oiling cables.
Tom85
PostPosted: 17:29 - 20 Oct 2011    Post subject: oiling cables. Reply with quote
What oil would be best to use to oil the clutch cable? Would wd40 work or would it cause damage?
The Artist
PostPosted: 17:30 - 20 Oct 2011    Post subject: Reply with quote
wd40 won't damage it but it is not really a proper lubricant.
3 in 1 or similar would be better. Any light oil really.
neil.
PostPosted: 18:36 - 20 Oct 2011    Post subject: Reply with quote
I've always used 3-in-1 silicone spray lube with one of these cable oilers:
https://www.3-in-one.co.uk/wp-content/uploads/2009/04/3in1-silicone-spray.jpg
https://www.dirtbikebitz.com/images/products/rfx/1536cableoiler.jpg
Benson_JV
PostPosted: 20:07 - 20 Oct 2011    Post subject: Reply with quote
I just use WD40.
Does the job. Thumbs Up
Johnser
PostPosted: 20:21 - 20 Oct 2011    Post subject: Reply with quote
some oils can damage nylon lined cables. check yours before lubing.
I use a mix of 2-stoke and white spirit. keep squirting it in with a cable oiler until it comes out the other end without being tainted with crap. I then whirl the cable round my head (not next to the conservatory) to fling out excess oil if cable is off the bike. if still in place, you will get some seepage.
orac
PostPosted: 22:20 - 20 Oct 2011    Post subject: Reply with quote
i use silkolene silkopen, its leaves a graphite film behind which helps the cable last that bit longer between lube ups
Fizzer Thou
PostPosted: 22:32 - 20 Oct 2011    Post subject: Reply with quote
I have owned a hydraulic cable oiler for many years and find it preferable to the one shown above as it forces any lubricant through the cable that you choose to utilise.
For the spray cable oiler I use GT85,but for the hydraulic oiler I use a mix of 3-1 oil with some copaslip.For some reason this works really well,often bringing old and tired cables back to life.I recently used this on a friends control cables and she was surprised by how much better they felt.
Always have a 'Plan B'
Lone-Wolf
PostPosted: 00:02 - 21 Oct 2011    Post subject: Reply with quote
Wotcha.
I have an hydraulic oiler - I removed the piston part and screwed in a length of plastic tube with a schrader ( tyre ) valve in the top. I just give the foot pump a couple of strokes and leave it - a few seconds later you get a sound similar to a squeege bottle of brown sauce when it is almost empty Very Happy . . . and a nice oiled cable.
Also, the plastic bits left from used "Party Poppers" make excellent oil reservoirs - just tape 'em to the top of the cable and fill with oil. Gravity and time does the rest.
Cheers.
L.W. - www.moonshiners.org.uk
temeluchus
PostPosted: 02:08 - 21 Oct 2011    Post subject: Reply with quote
chain wax spray makes a good cable lube.
tahrey
PostPosted: 18:50 - 02 Nov 2011    Post subject: Reply with quote
I just squirt general-purpose bicycle cable lube into the cut-out on the adjuster nut and keep pumping the lever until it moves smoothly again instead of feeling stiff and sticky. I figure the cable drags some oil with it, leaves it on the inside of the guide, comes back and picks up more as I drip it on, and so on and so forth, with gravity doing the rest.
But that's because I'm a lazy bastard Very Happy
I did use the same gear oil that I do for my chain at first, but I think it's a bit too thick to make much headway down the cable run. Certainly not without being heated.
(Hmm, there's an idea ... heat up some soft wax and pour it through? The stuff you'd use on sledge runners, like...)
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
The last post was made 14 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 68.94 Kb
