My first oil change - I've really got no idea!
J.M.
PostPosted: 00:22 - 02 Nov 2011    Post subject: My first oil change - I've really got no idea! Reply with quote
Hey guys,
I think the bike's probably due for it's first oil change now, so time to loose the oil changing virginity Laughing
Bought the bike at the start of April and have just been riding it up until now, so it's been about 7 months (presuming the service before it was sold did an oil change) and about 1500-2000 miles (I've not been counting).
Anyhow, I've really got no idea of how to go about doing an oil change, so I'd really appreciate it if I could get some help Smile I'm taking the bike in for it's MOT on the 3rd (due for the 23rd) so I'm hoping to be able to buy everything I need then Thumbs Up
From what I understand from the brief guides I've been looking at, I'm going to have to remove some of the fairing in order to get to the bottom of the engine, and drain it from there.
Now, as I've got to dispose of it properly, I'm thinking to put it into some kind of bottle and then dispose of it after the change is done. Where do I dispose of it? From what I understand it's got to be a local authority site, does the tip count (that's only a few miles away Smile)?
One of the most important questions I've got though: what oil to buy? Is it all the same, or do I have to match the brand that's already in there (I don't know what it is!) Is there anything I have to do if I'm switching brands (like clean it out?)
Presuming I've got the basic tools such as screw drivers, Alan keys, pliers, long-nose pliers - what else am I going to have to buy to do the oil change?
Now, encase I actually manage to pull of this intensely difficult job without somehow killing myself now that I've pried myself away from the computer for the first time in x-years, is there anything I need to do after the change? (please, please, let it be "rag it" Laughing )
Tips, information, good luck posts Rolling Eyes , they're all welcome. thanks for the help guys Very Happy
2004 R1 & 2018 XSR900
PostPosted: 00:31 - 02 Nov 2011    Post subject: Reply with quote
CBR, unsure if yours is slightly different to the older ones...
Basically 17mm socket, set it to anti clockwise and undo the bolt on the underneath of the bike. Cant miss it. Crucial you turn it the correct way.
Remove the oil filler cap and the side where your right foot would be.
Drain all the oil out into a pan/tub and dispose of however.
1 litre of oil goes back into the CBR. New washer on the sump plug, refit, do it finger tight then just a little bit of socket/spanner. Don't go macho on it.
Re fill the 1litre of new oil into the filler cap. Clean dipstick on cap and put back in and screw in, unscrew and check level on the stick with the bike UPRIGHT
Well done, oil change master.
Just for random info.. I used either Morrisons 10w40 semi synth or Castrol high mileage stuff in the 125s. Never had an issue, CBR was smooth with them both.
I dont think you need to remove fairing though... should be able to access bolt easily.
TheSmiler
PostPosted: 00:33 - 02 Nov 2011    Post subject: Reply with quote
HOW2: change Oil & CLean strainer (Small Honda's +)
This might help you, show you the easy process and how to do it, you could also save the old oil.. put it in a bottle and then use it for the chain.
The Artist
+1 to what Paddy said. Make sure bike is 100% upright, not on its stand when you measure the oil level.
PostPosted: 00:43 - 02 Nov 2011    Post subject: Reply with quote
Link that smiler sent you to, you do have an oil strainer in there... but if im honest, its really REALLY not worth the hassle.
You have to remove all the plastic on the right hand side, disconnect the clutch cable, remove the casing, new gasket as the old one just collapses on itself and then you have to remove a lot of bolts Laughing
I never did it and I have an engine with 25,000 miles sitting in the garage still going strong.
J.M.
PostPosted: 11:03 - 02 Nov 2011    Post subject: Reply with quote
Thanks for all the help guys, much appreciated Thumbs Up
I'm not quite sure what oil to buy (never got a manual). From the trusty Google I think Ive got to get some 4-stroke mineral oil, 10-40w?
I found this one, a friend reckons he has a discount there so I'll buy about 2 litres through him (oil change now and do another before I sell It in 4 to 5 months): opieoils.co.uk/p-725-castrol-actevo-4t-10w-40-motorcycle-4-stroke-engine-oil.aspx
Also I've read about having to replace the washer+bolt when changing the oil, is that true?
PostPosted: 11:05 - 02 Nov 2011    Post subject: Reply with quote
Change the washer yes, dont worry so much about the bolt.
Erm.. wouldn't say mineral oil is good. At all.
Like I said Morrisons - £2.99 for 2 litres, semi synthetic 10w40. Grey or green bottle. Works perfectly fine.
PostPosted: 13:13 - 02 Nov 2011    Post subject: Reply with quote
Good stuff. Warm the engine up first to help the oil to flow out, leave it to drain for as long as possible, and yes, fit a new crush washer and do not overtighten the drain plug.
PostPosted: 13:37 - 02 Nov 2011    Post subject: Reply with quote
That would be the right side then Laughing
tahrey
PostPosted: 13:46 - 02 Nov 2011    Post subject: Reply with quote
OH GOD, ^THIS^
The Honda drain plugs are a weird design and pretty fragile. I dunno if the CBR uses the same as the CG, but if so, it won't have a replaceable washer. Just an O-ring that's tensioned by the flat of the nut, and a sort of collar to keep the dirt out.
Overtighten it, and the centre nut part shears away from the collar and the flat without ever so much torque. The O-ring & metal parts holding it in place duly spring back away from the sump, leaving you with an immobilised bike pissing fresh oil onto the ground.
If you don't already have one, run, don't walk, to your local Machine Mart and buy a torque wrench - they are endlessly useful items to the home mechanic and MM's ones are quite cost effective (vs, e.g., Halfords - I can't speak for Screwfix etc) so long as you're not planning on doing your own stripdown/rebuild of a JCB. Been happily using mine for several years now for things upto and including doing up car hub bolts after a gearbox swap. Also a Haynes manual that, even if most things in it are dubious, should at least get you within spitting distance of the correct torque setting.
(hold it by the twisting, level setting part of the handle whilst doing up, and stop when it goes CLUNK and jerks slightly in your hand)
The above is spoken from wholly unexpected experience. I've done an uncountable number of home oil changes with little drama other than slipping and spilling dirty oil, or having to batter seized car filters into submission, but this still took me by surprise. The only place it seems you can get replacements is Honda themselves, too.
Oooooooother than that, and getting the fairing off, it's a pretty straightforward job as already said.
Get yourself some kind of non-valuable catching vessel that will fit under the drain hole and a distance either side (it comes out horizontal at first, and dribbles down out of the hole and drips off the sump itself at the end) and can hold at least 1 1/2 litres, preferably with a handle, plus some disposable gloves (dirty oil is nasty, carcinogenic stuff, and like turmeric it DOES NOT COME OUT OF CLOTHING).
Warm up the engine (a few minutes idling with occasional throttle blips is sufficient - just to warm up (not "heat", warm) the oil and loosen any debris) and park the bike on its centre stand, over a load of newspaper. Put the catcher in place, don gloves, open the filler, loosen the drain bolt until it starts to weep slightly, then do the rest by hand:
Push the bolt against the sump whilst you undo it, til you feel it come loose. Then execute some impressive sleight-of-hand removing it without interrupting the oil flow, losing the bolt/spring/filter, or suffering a jet of oil up your sleeve.
Leave that to drain a while, and "rinse" the filter in some fresh oil or petrol. It should be basically clean anyway as the centrifugal one takes care of any proper nasties, and modern EU spec oil / fuel / engine management produces very little in the way of cack.
When it's dribbling out slow enough to make individual drips, reassemble the plug/spring/filter contraption, reinsert it in the hole, thread it correctly and tighten with the torque wrench. Carefully introduce the correct amount of oil to the filler (a cheap set of funnels may be useful here, particularly if you can get one with a bendy neck or an asymmetric mouth); in winter you may want to let the bottle float in a bucket of warm water for a few minutes first. Clean the dipstick, its O-ring and the filler hole, thread it, screw in, remove, and check the level. Add extra if it's below the halfway point, but mind that the min/max range is only about 100ml on these engines (vs 500 to 1000 for cars). Screw the dipstick fully back in place, wipe up any drips on the engine, replace fairing, and carefully remove bike from the scene.
Transfer the oil to a more suitable, sealable container; a used bottle such as the one your fresh oil came out of is good, so long as you mark it up beforehand (e.g. with enamel paint!) as now being reserved for waste. Give it a wipe down, and give the catch container a cursory wipe round the inside, then bundle the wiping tissues, gloves, and newspaper all into a carrier bag. Take said bag and the waste bottle to the local tip, which should have facilities for "recycling" (ha) old oil. Ditch the bag into whatever receptacle they have for contaminated material, and empty the bottle into the tank. Hold onto it for the future - it's cheaper to buy oil in bulk, and bikes need theirs changing relatively more often than cars, so you'll need something to use until you've worked your way through a whole 4 or 5 litre container. (After that, you only have to go to the tip every 4 or 5 times Wink
I personally use Fuchs (aka Silkoline) Comp-2 oil, which seems to work very well... but only as it was recco'd by the ol' non peer reviewed Awardspace CG servicing website, and I use my bike for commuting (mercilessly thrashing it to the gunnels along the way) so I'm too much of a pussy to try something else which may knacker the clutch for the sake of 3 or 4 quid per 2000 miles... I daresay Asda pseudo-synthetic 10w40 grot may work just as well!
PostPosted: 13:54 - 02 Nov 2011    Post subject: Reply with quote
See, you share my logic, but when I've told various people its on the right, they question if its looking at it from the front or sitting on it Laughing
J.M.
PostPosted: 17:31 - 02 Nov 2011    Post subject: Reply with quote
Have to say I was thinking the same as chris there, I guess I didn't think about it like that Laughing
tahrey wrote:
rather a lot Laughing
Didn't realise there was quite so much when it came to changing the oil! I'm not letting it put me off though, I've got to learn (hopefully without destroying that bolt thingy!)
I was under the impression that the cbr used a crush washer rather than the o-ring, but looking at this ebay listing and taking the name "crush washer" quite literally, I'm guessing the cbr125 uses the o-ring. I guess I can ask about this at my MOT tomorrow though Thumbs Up
In which case is a torque wrench an essential item for the oil change, or could I get away with doing the bolt hand tight then just giving it a little extra with a socket?
I'm really a mechanical newbie Laughing so if the torque wrench is necessary (I understand it's going to be really useful to own), is there anything I'm looking for when/if I buy one?
From Machine Mart's website I've found these two which are.. not cheap let's say.. but I think I could stretch to paying that for a tool if it's going to be useful for the future. item 1 and item 2.
Also you mentioned putting the bike on it's centre stand to change the oil. Unfortunately the cbr125 only has a side stand, so should I be trying to keep the bike upright the entire time the oil is draining?
tahrey
PostPosted: 18:17 - 02 Nov 2011    Post subject: Reply with quote
Don't worry mate, it all makes sense when you do it. I've just done it step by painstaking step. Sort of like a video made out of words Very Happy
Something that's irked me a lot in the past is when people have put up guides that look nice and concise and easy but there's a whole lot of little steps hidden behind each single part of their description, which someone who's coming to it cold won't realise about*
Like, when you were first learning to read and write, you had to take each letter at a time, right? Then what each strange combination of letters sounded like, and the construction of basic words. Nowadays you just look up unfamiliar words in a dictionary. It wouldn't do to just chuck a dictionary at a kid who couldn't write yet.
Yes, you can do it with just a plain adjustable spanner if you have to, and that's the source of my downfall with the honda sump nut thing. I'd gotten used to car bolts, where you can just use any old spanner, or socket bit + mini breaker bar to take them off, then put 'em back on, pulling on it fairly hard to crush the new washer and form a seal. I'd also done it that way with the bike one, not realising the difference. It stood up to this treatment the first 3 or 4 times... then sheared.
If you're careful with it and stop tightening it at the point where the metal of the collar meets the sump, you should be fine. I'm just super paranoid about it now and so do it to what the manual says!
But the torque wrench is a mighty useful thing, and twenty-one quid isn't ever so much to spend on one (huh, inflation... mine was £14.99, even though it was the same model and I bought it within the last decade). There are a lot of things which need to be done up to a particular tightness, and though you can approximate the lighter ones, you've no realistic chance for anything more than finger tight. Doing up the rear axle nut, for starters, if you want to adjust the chain tension and/or basic wheel alignment for yourself (and you will, lest you like pissing money down the drain), or after taking the wheel off to have the tyre replaced without having to give the garage an extra quarter hour's labour each time. Do that twice, and you've spent as much as the wrench costs just for the pleasure of having someone else do it for you.
(On that note, invest in a basic tool & socket set combo at a Halfords or Homebase sale; the stuff probably won't be good quality, but with enough of a reduction you'll get a lot of handy tools fairly cheap, which will last OK if you're careful, and if nothing else they count as a starter pack)
Not that I'm a hardline advocate of buying all your own tools and doing everything at home. It can be risky and even more expensive that way, particularly for rare jobs. For example, it'll take a lot for me to bother trying to DIY anything to do with hydraulic brakes in future after some bad experiences in the past. It doesn't come up that often and it's a pretty critical thing both for your own safety and keeping the bike/car at all driveable.*
There's a time and a place for such investment of time and money, and generic tools that can be used for a variety of simple jobs certainly counts. And everyone should know how to change their own oil... it's like not being able to wash your own dishes Very Happy
As for the stand thing - it's OK to drain it on the sidestand, and in fact it may be easier that way depending on the relative position and bulkiness of the side and centre stands on a particular bike. But for refilling, you may want to prop it against a wall (on the opposite side to the filler) just SLIIIGHTLY leaning into it, locked in 1st gear whilst you pour and certainly when you check the level. Or have a trusted ally hold it upright. Trying to keep it upright whilst filling the oil yourself at the same time will end in tears and possibly a trip to the hospital. Checking the level when it's leant over by 15 degrees or more will give an inaccurate reading.
BTW I was writing it from the perspective of someone whose bike ONLY has a centrestand... Getting the catch tray into a suitable position with that sucker in the way is a pain in the bum. I'm considering getting the oil almost too hot to touch next time and shunting it through my biggest funnel into an old 2L pop bottle instead.
* for a fun example of both of these cases, pick up a Renault Megane (98-02) Haynes manual, and trace the method for changing the water pump. This is an involved, but far from impossible task on an older, simpler car, which is fairly simple to chug your way through after you've done it the first time... and the initial description and length of the main method as written by Haynes makes it seem that way for the Meg, too.
However, there are so many references and jumps to tasks in other chapters that have to be done along the way - some of them nesting four-deep - that to write the whole thing out would take probably 10 pages of A4, and the "spanner rating" of the whole thing goes through the roof, both in Haynes' own terms (difficulty), and in how much of one you'd have to be to attempt it at home. The gonzo tooling alone (e.g. a bespoke camshaft lock) that you'd have to invest in for a job you may have to do twice if you kept the car >5 years made it economically insensible. In prior cases, it needed a bucket, some fresh coolant, a new pump, a screwdriver, torque wrench and a couple of different sockets, and a sturdy pair of mole grips to get coolant pipe circlips on and off. Plus fingers to check the cambelt tension after getting the new pump on and adjusting its position.
The challenge is whether you can actually get through reading the entire process in a single day, without falling asleep or chucking the book across the room in confused frustration.
I gave up after about 2 1/2 hours and just let the garage have at it. Good job too - the pump was fine, but the car actually required some weirdo bit of plumbing that could only be ordered from Renault wholesale. I probably could have got hold of it and done it myself, but I reckoned they deserved the work for figuring it out.
J.M.
PostPosted: 19:22 - 02 Nov 2011    Post subject: Reply with quote
Ahh yes, that gets to me a bit too Laughing It's never happened mechanically to me before as I've not done much/any of that, but by god I hate following a computer tutorial and going "hang on, how the heck did they get there!"
I think I'll probably end up buying the torque wrench, if I do over tighten that bolt and render the bike temporarily useless then I'm going to be rather stuck with my commute Laughing Plus it'll be a handy tool to keep around Thumbs Up There's a store in Leicester, so only about 10 miles ish, or I could be the lazy guy and order online Thinking
I have got myself a couple of tools, but nothing major really; just a few small things. Bought one of these which sits nicely under the seat along with a small hammer pocket tool which includes a knife, pliers, etc.
Hopefully be off collecting the oil + washer tomorrow, not sure when I'll be getting the torque wrench as it's too far away to fit into my free time tomorrow Sad
The last post was made 14 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 99.26 Kb
