What van??
 Topic moved: from Random Banter to Dear Auntie BCF... by G (17 Nov 2011 - 09:34)
tatters
Exxon Valdez
PostPosted: 14:30 - 14 Nov 2011    Post subject: What van?? Reply with quote
Currently looking to buy a Van to carry 2/3 trail bikes in the back, has to be reliable and good on fuel any suggestions of what makes and models to look out for around £3k?
mad4it028
PostPosted: 16:01 - 14 Nov 2011    Post subject: Reply with quote
seams all modern vans have there faults personly tho ide go for a sprinter
main fault with a sprinter is ring of death ,copper washer under the injectors leak creating carbon ring build up when you try to remove injector they snap in the head so any sooty or tar like build up round the injectors walk away
modern transits suffer with duel mass clutches and constanly needing the injectors reprogramming
renaults, vauxhall,citroen all share same problems with injectors
iveco are very underrated with there only fault being the rear brakes lock 1st when empty cure is to carry more lol
PostPosted: 16:40 - 14 Nov 2011    Post subject: Re: What van?? Reply with quote
I had a bit bigger budget and ended up with a Vito Mk2 - was also considering a T5.
Unfortunately your budget will only stretch to the Mk1 Vito and T4, but both should still be pretty good on fuel.
3 bikes will be a struggle - should be ok for dirt bikes, but tight for others (which a swb transit you can get 3 sports bikes in ok).
But being that bit narrower also makes them a chunk less hassle for general 'daily' stuff - ie car parks etc.
robs321
PostPosted: 17:24 - 14 Nov 2011    Post subject: Reply with quote
you would pick up an half decent toyota hiace for that, mega reliable, but not as economical as the VWs and Trafic clones.
PostPosted: 17:35 - 14 Nov 2011    Post subject: Reply with quote
Providing it's under the appropriate weight (tad under 2t unladen I think), consider a crew cab - it's then allowed to do 70mph on A roads; while a normal front-seat-only van or one with a crew cab but over 2t is a 60mph speed limit for a de-limited dual carriageway.
Skudd
PostPosted: 18:00 - 14 Nov 2011    Post subject: Reply with quote
A White one
swanny
PostPosted: 22:50 - 16 Nov 2011    Post subject: Reply with quote
get an LDV convoy..
Tranny engine, gearbox and biggest 3.5t van around..
at half the price !!
M SWANNY.. see a sig !
tatters
Exxon Valdez
PostPosted: 22:56 - 16 Nov 2011    Post subject: Reply with quote
swanny wrote:
get an LDV convoy..
I may not know much about vans but l know LDV,s are cheap for a reason....
Looking at Vito or VW T4,s cheers Thumbs Up
PostPosted: 23:10 - 16 Nov 2011    Post subject: Reply with quote
Not the biggest by a fair bit.
Sprinter/LT35 and Iveco are both bigger in LWB and also come in XLWB. All are 4m load area in LWB and the Iveco is 4.5m in XLWB, while the other two are 4.2m I think.
I don't think you can get them really long in 3.5t, but the older style Mercs came in absolutely massive versions for the 6t ones.
swanny
PostPosted: 23:30 - 16 Nov 2011    Post subject: Reply with quote
looked at sprinters and the daily's and they are not as wide, which does make a difference, I had forgotten about the xlwb ones though as they are rare as if your after paying less than 2500 for one
I've managed to get my 3.6m wood in from B&Q Smile
PostPosted: 00:00 - 17 Nov 2011    Post subject: Reply with quote
I've had both a LWB LT35 and a LWB LDV.
Also test driven an XLWB and LWB Iveco; as well as a decent variety of other vans.
I wouldn't say the LDV was noticeably wider than the LT35 and definitely not that the Iveco; but both definitely had a fair bit bigger total load area.
pits
PostPosted: 00:05 - 17 Nov 2011    Post subject: Reply with quote
Personally, MK5(?) new old Transit
Ours is a 51 plate it has cost us a battery and a new injector pump, just clock over 150k miles.
I like Sprinters and Vitos but they don't half rust, most of the MK1 Vitos are dead or being bodged together, the metal in them is piss poor think up to like 2005 before they finally galved the bodies, Sprinter the same
Our 51 plate Transits has two bits of rust, drivers wing which is original and the passenger wing which is a cheap pattern part, the rest is solid
Our 53 plate Transit not a spec of rust
Our 51 plate Iveco has surface rust due to chipped paint in a few areas, but nothing like Merc rust.
I just couldn't buy a Sprinter or Vito with the known rust issues and the injector issues.
That said if you go for a Transit and you see the injector pump is leaking diesel it will be around £500+ to replace, so check where it has been parked and get your head under the front bumper and look for signs of diesel there, the leak can change each time you stop, and only leak when the van is stopped for some reason, at one point the one on mine was pissing diesel out (thankfully on the old dirt car park in work)
HTH
hmmmnz
PostPosted: 04:15 - 17 Nov 2011    Post subject: Reply with quote
we hired a merc sprinter camper here in nz,
it was double the weight of my delica,
it was faster to 60mph
had a higher top speed,
and used less gas
far more economical than the transit work van i had as well.
my money would be on the merc or the equic vw with the same 2.5 diesel turbo motor,
the humans are dead
I kick arse for the lord
boundy
PostPosted: 20:46 - 18 Nov 2011    Post subject: Reply with quote
swanny wrote:
get an LDV convoy..
You taking the piss? The LDV Convoy is the worst van I have ever had the misfortune of having, 2 years i had that piece of crap. There're noisy, the windscreens leak badly, even after having the rubber replaced twice (that cost more than the glass), you could fit a yellow pages in the door shuts and they are very slow. It was only 5 years old.
I've also had a 2007 Merc Vito that I loved.
A 2007 VW Crafter, you proberbly saw this van a few times we went out- masive inside, I could ride my bike straight in the back.
I'm now on to a 2011 VW Transported, me and Blue got both bikes in with ease, plus all our gear and my Sortimo was still fitted in the van.
These may all seem out of budget but i bought one of my old company vans 6 months ago for 3k, it was a 2006 Transporter with 160k on the clock, full history, one owner ect. It needed new brakes for the MOT and the EML light was on but it was still a bargin price.
We let a 55 plate WV LT35 go for £1700 last year.
There are some bargins to be had if you know where to look. First place I would ask is anybody you know who works for a firm that run a decent fleet of vans that own them. All ours go to auction and make pennies anyway, so if anyone at work wants them, they can buy it for the average CAP. They sold my old man a 56 plate Passat for £2700 a few months ago.
I don't think we have got anything at the mo but I can check if anything is due to go to auction
tatters
Exxon Valdez
PostPosted: 20:51 - 18 Nov 2011    Post subject: Reply with quote
Yes please, l,m still on the look out for one Thumbs Up
mr jamez
PostPosted: 12:45 - 20 Nov 2011    Post subject: Reply with quote
The vito (like sprinters) rot. Just because it has a mercedes badge on the bonnet don't expect decent build quality! I've driven two sprinters regularly and test drove a vito. The sprinters had the big lumps and went well, the vito was a 108 and felt like a LDV Laughing The load space in the older vito is disappointing. Not had a go in the latest vito.
I was looking at T4 transporters simply because they appealed to my tarty side. In all honesty they are out of date now, the design is old and they have too many niggles. They also carry an inflated price tag as people want them for surf vans or campers, VW scene tax Rolling Eyes
You will probably come across lots of cheap vauxhall vivaros/renault traffics, nice vans but they have chocolate gearboxes.
I run a LWB hi-ace, its got the D4D TD engine. Quite simply the best van of this size. Very solid and reliable workhorses. I use mine for work and don't run a car anymore as it drives like one anyway Smile
PostPosted: 12:56 - 20 Nov 2011    Post subject: Reply with quote
The Vitos do rot, especially the white ones (mine is white) - they're made in Spain not Germany, which may explain some things.
My vito is a 111 and as stock it's 'ok', but with a 'chip' it's not bad at all - I really wanted the 115, which when chipped is pretty good.
Fisty
PostPosted: 19:13 - 20 Nov 2011    Post subject: Reply with quote
https://www.tensionnot.com/pictures/images/Car/Free-Candy-Van.jpg
One like this.
Fatter and faster than Fret
Old Git Racing
PostPosted: 19:36 - 20 Nov 2011    Post subject: Reply with quote
Driven a lot of vans over the last few months, transit, sprinter, LDV, but suprisingly the best has been a Renault traffic, quiet good seat with fold down armrest, fast and torquey with cruise control and about 34mpg.
Must be reliable, last one had 350,000+ miles on it and still went well.
OGR
Quote Me Happy
PostPosted: 19:41 - 20 Nov 2011    Post subject: Reply with quote
Get something with a decent loading height. My Gas Gas only just went into my old smiley face Transit.
silky666
Captain Rulebook
PostPosted: 21:38 - 20 Nov 2011    Post subject: Reply with quote
my transit is now for sale
tatters
Exxon Valdez
PostPosted: 21:45 - 20 Nov 2011    Post subject: Reply with quote
Spec? price?
silky666
Captain Rulebook
PostPosted: 21:50 - 20 Nov 2011    Post subject: Reply with quote
tatters wrote:
Spec? price?
smiley trannie... fits 2 bikes in nicely ... fek knows spec... runs lovely... needs an mot .... new alternatpr and battery.
price.. a steal... been ummin and aaaring for ages (as u know) ... circumstances now mean i HAVE to sell.
ie: under £800 ... but whatever its worth minus a BCF discount
that van will run for ages
got buts to secure bike etc.
come round and have a look next week if u r free
tatters
Exxon Valdez
PostPosted: 21:57 - 20 Nov 2011    Post subject: Reply with quote
I,ll give you a call tomorrow Thumbs Up
The last post was made 14 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.69 - MySQL Queries: 16 - Page Size: 126.41 Kb
