| _Troy_ |
 _Troy_ World Chat Champion
 ..... Quote Me Happy
| Ariel Badger |
 Ariel Badger Super Spammer
| _Troy_ |
| Dan79 |
 Dan79 Scooby Slapper
 Posted: 22:16 - 12 Oct 2011 Post subject: |
One other test you might want to try, take the bike for ride for a couple or so miles, only need to ride at sensible speeds up to 30 or 40 should be okay, using bare minimal front brake, stop and feel (VERY CAUTIOUSLY) the front discs, with gloves hands initially. If they're still cool or close to ambient temperature to touch, the brakes aren't the problem; if they are hot, you've diagnosed likely brake seizure. If discs are hot, you should cease use of the bike until problem is rectified, not only for reasons of safety, also if you carry on riding a bike with brakes dragging, discs will be at risk of warping due to the heat.
Obviously don't try this test at high speed or over any distance, because if the brakes are seizing, the discs will get very hot indeed; not to mention danger of fluid overheating alluded to by Ariel Badger. ____________________ Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna |
| _Troy_ |
| _Troy_ |
 Posted: 13:11 - 13 Oct 2011 Post subject: |
Brakes will rub very slightly anyway.
However the GS500 has a twin piston sliding caliper. The pistons can stick but also the pins the caliper slides on can stick.
Plus point is that twin piston sliding calipers are generally a doddle to strip down.
Take the caliper off an then take alloy caliper body off the steel carrier it slides on. This might take some force. Clean up the pins and lube with a suitable grease (I normally use red rubber greases - there are rubber boots around the pins which you want to avoid getting normal grease on).
With the main body of the caliper, pump the pistons out gradually. Try and do this so both come out at the same time. As they come out brake fluid will pee out (one trick is to put the caliper in a clear plastic bag while you do this, so you can see the pistons and slow one coming out while also catching most of the fluid). Clean the pistons up carefully and look pitting or scores on them. They might need replaceing. In the main caliper body you will find 2 seals in each hole. Take these out carefully and inspect the grooves they live in. Often there is corrosion in these grooves which pushes the seals hard onto the pistons making them stick. Then carefully reassemble. If you are at all concerned about the condition of the seals then replace them with new ones, and soak the seals in brake fluid before using them. Lube the pistons with brake fluid as well and push them into place, making very sure you push them in straight. Make sure that the pads are free to slide slightly in the caliper as you reassemble them. Once the caliper is back together put it in place and bleed the brakes.
| _Troy_ |
| Noxious89123 |
 Posted: 21:20 - 13 Oct 2011 Post subject: |
Sounds to me like they are starting to get a bit "sticky" but haven't yet seized badly.
When my brakes were rubbing (due to a mechanic refitting old pads the "wrong way round") the brakes were very sharp to use, and were hot enough to make my leather gloves smoke when I poked the disc... Had only ridden a couple of miles too. ____________________
| _Troy_ |
| Fizzer Thou |
| _Troy_ |
 Posted: 22:33 - 13 Oct 2011 Post subject: |
Don't worry I'm not due to use the bike tomorrow anyway. So Saturday morning I'll be going at it.
I'll be sure to report back with how badly it's gone and the fact I barely know which end of a screwdriver to use  ____________________ Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650 |
| _Troy_ |
| chris-red |
| _Troy_ |
The last post was made 14 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
