ZZR250 Flywheel/Piston TDC
deleted111
PostPosted: 09:00 - 15 Oct 2011    Post subject: ZZR250 Flywheel/Piston TDC Reply with quote
Morning guys,
Trying to do the valve clearances on my ZZR250,
the manual I've got is for the GPX250, bugger all difference.
It says there should be a T1 and a T2 on the flywheel, so when you've lined T1 up, piston 1 is at TDC, fair enough...
...My flywheel only has an F and a T?!
And they're next to each other..?
I'm confused. Any help appreciated guys. I'm guessing the T still does correspond with a piston being at TDC but what the hell do I do to get the other piston at the top?
Many thanks.
Steve.
pepperami
PostPosted: 09:06 - 15 Oct 2011    Post subject: Reply with quote
If you`re looking for TDC, cant you put a rod/gauge through the plug hole and turn the fly-wheel?
It might not be the best method, but it`s one I`ve used many times to find TDC.
you just need to make sure it`s on the correct stroke ie ignition and not exhaust Embarassed Thumbs Up
hope this helps Thumbs Up
EDIT
ignition= both/all valves closed on that cylinder
Moo.
PostPosted: 09:12 - 15 Oct 2011    Post subject: Reply with quote
This? If you take the spark plug out, can you see down the whole to the other?
If you poke something like a straw down there and crank it round until the straw rises.
It may be that the T is tbc for both pistons, but on alternate strokes, as one goes up, the other is down, but crank it round a whole turn and one goes down the other goes up... This is just speculation mind, never worked on a zzr250 engine.
Hth Very Happy
A2 Passed 18/6/10
The last post was made 14 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 36.34 Kb
