| old1eye |
 old1eye Borekit Bruiser
| stinkwheel |
 Posted: 00:12 - 16 Oct 2011 Post subject: |
Leaky carbs is most likely a sticky float. try tapping them with a bit of wood.
I'd be wanting to check your camchain tension quick-sharp, could be a classic superdream death-rattle.
Take the rocker cover off and have a look at it. If it all seems ok, slacken off the adjuster nut then tighten it again while pressing down on top of the tensioner blade. You should be able to hear the camchain whirring at tickover, not clattering.
Popping on the overrun can be as simple as a leaky exhaust joint. or a hole in the exhaust (check at the splitter if it's a 2-1 system) have you torqued down the exhaust manifold nuts since you fitted it? They usually settle a bit after being fitted with new gaskets. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Teflon-Mike |
 Teflon-Mike tl;dr
| old1eye |
| salty21 |
 salty21 World Chat Champion
 Posted: 09:54 - 16 Oct 2011 Post subject: |
the discolouration could be leaky inlet rubbers. my superfour did it when the clamp snapped on the carb side of the rubber, would also explain the revs hanging a bit. not sure about the fuel leak though. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| stinkwheel |
 Posted: 11:21 - 16 Oct 2011 Post subject: |
The camchain tensioner on the older 250 twins at least was notorious for not springing down hard enough to do its job properly. It was seldom the chain itself that was the problem.
From the fact that you can tell the carbs are spitting back, I'm assuming you are using no airbox. Again, traditionally superdreams always ran like a bag of spanners with no airbox but this should have been ironed out by the dyno setup.
If it's spitting back significantly, it could also be an issue with ignition or valve timing, or perhaps the inlet valve is staying open a touch? Ignition timing should be keyed on that motor. Worth checking the tappet clearances and timing marks when you check the camchain. A loose camchain could conceivably alter the valve timing a bit between being on and off the throttle.
I don't think the above is likely but it's worth a check for piece of mind. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| old1eye |
| old1eye |
| stinkwheel |
| old1eye |
 Posted: 19:34 - 16 Oct 2011 Post subject: |
nope, chain is properly adjusted and nothing to rub on as theres no chain guard and the rear mudguard doesnt exist  ____________________ If its loud Be proud! |
| Maverick Rigger |
 Maverick Rigger Borekit Bruiser
| old1eye |
| Maverick Rigger |
The last post was made 14 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
