 mufalak L Plate Warrior
 Cheeseybeaner World Chat Champion
 unitynotsocri... Banned
 Posted: 17:07 - 22 Oct 2011 Post subject: |
if you can fit the 12 v stator plate and rota on it should work ok.the casing should be the same,if not the later casing should fit.
you might consider swopping the cam as well,it may improve performance.
just one thing though ,a 1988 cdi model?or a honda brazil points model?if its a 1988 points model then it should do,
if you have a cdi model you have got to swop the 12 volt /cdi power coils and flywheel and so before you start ,just check the flywheel taper is the same.using the old flywheel will not work as you need the pulse coil magnet in the newer flywheel ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
