your mito?
Fizzer Thou
PostPosted: 14:28 - 12 Oct 2011    Post subject: Reply with quote
There is quite often a lowest point from where the coolant can be drained,but whenever I have had to change coolant I have found that it was best to remove the radiator and to flush this seperately,as there may be debris still in the engine that might otherwise be washed back into the rad otherwise.
Always have a 'Plan B'
The last post was made 15 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 44.4 Kb
