Brake pads, how long do yours last?
DrDonnyBrago
PostPosted: 17:55 - 09 Nov 2011    Post subject: Brake pads, how long do yours last? Reply with quote
So, front, back and on what bike, how long do your brake pads last?
Trying to see if my usage is normal Thumbs Up .
sebastianw
PostPosted: 18:00 - 09 Nov 2011    Post subject: Reply with quote
ER6F, both changed for the first time at 22000 miles. Back knackered, front still had 3mm of pad left
salty21
i usually go through 2 rear sets to 1 front. not sure what distances though. If i had to guess i'd say about 7000 miles
twostroketit
PostPosted: 18:27 - 09 Nov 2011    Post subject: Reply with quote
FZ6 Still on original pads front and rear. 26000 miles.
sup up your beer and collect your fags
Sam_Y_93
PostPosted: 18:53 - 09 Nov 2011    Post subject: Reply with quote
Not had a bike long enough to know Embarassed
Current bike (Hornet) has 13k on and about to change them
Jim Mc
PostPosted: 19:12 - 09 Nov 2011    Post subject: Reply with quote
what's the minimum pad depth and disc thickness for MOT?
iooi
PostPosted: 19:14 - 09 Nov 2011    Post subject: Reply with quote
Well I got one set from ebay and they lasted less that 3K.....
Next set are doing better @ 4 K and about 1/2 way down....
And I consider myself very gental on the brakes.
DrDonnyBrago
PostPosted: 19:42 - 09 Nov 2011    Post subject: Reply with quote
Cheers for the input,
Seems my use is fairly high, but not unusual.
I've been getting 6-7k front and back.
Jim Mc - disc thickness depends on the bike, it is normally stamped onto the disc itself. Typical seems to be around 3.5mm.
Pad thickness is 1.5mm for non sintered or 1mm for sintered at the thinnest point. In practice there are wear markers cast into the pad, if you can't see them they are worn out
HD
PostPosted: 22:34 - 09 Nov 2011    Post subject: Reply with quote
Well I have done about 5km and have been through two sets on my 50 Laughing
Cos the bike doesn't go fast though, I get my adrenaline from braking hard Razz
Maybe they are just shit pads or something but some people rate Goldfren high?!
Marcg868
PostPosted: 00:07 - 10 Nov 2011    Post subject: Reply with quote
I just change them every MOT regardless off what they look like so between 3,000 to 5,000 miles.
JACK, MISS YOU LOADS YOU LEGEND.
Welshd1k
PostPosted: 03:22 - 10 Nov 2011    Post subject: Reply with quote
3-5k on back with a wavey and ebc HH pads
6-9 k on front using ebc HH
5k on front using ARMSTRONG HH
robbieguy2003
PostPosted: 08:47 - 10 Nov 2011    Post subject: Reply with quote
6-9k on the front and about 10-12k on the back.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
spyuggy
PostPosted: 23:09 - 10 Nov 2011    Post subject: Reply with quote
Donny, your brakes are about average, some use brakes and others use gears, whatever turns you on mate Wink
Treat each day as if it was your last, because one day you will be right.
hellkat
PostPosted: 23:15 - 10 Nov 2011    Post subject: Reply with quote
Yeah, front brake pads, I go thru them more than back.
(although I do try to remember to brake front and back, I just tend always to be touching the front brakes cos I'm always filtering)
I invariably think "what's that odd noise" for a few weeks, then it gets worse and I think "Ohhhhhh, thats the 'brake pads noise' and I listen to it get worse and worse for a week or two (depending on how long till payday) ... and then I get round to buying some more.
Note to self, buy brake pads and clutch cable before proper winter sets in.
Dazbo666
PostPosted: 23:26 - 10 Nov 2011    Post subject: Reply with quote
About 8-10k with EBC or Kyoto pads,
or about 3-5k with Armstrong soft compound pads
Word of the day : DILLIGAF
The last post was made 14 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 82.8 Kb
