Front brake rubbing/always on
_Troy_
PostPosted: 21:14 - 12 Oct 2011    Post subject: Front brake rubbing/always on Reply with quote
Evening all.
My GS500's front brake seems to have decided it wants to stay on. When wheeling the bike you can hear it rub and squeak, and when riding you can feel the difference, I think, it may mostly be psychological though.
When it comes to using the front brake, there is nothing much except full emergency stopping power (presumably because the rest of the braking power is already applied)
Is there a simply fix to this, a way to release the brake and perhaps reposition it a bit.
As always, any and all help appreciated as I need this bike every day, as it's my only form of transport.
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
Quote Me Happy
PostPosted: 21:20 - 12 Oct 2011    Post subject: Reply with quote
It sounds like the brakes need a bit of an overhaul. The first thing I'd try is pumping the brake pistons out a bit and trying to give them a bit of a clean up using some brake fluid with a tooth brush.
If that doesn't work I'd go for the full strip down, clean and new seals.
Ariel Badger
PostPosted: 21:31 - 12 Oct 2011    Post subject: Reply with quote
If it is rubbing it will create heat. Heat will boil fluids.
Ask Pete what happens if you boil brake fluid.
_Troy_
PostPosted: 21:42 - 12 Oct 2011    Post subject: Reply with quote
I shall do my best to give this a go in the weekend. Can't be too hard, can it? Very Happy
Dan79
PostPosted: 22:16 - 12 Oct 2011    Post subject: Reply with quote
One other test you might want to try, take the bike for ride for a couple or so miles, only need to ride at sensible speeds up to 30 or 40 should be okay, using bare minimal front brake, stop and feel (VERY CAUTIOUSLY) the front discs, with gloves hands initially. If they're still cool or close to ambient temperature to touch, the brakes aren't the problem; if they are hot, you've diagnosed likely brake seizure. If discs are hot, you should cease use of the bike until problem is rectified, not only for reasons of safety, also if you carry on riding a bike with brakes dragging, discs will be at risk of warping due to the heat.
Obviously don't try this test at high speed or over any distance, because if the brakes are seizing, the discs will get very hot indeed; not to mention danger of fluid overheating alluded to by Ariel Badger.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
_Troy_
PostPosted: 22:33 - 12 Oct 2011    Post subject: Reply with quote
Cheers for that Dan. I did check the brakes for warping earlier, but it was too dark to really tell.
I'm hoping it's not that serious, but I'll be sure to check all of this as soon as I can.
However, if none of what you have said turns up, and it isn't the brakes that are the problem - what is??
_Troy_
PostPosted: 12:48 - 13 Oct 2011    Post subject: Reply with quote
I gave it a couple of runs today. Stopped and checked the disc temperature. It's warm, maybe a little hot, but by no means very hot or too hot. If that makes sense.
PostPosted: 13:11 - 13 Oct 2011    Post subject: Reply with quote
Brakes will rub very slightly anyway.
However the GS500 has a twin piston sliding caliper. The pistons can stick but also the pins the caliper slides on can stick.
Plus point is that twin piston sliding calipers are generally a doddle to strip down.
Take the caliper off an then take alloy caliper body off the steel carrier it slides on. This might take some force. Clean up the pins and lube with a suitable grease (I normally use red rubber greases - there are rubber boots around the pins which you want to avoid getting normal grease on).
With the main body of the caliper, pump the pistons out gradually. Try and do this so both come out at the same time. As they come out brake fluid will pee out (one trick is to put the caliper in a clear plastic bag while you do this, so you can see the pistons and slow one coming out while also catching most of the fluid). Clean the pistons up carefully and look pitting or scores on them. They might need replaceing. In the main caliper body you will find 2 seals in each hole. Take these out carefully and inspect the grooves they live in. Often there is corrosion in these grooves which pushes the seals hard onto the pistons making them stick. Then carefully reassemble. If you are at all concerned about the condition of the seals then replace them with new ones, and soak the seals in brake fluid before using them. Lube the pistons with brake fluid as well and push them into place, making very sure you push them in straight. Make sure that the pads are free to slide slightly in the caliper as you reassemble them. Once the caliper is back together put it in place and bleed the brakes.
_Troy_
PostPosted: 21:08 - 13 Oct 2011    Post subject: Reply with quote
Thanks for that Keith.
If I get the chance I'll be doing all of this on Saturday morning.
The thing is the brake seems to work fine at the stronger end, and a little with normal braking. The discs are slightly warm after use, meaning there is some rubbing, but surely that's normal? Or would it nor be enough to warm the disc?
I'm in two minds as to whether a lot of this is psychological, but I'll definitely look to give it an overhaul anyway.
Noxious89123
PostPosted: 21:20 - 13 Oct 2011    Post subject: Reply with quote
Sounds to me like they are starting to get a bit "sticky" but haven't yet seized badly.
When my brakes were rubbing (due to a mechanic refitting old pads the "wrong way round") the brakes were very sharp to use, and were hot enough to make my leather gloves smoke when I poked the disc... Had only ridden a couple of miles too.
_Troy_
PostPosted: 21:30 - 13 Oct 2011    Post subject: Reply with quote
Well my disc is barely warm enough to feel it through the gloves. It's only when I take them off that I can feel they have warmed a little. Where as the back one is very hot.
Fizzer Thou
PostPosted: 21:48 - 13 Oct 2011    Post subject: Reply with quote
If your brakes are nowhere like how they were I would be making this job a priority before anything else.If you use the bike for your main commute transport,the last thing that you need is for the brake/brakes to lock on when in the middle of heavy traffic.Get a manual,some copaslip,some DoT4 brake fluid,some emery cloth and some elbow grease.This will only take a two hours or so and the rewards will be advantageous.
Always have a 'Plan B'
_Troy_
PostPosted: 22:33 - 13 Oct 2011    Post subject: Reply with quote
Don't worry I'm not due to use the bike tomorrow anyway. So Saturday morning I'll be going at it.
I'll be sure to report back with how badly it's gone and the fact I barely know which end of a screwdriver to use Very Happy
One thing that is worth checking is where the brake lever meets the piston in the master cylinder. The lever can wear to piston so as the lever is pulled it has to slide over the worn bit of the piston which can make the feel a bit odd.
Grease (red rubber grease near rubber seals) the lever where it touches the piston. Also grease the levers pivot point while you are at it.
_Troy_
PostPosted: 23:00 - 13 Oct 2011    Post subject: Reply with quote
Thanks again Keith, looks like I have a busy saturday morning ahead of me!
PostPosted: 08:57 - 14 Oct 2011    Post subject: Reply with quote
It it was stuck on there would be more heat in the disc. Could it be knackers wheel bearings your hear? Sounds like the brakes need an overhall anyway.
_Troy_
PostPosted: 07:16 - 15 Oct 2011    Post subject: Reply with quote
I thought so. I cant really hear anything, but thought i could feel something. Oh and using the brake it doesnt feel quite right. The brake does need an overhaul, so I'll be looking to do that soon anyway, just nice to know its not a major issue.
Cheers all.
The last post was made 14 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 96.58 Kb
