| EazyDuz |
 EazyDuz World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 12:01 - 18 Oct 2011 Post subject: |
Think the current Oxford ones do detect falling battery voltage and switch off (possibly some of the HG ones).
However I normally wire them up through a relay to the battery, and trigger the relay with a wire taken from the feed for the rear brake light switch (fairly unobtrusive and also often a cheap and easily replaced bit of wiring rather than an integral part of the wiring loom)
| EazyDuz |
| G |
 G The Voice of Reason
| EazyDuz |
 Posted: 12:25 - 18 Oct 2011 Post subject: |
You could, depending on how the horn is wired. If it has a permanent feed when the ignition is on and just earths to sound the horn then you can use that. However that is probably not that likely so you would need to cut into the main wiring to the switchgear.
I am a bit dubious about chopping the main loom unless really necessary. Too likely to cause difficult to find hassle in the future.
| Mrjoolz |
 Mrjoolz Brolly Dolly
| P.addy |
 P.addy Red Rocket
 Posted: 12:29 - 18 Oct 2011 Post subject: |
Installed saturday.
Make the grips a bit too thick, bugger to grip
Mixing these with some Tucano Urbano muffs  |
| Mrjoolz |
 Posted: 12:34 - 18 Oct 2011 Post subject: |
thats the muffs I was looking at. £40.00 apparently from a place near my work. Wondered if they would also press on brake/clutch and should I fit hand guards inside them.
If I was going for one or the other, would you recommend grips (heated) or muffs ?
[/quote] ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa..... |
| P.addy |
 P.addy Red Rocket
| EazyDuz |
| J0Al1 |
 J0Al1 World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 15:28 - 18 Oct 2011 Post subject: |
| EazyDuz |
| Gazdaman |
 Gazdaman I did a trackday!!!
| G |
| EazyDuz |
| kawakid |
 kawakid World Chat Champion
| EazyDuz |
 Posted: 15:37 - 19 Oct 2011 Post subject: |
Waste of time and money just for some heated grips. Useful if i intend to buy every electrical gadget under the sun but for a set of heated grips its a bit OTT imo.
Thanks though, will just wire to the horn. ____________________ To shreds you say? Tss tss tss |
| Souleh |
 Souleh Trackday Trickster
| kawakid |
The last post was made 14 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
