Dark/tinted visors
at106
PostPosted: 19:08 - 01 Nov 2011    Post subject: Dark/tinted visors Reply with quote
I've been asked what i'd like for christmas and one thing i need is a darker visor. At the moment i only have a clear visor but when the sun does shine a darker visor would be useful. I have an AGV K3 and all the dark/tinted visors say not for road use?
https://www.ebay.co.uk/itm/Genuine-Dark-AGV-K3-K4-Visor-/310340789034?pt=UK_Motorcycle_Helmets&hash=item4841c0a32a
Or another option is to get a clear pinlock visor and use darker inserts but im not sure how effective this will be?
0l0dom0l0
PostPosted: 19:19 - 01 Nov 2011    Post subject: Reply with quote
The legal limit for the amount of light a visor must let through is about 70% or something like that.
Tinted visors let around 30% through.
They are technically not road legal and its been said it might go against you in the event of an accident but in reality everyone has them.
I personally think they are safer in sunny conditions. They stop all glare from anything. I also think they are safer than riding with sunglasses.
weasley
PostPosted: 19:24 - 01 Nov 2011    Post subject: Reply with quote
To be road legal, a visor must have no more that 50% tint. This is barely tinted and not worth it. Anything with a tint that is effective against the sun is darker than 50% and is thus not road legal.
The police have been given advice to be practical with visors, which generally means only intervene if dark/low visibility and let it go under more expected circumstances (eg a sunny day, low sun etc).
I've used a dark visor for 9 years and never been stopped. I always carry a clear one with me anyway, in case the conditions change.
I prefer a dark visor to a dark insert - the clarity is better and it's right across the field of view. If your visor replacement mechanism is straightforward it is no issue to swap between visors. I had an old AGV with fairly easy-to-use visor mechanism, although my current Shoei is easier.
TL;DR - a dark visor will be fine.
0l0dom0l0
PostPosted: 19:32 - 01 Nov 2011    Post subject: Reply with quote
Gotta agree with this!
st3v3
PostPosted: 19:34 - 01 Nov 2011    Post subject: Reply with quote
I'd be ok with it as long as it don't say "not for road use".
PostPosted: 19:48 - 01 Nov 2011    Post subject: Reply with quote
I've been using not for road use black visors since I started riding. Never been pulled for it.
IMO if you're riding around at night with a dark visor you deserve to get pulled.
at106
PostPosted: 19:55 - 01 Nov 2011    Post subject: Reply with quote
Thanks for all your replies Thumbs Up
I'll always carry a clear visor with me anyway so there shouldnt be an issue.
Cunnington
PostPosted: 20:15 - 01 Nov 2011    Post subject: Reply with quote
I got a hyper optiks fog city insert for my shark lid, and converted it to pinlock when i got my shoei. The tint changes colour, but it doesnt darken enough to give an even luminesence when you go from dark to bright.
I've got to agree that a tinted insert isnt as good as the full visor, because the tint doesnt cover the full area, and depending on your riding position (how head down arse up you are) it can get in the way a bit. That said, it is easier to carry an insert rather than another visor.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Maruchino
PostPosted: 20:43 - 01 Nov 2011    Post subject: Reply with quote
https://media.cnbc.com/i/CNBC/Sections/News_And_Analysis/_News/_SLIDESHOWS/ProductPlacementMovies/CNBC_Product_Placement_top.jpg
PostPosted: 20:45 - 01 Nov 2011    Post subject: Reply with quote
Personally never bothered carrying a spare, if I knew it was going to get dark when I was out just bung the clear one on.
instigator
PostPosted: 22:02 - 01 Nov 2011    Post subject: Reply with quote
I haven't used a clear visor for about 5 years. And yes, I tend to ride daily when I can, whatever the weather. Sure makes dark, foggy mornings interesting...
Andy_Pagin
PostPosted: 22:53 - 01 Nov 2011    Post subject: Reply with quote
I just wear sunglasses.
PostPosted: 23:44 - 01 Nov 2011    Post subject: Reply with quote
"Not for road use" or "Daytime use only" is irrelevant on visors. Unlike for exhausts, it has no meaning in law. What matters is that the visor has a BS4110 or E mark. No mark, illegal. Mark, legal.
I've noted a few times that there's no obvious way to verify whether a marked item actually does meet the required standard. My visor has a stuck on E13 label, so it was ostensibly tested in Luxembourg. How on earth would I check? And why should I? The presence of the mark is what matters as far as the law is concerned.
Incidentally, the label is peeling - the moment that it comes off, the visor becomes illegal. Shocked So to keep on the right side of the law, I should make up another one and stick it on, right?
So here's what you do. Buy any visor you like, look the other way while a Glamorous Assistant slaps an "E" sticker on it, and you're every bit as legal as anyone else wearing any E marked visor, regardless of tint or "you gonna die, sucka" marking on it.
Yes, if it's over 50% tint then it shouldn't be E marked, but that's not your problem, is it? Came that way, right?
JoeDougieDoug...
PostPosted: 23:59 - 01 Nov 2011    Post subject: Reply with quote
Tinted visors are brilliant! Thumbs Up My Caberg flip helmet has an internal one that you can pull down. Pretty swish.
nightshaddow
PostPosted: 09:42 - 02 Nov 2011    Post subject: Reply with quote
this is my helmet,
https://www.motovest.com/loja/images/D/capacete-modular-ls2-ride.jpg
PostPosted: 10:26 - 02 Nov 2011    Post subject: Reply with quote
As above. My helmet has an inner visor that drops down. Does the job.
PostPosted: 10:31 - 02 Nov 2011    Post subject: Reply with quote
My tinted visor has the same stamps as my clear visor.
It still gets a bit iffy with the proper low sun, but aside from that its ace.
Atomic Punk
PostPosted: 10:48 - 02 Nov 2011    Post subject: Reply with quote
Dark visor as soon as the clocks go forward or if it light in the mornings/evenings and a clear one when the clocks go back.
Had to change it two days early this year due to the inclement weather.
I may have lost my way but I'm way ahead of schedule.
sepher
PostPosted: 12:29 - 02 Nov 2011    Post subject: Reply with quote
I always wear backed out visor, if I get caught out in the dark with it then I just ride around with visor open but normally I carry clear visor on me just in case. I'm still fairly new to riding, so if I do something stupid like stall the bike or almost drop it then I can hide behind the dark visor Very Happy
T.C
PostPosted: 12:40 - 02 Nov 2011    Post subject: Reply with quote
2 points.
As mentioned, legal tint is 50% maximum and will be stamped as mentioned with BS4110 XA, YA or ZA.
Black tint visor only allows 18% light through.
If you are wearing a legal tint visor in the event of a crash at night it has no bearing and therefore contributory negligence cannot be attributed.
Even those wearing a black race visor at night who have been involved in crashes have not had any contrib however that has probably been more through luck than judgement, and it is not advised to wear a black visor at night.
It is better to arrive 30 seconds late in this world, than 30 years early in the next
JoeDougieDoug...
What has always interested me is those mirror'd visors... you know the ones you get that are reflective from the outside, usually in a yellow or purple colour... do they do the same job as the tinted visors? Confused
https://www.motorcycle-accessories-wiseguy.com/image-files/vr2mir_side.jpg
UKRedwing
PostPosted: 13:03 - 02 Nov 2011    Post subject: Reply with quote
I have an AGV k4 as my spare lid, uses same visor as the k3, I have managed to get 4 visors somehow, a rainbow iridium tint which is road legal (came with helmet) a dark tint visor and a clear visor (given to me by a member on here when they wrecked their lid) and an iridium silver mirror visor that I bought. Never been stopped with it in 2 years, I just carry my clear in the visor pouch in my bag and swap it over if its dark.
I put a fogcity in the iridium and its absolutely perfect for riding to work in the morning with low sun, stop more light than a dark tint and the fogcity insert stops it fogging
Redoko
PostPosted: 13:14 - 02 Nov 2011    Post subject: Reply with quote
This my AVG Stealth 4 or something. Awesome helmet.
In built visor is really handy. No need to carry a spare.
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/311433_10150382500136201_587806200_10342898_1839075548_n.jpg
PostPosted: 14:18 - 02 Nov 2011    Post subject: Reply with quote
or "to any other standard accepted by an EEA State, which offers in use levels of safety, suitability and fitness for purpose equivalent to those offered by [BS 4110 XA YA or ZA] and are marked with a mark to indicate that standard"
or "those which comply with the requirements of Council Directive 89/686/EEC(3) of the 21st December 1989 on the approximation of the laws of the Member States relating to personal protective equipment as amended by Council Directives 93/68/EEC(4) of 22nd July 1993, 93/95/EEC(5) of 29th October 1993 and 96/58/EEC(6) of 3rd September 1996"
As mentioned above, my visor is marked "E13", with a (not very) sticky label. Now, I have an interest in the minutiae of legislation, but I have no idea if it actually "meets levels of safety, suitability and fitness for purpose equivalent to those offered by [BS 4110]". What chance does a random traffic copper have, or one of the CPS's finest clock-watchers?
In practice, I'd suggest that having a helmet sporting a mark is a pretty good defence. It doesn't meed DS 4110 or 89/686/EEC (as amended), you say? You'd have to take that up with the seller, or Luxembourg, or Brussels.. No, I can't remember where I bought it, it was some guy on eBay years ago.
T.C
PostPosted: 16:04 - 02 Nov 2011    Post subject: Reply with quote
You are right to a point.
To be legal in the UK, it has to be of an equivelant standard and therefore capable of passing the 4110 test.
Although approved for use in most EU countries, it is one of those areas where because the level of tint does not conform to UK standards, despite being marked with EU markings, 4110 is still the base setting for legality.
However, if the visor is worn in appropriate conditions, it is unlikely to affect anything as the same principal applies as wearing an 18% visor, and the big issue is that retailers are not allowed to sell visors other than those stamped with 4110 unless they are happy to pay massive fines, the last one being up north who got stung for about £50,000 and went out of business.
With helmets brought in from overseas it is somewhat different as most of the branded hats would if tested meet the standard, but the current EC22/05 is europe wide and those brought in from the USA with either a Snell or DOT approval would reasonably be expected to meet the 6658-85 or EC22/05 standard.
Visors are different because different manufacturers have different manufacturing techniques and optical clarity and colour recognition is a major issue which is ne of the key points raised when as members of the BSI committee we tried to get the use of 18% black visors legalised for daytime use a few years back.
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 134.72 Kb
