Aprilia rs 125 engine problem
jinis dust
PostPosted: 23:06 - 20 Oct 2011    Post subject: Aprilia rs 125 engine problem Reply with quote
hi
was riding home the other day an bike started to have no power at all and was bogging?? then all of a sudden cut out and now wont start.
when i got it home and tried again, the engine sounds like when your turning it over with no spark plug init?? Sad Thumbs Down
any help much appreciated,
thanks
justin
PostPosted: 23:45 - 20 Oct 2011    Post subject: Reply with quote
Take the spark plug out, with the plug held against a bare metal part of the engine and with the HT cap on the plug crank the engine over and look for a spark.
ClockworkJesu...
PostPosted: 00:04 - 21 Oct 2011    Post subject: Reply with quote
You mean like it lost all compression?
How old is the bike and when was it's last rebuild? Confused
Nope.
PostPosted: 00:31 - 21 Oct 2011    Post subject: Re: Aprilia rs 125 engine problem Reply with quote
jinis dust wrote:
I was riding home the other day and my bike started to have no power at all and it started bogging down. Then all of a sudden it cut out and now it won't start.
When i got it home and tried to start it again, the engine sounds like when your turning it over with no spark plug in it? Sad Thumbs Down
Any help is much appreciated.
Thanks,
Justin
Grammar corrected for free.
When was the bike last rebuilt?
You need to check for a spark and do a compression test.
jinis dust
PostPosted: 08:28 - 21 Oct 2011    Post subject: Reply with quote
Yh i have got a spark that was the first thing i tried.
Bikes on a 52 plate obly have it 5 month and dont know wen was the last rebuild. As its now gettin horrid weather i think its gunna have a new piston n rings. So gunna further investigate wen its in bits. Not too sure bout compression as i havent got a tool to measure it.
Thank
Justin
PostPosted: 09:33 - 21 Oct 2011    Post subject: Reply with quote
As a quick test, pop your finger over the spark plug hole and try to start the bike. It should try and force your thumb off pretty hard.
Although... compression isn't everything. I had apparently 128psi and all looked good. Main bearings were slowly dying and was causing the crank to lock solid every now and then Laughing
PostPosted: 10:41 - 21 Oct 2011    Post subject: Reply with quote
If you have a spark then that is the simplist thing out of the way.
If it is spinning over rapidly on the starter then that suggests low compression. Run a compression check. However for it to go suddenly it suggests a failure rather than just gradual wear. If so then possibly a hole burnt in a piston or possibly it has snapped a ring. If it has snapped a ring then it has probably scored the barrel.
jinis dust
PostPosted: 18:32 - 22 Oct 2011    Post subject: Reply with quote
Took the head n barrel of earlyer n took piston off. Wer the piston faces the exhaust port it has sort of melted the rings to the piston...
So think i need a new piston. Will post on weather its ok after.
Thanks
Justin
jinis dust
Thanks
Justin
The last post was made 14 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.83 - MySQL Queries: 15 - Page Size: 60.7 Kb
