| hazza |
 hazza World Chat Champion
| spyuggy |
 spyuggy Nitrous Nuisance
| hazza |
| Moxey |
 Moxey World Chat Champion
 Posted: 21:56 - 19 Oct 2011 Post subject: |
You could try adjusting the A/F or pilot screws a wee bit to make it a little richer (helps for cold starting) shouldn't cause too much harm other than some carbon deposits and lower mpg.
Mine was running a little rich before I took it off the road last week for the MZ and always started first push of the button with full choke.
If I remember correctly the further out the screws are the richer the mixture if you want to try (haynes recommended is 1 7/8 turns out as a guide), I advise checking the plugs after to make sure it isn't too rich.
Careful with the screws as well they can round off pretty easy and sometimes can be seized (wd40 or plusgas) ____________________ Current: 02 FZS 1000 & 91 Royal Enfield Bullet 350 Some Bike Pics...
'I was too busy paying attention to pay attention' |
| temeluchus |
| Fizzer Thou |
| hazza |
| Moxey |
 Posted: 19:48 - 20 Oct 2011 Post subject: |
If theres a smell of petrol then sounds like flooding, check the aribox and see if theres a puddle of fuel in it, could be the vacuum tap has failed and just allowing fuel straight through all the time, or perhaps the float heights but if it was fine before I doubt they would suddenly go but might be worth considering.
Also when starting with choke you don't touch the throttle do you? Made the mistake of using full choke and twisting the throttle abit a few times, can flood the engine and spoil the plugs they never work too well after been soaked in petrol even fairly new plugs. ____________________ Current: 02 FZS 1000 & 91 Royal Enfield Bullet 350 Some Bike Pics...
| temeluchus |
| hazza |
| Moxey |
 Posted: 21:11 - 21 Oct 2011 Post subject: |
If its stuttering when opening throttle could be a few things.....
Most likely is carb balance, can be done with vacuum gauges (cheap ones of the bay are about £35 decent are Morgan at £70), a phillips screwdriver and knowing where the flap adjustment screws are (think theres a video on youtube demoing how to).
Failing that could be stiff throttle cable, bit of 3 in 1 oil on the cables might free them up
Needles and jets do wear with time, often idle fluctuates and delay in fuelling can happen, cost about £90 for new set from the usa never seen any for sale in uk (probably cheaper getting used set of carbs off of the bay)
If the problems not to bad then don't see any harm in just putting up with it, gives the bike character doesn't it  ____________________ Current: 02 FZS 1000 & 91 Royal Enfield Bullet 350 Some Bike Pics...
| temeluchus |
 Posted: 06:32 - 22 Oct 2011 Post subject: |
sounds like a good excuse to fit trick a new set of trick flatslide carbies.
RS36 or 38 mikunis work very well on those motors  ____________________ Some shite cruiser. Now with guns and FREEDOM! |
The last post was made 14 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
