HHEEELLLPPP!!!
old1eye
PostPosted: 23:53 - 15 Oct 2011    Post subject: HHEEELLLPPP!!! Reply with quote
just recently fitted a honda cd250u engine into my honda rebel.
had it rejetted and on a dyno and is set perfect.
today though i have found out the twin carbs are leaking feul some how?!, both of them have yellow stains and are wet/smelly.
undid the drain screws and did them back up to let feul through and check it didnt drip. both are fine. seals were fine last time i had it apart which was around 500 miles ago and its only just started it now, put a new feul line on to see if that solves it but hasnt.
also the engine has suddenly started making a really bad metallic sound on the over run when decelerating around 3-4k rpm above and under it stops, it doesnt do it on normal revving or acelerating only when slowing down and more in the 2 top gears?!
the carbs also pop and spit once or twice when engine braking?!
any help would be really great thanks
p.s. duno if this is posted in right section.
If its loud Be proud!
PostPosted: 00:12 - 16 Oct 2011    Post subject: Reply with quote
Leaky carbs is most likely a sticky float. try tapping them with a bit of wood.
I'd be wanting to check your camchain tension quick-sharp, could be a classic superdream death-rattle.
Take the rocker cover off and have a look at it. If it all seems ok, slacken off the adjuster nut then tighten it again while pressing down on top of the tensioner blade. You should be able to hear the camchain whirring at tickover, not clattering.
Popping on the overrun can be as simple as a leaky exhaust joint. or a hole in the exhaust (check at the splitter if it's a 2-1 system) have you torqued down the exhaust manifold nuts since you fitted it? They usually settle a bit after being fitted with new gaskets.
Teflon-Mike
tl;dr
PostPosted: 08:21 - 16 Oct 2011    Post subject: Reply with quote
Many maledies... but those CV carbs are rather notoriouse for the diaphragms cracking up. That could cause all sorts of anomolouse running issues, and I believe that the cure is new slides as they diaphragms are 'bonded'.....
old1eye
PostPosted: 09:25 - 16 Oct 2011    Post subject: Reply with quote
cheers dude will try the above. The exhaust is a two into two straight throughs and i regularly tighten the collar nuts up. The carbs actualy spit back. Does it when you rev sitting at lights some times to.
Also the revs hang for a few seconds as aposed to raising and lowering with the throttle?!
If the cam chain doesnt move and is still loose what is the next step? Have a sneaky suspision it will be a b***h for me as i dont get much luck with these.
Cheers.
Teflon. The dia- whats its are fine thanks. It has the usual flat spot at 5-6k rpm like most cd250's though. Cant find a cure online for it. Its just tick over and shut throttle on the over run thats being a bitch. Flat out ot will touch 78mph with still a 1/4 of throttle left wich is just revs though i am running the wrong gearing i know.
salty21
PostPosted: 09:54 - 16 Oct 2011    Post subject: Reply with quote
the discolouration could be leaky inlet rubbers. my superfour did it when the clamp snapped on the carb side of the rubber, would also explain the revs hanging a bit. not sure about the fuel leak though.
PostPosted: 11:21 - 16 Oct 2011    Post subject: Reply with quote
The camchain tensioner on the older 250 twins at least was notorious for not springing down hard enough to do its job properly. It was seldom the chain itself that was the problem.
From the fact that you can tell the carbs are spitting back, I'm assuming you are using no airbox. Again, traditionally superdreams always ran like a bag of spanners with no airbox but this should have been ironed out by the dyno setup.
If it's spitting back significantly, it could also be an issue with ignition or valve timing, or perhaps the inlet valve is staying open a touch? Ignition timing should be keyed on that motor. Worth checking the tappet clearances and timing marks when you check the camchain. A loose camchain could conceivably alter the valve timing a bit between being on and off the throttle.
I don't think the above is likely but it's worth a check for piece of mind.
old1eye
PostPosted: 11:24 - 16 Oct 2011    Post subject: Reply with quote
Ok cheers dude will do so after work today
old1eye
PostPosted: 17:42 - 16 Oct 2011    Post subject: Reply with quote
Ok. I have adjusted the valve clearence (werent to far off) done the cam chain tension thing. Tightened up the exhaust bolts checked the carbs over. still making the metalic rasping on de accelerating.
Could it be worn pistons? Still got good power but the left exhaust has smoke drifting out of it wuen i switch uer off, slight amount of white smoke when riding around at low revs too.
Could it be something inside the gearbox as when i pull the clutch in it stops and it doesnt do it on accelerating?
PostPosted: 19:30 - 16 Oct 2011    Post subject: Reply with quote
You're absolutely sure it's not your final drive chain rubbing on something?
old1eye
PostPosted: 19:34 - 16 Oct 2011    Post subject: Reply with quote
nope, chain is properly adjusted and nothing to rub on as theres no chain guard and the rear mudguard doesnt exist Smile
Maverick Rigger
PostPosted: 23:13 - 16 Oct 2011    Post subject: Reply with quote
Cam chain not the drive chain.
The motorcycle presents you a challenge to master the machine, a challenge to adventure. You ride through the wind, linked to the road by a vehicle that responds to your commands as no other does. Unlike an automoblie, there is no metal cage around you, Like and airplane, a pre-ride inspection and regular maintenance are essential to your safety. Your reward freedom.
old1eye
PostPosted: 07:53 - 17 Oct 2011    Post subject: Reply with quote
adjusted that last night, still making the noise, im thinking it could be a worn piston ring as they also make a rattle on the over run. also i get a small amount of smoke from the left exhaust.
Maverick Rigger
PostPosted: 09:19 - 17 Oct 2011    Post subject: Reply with quote
Sounds like you could do with doing a compression test.
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 85.25 Kb
