Petrol theft.
PostPosted: 12:51 - 11 Nov 2011    Post subject: Petrol theft. Reply with quote
I gave a mate of mine my RXS to commute on to uni and back. The other day he called me and said it had broken down outside uni and wouldn't start I asked him about the reserve and he said he had only done 20 miles since he filled up. He called the AA and the guy found out the tank was bone dry. Obviously someone had unclipped the petrol hose at uni drained out most of the petrol and clipped it back. Is there any decent way to prevent this? I thought clamping the hose with Jubilee clips but then I was worried that they would just cut through the hose causing even more trouble. Is there any braided/re enforced hose out there? This was done where all the Bikes park in broad day light.
I would have loved to have caught them doing it. A swift boot to the face then half a dozen to the testicles while he is on the floor.
FerretFing
PostPosted: 12:57 - 11 Nov 2011    Post subject: Reply with quote
I use a jubilee clip on mine, it's fine as long as you don't go crazy on the tightening - hopefully enough of a deterrent for them to move onto the next bike......fucking scum!
The Artist
PostPosted: 12:59 - 11 Nov 2011    Post subject: Reply with quote
You sure it isn't leaking?
Of all the tanks to drain, an rxs isn't exactly bulk business is it. You would get more collecting all the loose petrol in the hoses at a petrol station.
EazyDuz
PostPosted: 13:03 - 11 Nov 2011    Post subject: Reply with quote
At a uni it is a different story.
tatters
Exxon Valdez
PostPosted: 13:04 - 11 Nov 2011    Post subject: Reply with quote
https://www.ebay.co.uk/itm/6mm-1-4-Stainless-Braided-Fuel-Hose-Kit-Car-BriSCA-F2-/390364048782?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae382ad8e
Use with jubilee clips, they would have to use proper cutters to cut it but will stop a knife.
PostPosted: 13:13 - 11 Nov 2011    Post subject: Reply with quote
Leaking about 7/8 litres of petrol in a couple of days? No.
PostPosted: 13:48 - 11 Nov 2011    Post subject: Re: Petrol theft. Reply with quote
Checked for any CCTV? Report it as a theft to the police and the UNI.
mrtEE
PostPosted: 13:55 - 11 Nov 2011    Post subject: Reply with quote
Smear dog sh*t, razor blades and AIDS all over the petrol pipe and tap?
Just remember to wear gloves when putting it on reserve Wink
Jim Mc
PostPosted: 18:49 - 12 Nov 2011    Post subject: Reply with quote
Not sure about the RXS but the CBR has a vacuum tap on the fuel tank, surely it isn't that simple to drain the fuel from the RXS by just removing the hose?
Moo.
PostPosted: 20:00 - 12 Nov 2011    Post subject: Reply with quote
RXS will just be gravity fed, if you take the hose off, it all leaks out Wink
A2 Passed 18/6/10
stonesie
PostPosted: 00:05 - 13 Nov 2011    Post subject: Reply with quote
Your CBR will have a 'Prime' setting which will let the fuel flow without vaccum from the engine...
It's a very hard thing to 'scrote proof' but what I did to the cg was to wrap steel wire round the ends with the ends left pokeing out and sharp, the hope was that any scrote messing with it would grab hold and leave a nice blood sample behind Twisted Evil
Rowey
PostPosted: 02:46 - 13 Nov 2011    Post subject: Reply with quote
Get some steel braided line
Attach battery to it via a simple switch to electrify it (could use a capacity to add extra punch).
Flick switch on when parked up.
Anyone touching it gets an electric shock.
Profit
ZX6R C6F.
Marmalade
PostPosted: 11:31 - 13 Nov 2011    Post subject: Reply with quote
Profit
Putting it to a battery will only put 12v into your metal fuel pipe connected to your metal fuel tank. Won't cause a major fire at all.
To get any kick it'd need to be connected to a coil and something to make it pulse
Easter Bunny
PostPosted: 11:41 - 13 Nov 2011    Post subject: Reply with quote
Personally i reckon its more likely he was mistaken and it was last week he filled up
Marmalade
PostPosted: 11:42 - 13 Nov 2011    Post subject: Reply with quote
Just because you're old and senile doesn't mean every one is
Im-a-Ridah
PostPosted: 12:24 - 13 Nov 2011    Post subject: Reply with quote
You'd probably be able to smell it if all that fuel leaked out. As others have said, ask the Uni for the CCTV.
Ingah
PostPosted: 19:42 - 13 Nov 2011    Post subject: Reply with quote
A sensitive-ish alarm might've helped.
-- Ingah
johnsmith222
PostPosted: 03:09 - 14 Nov 2011    Post subject: Reply with quote
Probably not considering the 6v electrics stuggle to light the indicators half the time. Laughing
PostPosted: 10:39 - 14 Nov 2011    Post subject: Reply with quote
He doesn't ride it enough for that, I think this is only his second fill up since he has owned it!
The last post was made 14 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 111.62 Kb
