| loply |
 loply World Chat Champion
 Posted: 17:20 - 10 Sep 2004 Post subject: [OT] Seagull Boat Engine |
Hi folks,
But OT but kind related
Ive got an ancient (1950s) seagull 100cc two-stroke outboard engine.
After fixing the broken magneto the engine has been running fine but now wont fire up.
There is a spark, fuel well is full, fuel is free to flow into the carb, the engine turns over, but it wont start...
Im assuming a problem with the carb/mixture but I cant see whats causing it. Any idea what to check? I figure there might be a needle valve blockage?
The engine spins for about a second but just spluttery, then stops. |
| Robby |
 Robby Dirty Old Man
| Retro-Man |
 Retro-Man Traffic Copper
 Posted: 00:20 - 11 Sep 2004 Post subject: |
second that
the fact that you had it running implies settings are not too far out
most likely some shit has been taken from the float bowl and is blocking a needle
remove and clean out carb
if possible do it without turning carb upside down so when you take float bowl off you will see how clean it is...  ____________________ https://domharnessphotography.webs.com |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 02:18 - 11 Sep 2004 Post subject: |
Wotcha.
It may be worth checking the crank seals, especially on an older engine. ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 17:18 - 11 Sep 2004 Post subject: |
Has it a choke or an idle adjustment screw? Try making the mixture a bit richer? If it's a mucky filter or something restricting the fuel it should start with a bit more. You could try putting a couple of drops of (petrol?) or something in the cylinder and seeing if that fires up fine? All just ideas off the cuff, so feel free to tell me if they're wrong and probably dangerous.  |
| Git |
 Git Brolly Dolly
| loply |
The last post was made 21 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
