Impossible to replace indicator lens screw
EazyDuz
PostPosted: 14:13 - 15 Oct 2011    Post subject: Impossible to replace indicator lens screw Reply with quote
The head on my indicator lens screw was so rusty and knackered i had to cut the remaining plastic from what was left of my old indicator lens off the screw to remove it.
Now i cant find a replacement anywhere. Been to a hardware store today and they dont have any screws in the right diameter and thread size. Already snapped the plastic off my new indicator lens by using a screw which i thought would fit, in the end just glued the lens on and it seems ok now.
But i ordered another lens and i want to screw it on, any ideas where i can find the right screw? its for a GZ125...
cb1rocket
PostPosted: 14:49 - 15 Oct 2011    Post subject: Reply with quote
go to some motor factors or a specialist company that does screws, bolts and nuts.
ie namrick:
https://www.namrick.co.uk/
EazyDuz
PostPosted: 14:53 - 15 Oct 2011    Post subject: Reply with quote
how do i work out the specs of the screw and thread?
cb1rocket
PostPosted: 15:08 - 15 Oct 2011    Post subject: Reply with quote
well i believe the indicator screw is a self tapper type screw.
ie one of these: https://www.adfasteners.com/images/self_tapping_screws_2.jpg
so generally its the diameter and length you need to find out by measuring the old screw.
Take it to the shop and they will pair you up with a new one, there only like 15p
cb1rocket
PostPosted: 15:12 - 15 Oct 2011    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Screw
read this, some useful reading
finpos
PostPosted: 16:55 - 15 Oct 2011    Post subject: Reply with quote
I can confirm that the type of screw you are looking for (generally self tapping light lens screws) falls into the generally unobtainable category. It's quite hard to find one the right size it terms of length/diameter/pitch, but you can find something close enough. Once you've done that, as you've discovered, the head is far too big.
You can turn down the head using a electric drill and a file, but be warned that if it's a plated screw (which it will be unless you specifically asked for stainless) then it will rust in no time.
f.
Ichy
PostPosted: 17:10 - 15 Oct 2011    Post subject: Reply with quote
Tell me the size your looking for. I have a box of small self tappers that I can take a look in.
PostPosted: 18:03 - 15 Oct 2011    Post subject: Reply with quote
Annoying fiddly fragile things. I'd just drill a 3mm hole right through the whole unit, fit a long bolt, and put a spring washer and nut on the back of it.
EazyDuz
PostPosted: 18:49 - 15 Oct 2011    Post subject: Reply with quote
I'll just leave it glued, fuck it. Ive already cracked it off today with not much force and didnt leave any marks, bulb was playing up so i just cleaned it, put it back and re glued. Seems to hold well, after all nothing is ever going to stress the join anyway...
The last post was made 14 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 58.61 Kb
