Riddle Time
The Artist
PostPosted: 01:03 - 08 Nov 2011    Post subject: Riddle Time Reply with quote
https://www.bikechatforums.com/files/riddle.jpg
Post your answer for each
e.g.
Easy =
God =
God slayer =
plugger147
PostPosted: 01:28 - 08 Nov 2011    Post subject: Reply with quote
Do the birds know that the other can only lie or tell the truth?
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
plugger147
PostPosted: 01:32 - 08 Nov 2011    Post subject: Reply with quote
Nevermind, didn't read the one question bit....
The Artist
PostPosted: 09:01 - 08 Nov 2011    Post subject: Reply with quote
Easy is fairly easy, I can't work out god atm though.
Redoko
PostPosted: 11:51 - 08 Nov 2011    Post subject: Reply with quote
If one of the birds always lies then it cannot tell the truth. It will always lie to you.
You would ask one of the birds which door he would pick if he was the other bird.
One always tells the truth, one always lies.
The Artist
PostPosted: 11:56 - 08 Nov 2011    Post subject: Reply with quote
Ok, so you got the easy one. Which is fairly easy.
Try God now. Laughing
Redoko
PostPosted: 12:02 - 08 Nov 2011    Post subject: Reply with quote
I will ponder it, but at the moment it is above my capability. Laughing
mistergixer
PostPosted: 12:31 - 08 Nov 2011    Post subject: Reply with quote
I disagree, that method would not tell you which door is which.
The evil bird may want to send the good bird to hell, he may not, equally, the good bird may want to send the evil bird to heaven, or he may not.
None of these points is outlined in the original puzzle, and therefore cannot/shouldn't be assumed.
Equally, it is assuming that the one of the birds is aware of the other bird's prediliction to truth or lies.
Personally, I would ask one of the birds if it was a bird. If it replied yes, then it could be assumed to be the truthful bird, and the other bird the liar. I would then ask the lying bird which door was which, and do the opposite of his response.
If the bird replied 'no' to the 'are you a bird' question, it would be the lying bird, I would then ask the other bird which door was which and assume his response to be truthful.
That, however, is assuming that the birds are self-aware, something which is not mentioned in the riddle.
Space Monkey #7
The Artist
PostPosted: 12:42 - 08 Nov 2011    Post subject: Reply with quote
EASY SOLVED
It is correct, here is why.
If you pick the good bird (unknowingly)
Ask it which door he would pick if he was the other bird, then he would tell you the truth which is the lie from the bad bird. The answer you would get is the door to hell.
If you pick the bad bird
which door he would pick if he was the other bird, then he would say the door to hell because he lies and obviously the good bird would pick heaven.
Therefore you know which door is which now.
EASY SOLVED
connornrg
PostPosted: 12:45 - 08 Nov 2011    Post subject: Reply with quote
God Mode:
Do you know the door to heaven? If no then it is the lying bird, if yes it is the good bird! so if you find the liar go ask the other one!
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
The Artist
PostPosted: 12:48 - 08 Nov 2011    Post subject: Reply with quote
connornrg wrote:
God Mode:
Complete fail. Re read the rules. You can only ask ONE question to ONE bird.
mistergixer
PostPosted: 12:52 - 08 Nov 2011    Post subject: Reply with quote
Your answer assumes a) that the birds know that the other lies/tells the truth.
This is not outlined in the original riddle.
Your answer also assumes that good bird wants heaven, bad bird wants hell. This is not outlined in the original riddle.
Perhaps the good bird did something terrible during his life and thinks he deserves to go to hell. Perhaps he has told the evil bird this. Does your answer still work now?
Space Monkey #7
The Artist
PostPosted: 12:57 - 08 Nov 2011    Post subject: Reply with quote
True it does assume these things, I meant to put that in my post. I think we can safely assume the birds want to go to heaven. The good bird is good, the bad bird is bad (in wanting the good bird to go to hell).
mistergixer
PostPosted: 13:45 - 08 Nov 2011    Post subject: Reply with quote
Oh, well, if we are assuming things, then I'm assuming the birds are self-aware.
I would ask one bird the following question:
If you are a bird, tell me which door is heaven, but if you are not a bird, tell me which door is hell.
The truthful bird would reply: I am a bird, door x is heaven.
The lying bird would reply: I am not a bird, door x is hell.
God mode done.
Space Monkey #7
The Artist
PostPosted: 13:46 - 08 Nov 2011    Post subject: Reply with quote
God mode done.
That is 2 questions
D O G
PostPosted: 15:08 - 08 Nov 2011    Post subject: Reply with quote
IMO there is no solution to the riddle above Easy mode - it'll be some wanky smartarse 'trick' bollocks which has no real basis.
Doesn't mean that I'm not despreate to read it tho...
nowhere.elysium
The Pork Lord
PostPosted: 15:24 - 08 Nov 2011    Post subject: Reply with quote
God Slayer:
"Bearing in mind that you're going to be going through it first, which is the door to heaven?"
That is, of course, operating on the assumption that the bird is self-aware.
mistergixer
PostPosted: 15:31 - 08 Nov 2011    Post subject: Reply with quote
The Artist wrote:
That is 2 questions
No, it's a conditional if/else statement.
Space Monkey #7
PostPosted: 17:42 - 08 Nov 2011    Post subject: Reply with quote
CBA.
https://i39.tinypic.com/o59t37.gif
Kate_W
PostPosted: 10:41 - 10 Nov 2011    Post subject: Reply with quote
Highly confusing riddle this is ! Why do we have birds which talk to begin with ? Lol ! Jokes aside,I think I would go by what mistergixer said.I would ask the birds exactly those questions.
Check this brainteaser if you wish - Laughing
https://www.iqtestexperts.com/brainteasers/
Cadbury
PostPosted: 12:44 - 10 Nov 2011    Post subject: Reply with quote
Ok, so.
God slayer mode:
“Is one of the following statements true and the other false? The door on the left goes to heaven. You are a liar.”
Yes: door on the left
No: door on the right
I'm pretty sure this works and keeps within all the parameters of the riddle?
angryjonny
PostPosted: 15:26 - 10 Nov 2011    Post subject: Reply with quote
God mode:
"If there was another bird present who would always give the opposite answer to you, which door would that bird tell me led to heaven?" - then do the opposite.
Ask Lying Bird
if A is correct: Imaginary Truthful Bird says A so Lying Bird says B
if B is correct: Imaginary Truthful Bird says B so Lying Bird says A
Ask Truthful bird
if A is correct: Imaginary Lying Bird says B, so Truthful Bird says B
if B is correct: Imaginary Lying Bird says A, so Truthful Bird says A
angryjonny
PostPosted: 15:58 - 10 Nov 2011    Post subject: Reply with quote
God Slayer mode:
Assuming that the lying bird cannot just make stuff up (like one door goes to Leeds and the other to France) and has no understanding of the concept of decimals, and can do arithmetic, the following works.
(Pointing to either door) What do I get if I multiply the number of beaks on your face by 10 and add to it the number of Es in the name of the destination behind this door?
If answer = 11 (10*1 beak + 1 E in Hell) = truthful bird, door = Hell
If answer = 12 (10*1 beak + 2 Es in Heaven) = truthful bird, door = Heaven
If answer = any other number 1, 2, 21, 22 etc then this bird is lying about the number of beaks on its face and therefore is the lying bird. So if the number ends in a 2 that door is Hell and if the number ends in a 1 that door is heaven.
The999Kid
PostPosted: 17:25 - 10 Nov 2011    Post subject: Reply with quote
CHR15 wrote:
lick both birds.
the one that doesn't taste of custard is lying.
that method requires you to be off your tits...
The last post was made 14 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.93 - MySQL Queries: 13 - Page Size: 129.03 Kb
