| jinis dust |
 jinis dust L Plate Warrior
 Posted: 23:06 - 20 Oct 2011 Post subject: Aprilia rs 125 engine problem |
hi
was riding home the other day an bike started to have no power at all and was bogging?? then all of a sudden cut out and now wont start.
when i got it home and tried again, the engine sounds like when your turning it over with no spark plug init??
any help much appreciated,
thanks
justin |
| ClockworkJesu... |
 ClockworkJesu... Nitrous Nuisance
 Posted: 00:04 - 21 Oct 2011 Post subject: |
You mean like it lost all compression?
How old is the bike and when was it's last rebuild?  |
| Nope. |
 Nope. World Chat Champion
 Posted: 00:31 - 21 Oct 2011 Post subject: Re: Aprilia rs 125 engine problem |
| jinis dust wrote: | Hi
I was riding home the other day and my bike started to have no power at all and it started bogging down. Then all of a sudden it cut out and now it won't start.
When i got it home and tried to start it again, the engine sounds like when your turning it over with no spark plug in it?
Any help is much appreciated.
Thanks,
Justin
Grammar corrected for free.
When was the bike last rebuilt?
You need to check for a spark and do a compression test. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| jinis dust |
| P.addy |
 P.addy Red Rocket
 Posted: 09:33 - 21 Oct 2011 Post subject: |
As a quick test, pop your finger over the spark plug hole and try to start the bike. It should try and force your thumb off pretty hard.
Although... compression isn't everything. I had apparently 128psi and all looked good. Main bearings were slowly dying and was causing the crank to lock solid every now and then  |
 Posted: 10:41 - 21 Oct 2011 Post subject: |
If you have a spark then that is the simplist thing out of the way.
If it is spinning over rapidly on the starter then that suggests low compression. Run a compression check. However for it to go suddenly it suggests a failure rather than just gradual wear. If so then possibly a hole burnt in a piston or possibly it has snapped a ring. If it has snapped a ring then it has probably scored the barrel.
| jinis dust |
| jinis dust |
The last post was made 14 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
